LCD 19" BENQ T905 problems
  • retiredcaps
    • Apr 2010
    • 9271
    #61
    Re: LCD 19" BENQ T905 problems
    Originally posted by capullaco
    One thing im still not sure:
    Code:
    Desolder all 4 transistors and the polyester caps (between the transistors
    Is the polyester cap the 'K' cap from my first pic? Theyre 2 so it makes sense, but just to be sure.
    Yes, the K cap is what Krankshaft is referring to.
    About the dual diodes, yes they are.Theyre named "DXXX" and they have this printed on one side:
    YG902C2
    -->|--|<-- CI
    40 121
    I managed to unstick them from the heatsink.
    But how do I test them? I tried this but I dont know if its correct:
    - Black (COM) on 2nd pin RED on 3rd: 400
    - RED on 1st pin BLACK on 2nd: 400
    Those values are with the diode setting ( -->|) of the polimeter. Other combinations didnt show results.
    Yes, that is correct. Excellent job. 400mV (millivolts) indicates that the dual diode is good. A good diode should read between 0.4V and 0.7V.
    The things I need to resolder, I just need to unsolder them and sold again with new tin or is there any other action involved? I ask because the soldering on those things seems ok , at least on looks.
    One more thing, should I resolder those things marked as '?' on the 6th pic?
    Krankshaft writes to desolder (remove all the old solder) and resolder with new solder.
    Another analogy (I spelled it right this time) might be painting a door.
    You have a door that needs to be painted. For the most part the paint looks good, but it could use some touch up.
    The lazy way is to just put another coat over it without cleaning it or stripping it down to the wood. This is akin to reflow new solder on top of the old solder.
    The "proper" way to paint this door is to remove all the old paint, sand it down so that is smooth, apply protective coat, and then paint it. This is akin to removing the old solder and adding new fresh solder.
    Yes, resolder those ? marked items.
    PS. You have made huge progress in the last 24 hours. Keep up the good work.
    --- begin sig file ---
    --- end sig file ---
    • capullaco
      • Aug 2010
      • 40
      #62
      Ok,went to buy the components but they didnt have the fuse at 125V.
      Would one of 220V do the job?
      • retiredcaps
        • Apr 2010
        • 9271
        #63
        See your pic at
        https://www.badcaps.net/forum/attach...6&d=1283482087
        See where it says re CAUTION:
        Others may have different opinions on the fuse, but the warning CAUTION is there for a reason. I know it is not the picofuse, but the same caution applies.
        • capullaco
          • Aug 2010
          • 40
          #64
          Oh, thats not the blown fuse, its one on the top right on the pic.Next to the heatsink, only half of it is visible.
          Its the picofuse, but I replaced it the 1st time with a cristal one.
          Also the normal voltage in Europe is 220V, just saying, dunno if that affects.
          • capullaco
            • Aug 2010
            • 40
            #65
            Ok, so I was resoldering all the things you marked.
            When I removed 2 of the transformers, one of their pins were without that silver layer on the board, so the tins doesnt sticks well.
            I attached some pics, 1 and 2 are the same and the 3 is the other pin.
            How can I fix this?
            • retiredcaps
              • Apr 2010
              • 9271
              #66
              How can I fix this?
              If you lifted the solder pads, there isn't much you can do.
              For this exercise, you are removing all the old solder.
              I like to add a little bit of solder first to the old solder/joint and then I use my desolder pump to suck everything up. Then I clean up with a little bit of alcohol and add fresh solder.
              • capullaco
                • Aug 2010
                • 40
                #67
                I used the desolder pump to desolder all the items (thought I didnt add more
                solder,never saw that technique on the videos of desoldering I have seen) and only those 2 gave problems.
                Maybe scratching the board a bit? What if I just leave a ball of tin? Will it be a dry joint? Maybe painting the place with a pencil? (dunno why this came to my mind)
                How about soldering the pins to another bit of the board? On the same trace,of course.
                I dont wanna give up yet!
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #68
                  I haven't done the scratching board so I can't say. However, I have soldered pins together when I lifted a solder pad and run a small wire from one pin to the joint. They were on the same trace.
                  As you can see in this post, some people run trace wires or other hacks ...
                  https://www.badcaps.net/forum/attach...5&d=1278637697
                  • capullaco
                    • Aug 2010
                    • 40
                    #69
                    Ok, I can solder a wire easily on the pin from the 3rd pic.
                    But the pin from the 1st and 2nd pic its alone! no traces to anything
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Then you don't have to worry about it. They often use a standard bobbin; some pins are unused. You are concerned about electrical integrity, not the mechanical strength. Unless, of course, you are planning on using your monitor on an ATV.
                      PlainBill
                      • capullaco
                        • Aug 2010
                        • 40
                        #71
                        Ok,gonna try with that pin being dry soldered !
                        • capullaco
                          • Aug 2010
                          • 40
                          #72
                          So I tested it...no luck
                          Didnt even show up the BenQ logo. When I plugged it, I heard a spark, but dunno if it was from inside or just the normal spark sound that sometimes is heard when you plug something.
                          Its like at first, with the green led working ok.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #73
                            Check your solder work again. Check the orientation of your caps, transistors to make sure they were installed properly.
                            Your previous pictures are very hard to see (fuzzy, out of focus, and at an angle). Take a look at this picture
                            https://www.badcaps.net/forum/attach...6&d=1282133540
                            and compare it to yours. Our the other pic, we can see all the PCB designations CLEARLY.
                            The reason I bring up the picture quality is I cannot tell from your pics where things are located.
                            So I'm guessing, but on most benq boards, there are 4 C5707 transistors and 2 Fu9024 FETs.
                            If you see no picture, but have a green power LED, there are 7 things to check. 1 picofuse, 4 c5707s, and 2 fu9024s. Check to make sure the picofuse is not open and the transistors and fets are not shorted.
                            • capullaco
                              • Aug 2010
                              • 40
                              #74
                              Yeah, I changed all the blown things, the picofuse (actually used a normal fuse) and 4 transistors.
                              BTW, the caps are orientated right, Im 100% sure. (white painted side with the negative side, the shorter pin)
                              Which ones are the fets? When I checked the transistors ,only 4 were blown, the rest were ok.
                              Im gonna test all the things again,and try to make a better pic, but cant do miracles with the mobile phone (a relative has my cam and he will be out for a long time)
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #75
                                The FETs could be on the backside on the board.
                                Take the boards to a window on a sunny day. Turn off flash. If your phone has macro mode, use that. Look at your pics on the computer to make sure everything is legible. Some of us don't have PlainBill's 20/20 vision.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #76
                                  Normal fuse? Is this fuse rated the same amp and voltage as the picofuse?
                                  • capullaco
                                    • Aug 2010
                                    • 40
                                    #77
                                    Diferent voltaje but same amp, the guy told me that the amp is the important stuff and it should work with a 220V fuse.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #78
                                      Amp is the most important. It should be the same.
                                      The FET is most likely FU9024. It is a 3 legged component and looks like a transistor. If you find, test to see if it is shorted (same procedure as testing a transistor).
                                      • capullaco
                                        • Aug 2010
                                        • 40
                                        #79
                                        Ok, tomorrow im gonna check all the componentes again.
                                        But the last time I checked all the 3 legged components, they were ok except for the 2 transistors (I made a mistake in some post above saying there were 4 blown transistors, the other 2 were double diodes and they were also ok)
                                        nice night guys, uni class starting tomorrow
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #80
                                          If your board looks anything like the OP, this is the backside
                                          https://www.badcaps.net/forum/attach...0&d=1226067862
                                          showing where the FU9024 are in relation to the c5707.
                                          • Caspar
                                            BENQ GW2780-T power board blown
                                            by Caspar
                                            Hi all, I am looking for some help in ID'ing some parts in an attempt to fix a power supply from a GW2780-T monitor. The power supply PN is 715G7300-P02-006-0V3R. I have been looking around for the PN and it appear the board was used by other OEMs as well (ASUS, Viewsonic). If anyone has a schematic, it would be helpful.
                                            Quick look on the underside of the board, I can see:
                                            -D905 is blown - ? value
                                            -R920 is open - 1Ω ?W
                                            -R927 is open - 20Ω ?W
                                            On top side, I see:
                                            -R931 open - 0.68Ω ?W
                                            Metered short:
                                            -P9NK65ZFP...
                                            06-01-2022, 05:16 PM
                                          • jean luc ferre
                                            laptop hp g72 b52sf screen problems
                                            by jean luc ferre
                                            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                            06-07-2025, 03:27 PM
                                          • drscoot
                                            HP X360 convertible battery blown fuse error, not charging
                                            by drscoot
                                            HP Modelnumber: 14-dh0061nb​
                                            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                            All these 3 batteries are charging...
                                            12-15-2023, 05:54 AM
                                          • Hondaman
                                            USB problems?
                                            by Hondaman
                                            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                            08-12-2024, 03:26 PM
                                          • swerg
                                            Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                            by swerg
                                            Hey everyone,
                                            I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                            I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                            I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                            06-06-2024, 03:39 PM
