dell 2007 WFPb monitor ,no lights
  • aortiz
    • Feb 2014
    • 120
    • mexico
    #41
    Re: dell 2007 WFPb monitor ,no lights
    the lamps dont flash at all
    i do have 19v at both sides of the fuse.
    i dont know where INV-ON PIN IS IN THE INVERTER BOARD is.can you tell me please?
    sorry for the delay,i am having a lot of trouble connecting,tomorrow i got to go buy another antenna.
      By the way, do you have 3.3V and 5V on that USB/SMPS board? I know you do not have the 12V.
      I do not remember which test point is for the BL_ON, DIMM.
      You need to take DC voltage readings on these three test points TP713, 714, and 716 when monitor is off and when it is turned on.
      • aortiz
        • Feb 2014
        • 120
        • mexico
        #43
        i do have 3.3 v all the time,the 5 v show up when i turn on the monitor.
        tp7-13 is 0 volts when the unit is off and when its on
        tp7-14 is 2.75 when is off and 2.77v when is on
        tp-16 is 0 volts when is off and 0 volts when is on.
        i took this readings in refrence to ground whis is labeled tp712 on the power board.
        • aortiz
          • Feb 2014
          • 120
          • mexico
          #44
          is 2.77v a normal reading ?is going to the + side of c142 ,10mfd,25v cap.i can not find where is going from there.
          on the video logic card.
          • aortiz
            • Feb 2014
            • 120
            • mexico
            #45
            bud,its almost midnite,i am going to bed.
            tomorrow i will try to get connected early.
            i lived in oakland calif for about 30 yrs and it just to be that sf bay its 2 hrs earlier than this part of mexico.anyway i will be here tomorrow morning around 9 our time to see if i had any replies.thank you bud,and have a good night.
              "i do have 3.3 v all the time,the 5 v show up when i turn on the monitor." That is good, because the common failure of this USB/SUB-POWER supply is due to failed diodes in the 5V or 3.3V buck regulator power supply.
              "tp7-13 is 0 volts when the unit is off and when its on
              tp-16 is 0 volts when is off and 0 volts when is on."
              Those voltages do not look right. I will need to find out what those 3 pins are.
              "is 2.77v a normal reading ?is going to the + side of c142 ,10mfd,25v cap.i can not find where is going from there.
              on the video logic card." I do not know what that C142 is.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4327
                • Italy - Milan
                #47
                Ortiz my test was another: with all connected up also pc connec. and swithced on does you see a dark image if you point a lamp from the side to screen?
                • selldoor
                  Slow Learner
                  • 7870
                  #48
                  Here is another thread on a set which MAY have the same boards Aortiz perhaps you can
                  check they are the same. Unfortunately they dont manage to fix the set but has a lot of voltages at test points ( as there was no fix we still dont know if these are correct or not)
                  https://www.badcaps.net/forum/showth...ighlight=tp713
                  Post 2 is the "pointed lamp" test - in 3 years on this site I have never seen it referred to as that.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4327
                    • Italy - Milan
                    #49
                    ok i have translated better, is "lamp bet" test, is more clear now?
                    English is strange "point the lamp" is correct "pointed lamp" is another thing..
                    • selldoor
                      Slow Learner
                      • 7870
                      #50
                      No that is a worse translation.
                      There is no name for this test you just have to say ......... try shining a flashlight (american for torch) at different angles onto the screen to see if you can see a dark/dim image of what the PC is producing
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4327
                        • Italy - Milan
                        #51
                        thankyou selldoor
                        • aortiz
                          • Feb 2014
                          • 120
                          • mexico
                          #52
                          ok ,thank you bud.
                          could that 2.77v be the 3.3v being loaded down by something on the logic board?if i take out the cap,will i damage something else in the units when i turn it on to see if the voltage comes up? i tried disconecting connector cn702(the 7 pin connector that goes to the logic board) and the monitor wont turn on)
                          please advise
                          • aortiz
                            • Feb 2014
                            • 120
                            • mexico
                            #53
                            yes ,i see a dark screen when i shine a lamp to it ,sideways,frontways,etc
                            • aortiz
                              • Feb 2014
                              • 120
                              • mexico
                              #54
                              ok selldoor,thank you and i am going to definitly look at that thread.
                              • selldoor
                                Slow Learner
                                • 7870
                                #55
                                please advise
                                Simple explanation there are more scattered throughout the forum maybe some in the "stickies" at the front
                                There is an interaction between the boards. when you first plug in there should be at least a standby voltage though some sets also have the 24v to the
                                inverter.
                                When you press the on button a signal is sent to the power supply to turn the rest of the voltages on via pin pson or pwr or enable further signals are sent
                                to switch on the back lights via Blon pin and subject to other internal testing being ok it should all switch on.
                                  OK, I am confused:
                                  "could that 2.77v be the 3.3v being loaded down by something on the logic board?"
                                  So do you have 3.3V at the point as shown in the pictures and diagram I posted (#42) or you have 2.77V?
                                  We are not getting any where here with so many unclear answers.
                                  • aortiz
                                    • Feb 2014
                                    • 120
                                    • mexico
                                    #57
                                    sorry bud,
                                    didnt mean to confused you.
                                    that was just a dumb question coming from somebody who knows little about monitors but has the will to learn.
                                    the reading is ,and still is 2.77v at the + side of c142 on what i call the logic board the one with the vga connector.
                                    and the reading on the usb board tp35 (positive side of c44)still is 3.3 v.
                                    • aortiz
                                      • Feb 2014
                                      • 120
                                      • mexico
                                      #58
                                      hello everybody ,after a long ,lonlely afternoon.,and thanks to all of you that pitched in ,budm,davip,selldoor and the treads that you guys recommended i read.
                                      i really dont know what i did but,i definitly got a backlight,not very bright but its there,maybe the brightness control can bring it up.
                                      i replaced c142,(blind shot) on logic board,and 3.3v came on at tp7-13,it was 0v.
                                      i dont get a picture yet,but i got faith on you guys.
                                      any sugestions as to where to start to look for data signal?
                                      thank you all
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #59
                                        Wow! progress - do/did you have a pc connected producing a known image?
                                        and is the lvds cable attached at both ends
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4327
                                          • Italy - Milan
                                          #60
                                          what do you see on screen? Black with backlight, white ??
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
                                          • Jesus Coder
                                            Issues Reviving Old Dell 2408WFPb Monitor
                                            by Jesus Coder
                                            I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                            06-25-2023, 02:33 PM
                                          • ChristianBr01
                                            Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                            by ChristianBr01
                                            I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                            This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                            This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                            Does someone have seen this before?...
                                            05-23-2025, 06:06 AM
