Dell E153FPB Back Light problem
  • dell-usional
    • Oct 2010
    #121
    Re: Dell E153FPB Back Light problem - and another
    top fix chap, a bit of 2 amp fuse wire done the trick. all hale brian h
    • coolcurrent
      • Oct 2010
      • 98
      #122
      Hello, my dell flat screen too has this problem. I have read the entire post, but it seems there ins't any particular solution. Can anybody point out which transistor is causing this
      thanks
      • PlainBill
        • Feb 2009
        • 7034
        thanks
        1. The problem is not caused by a transistor. The problem is caused by bad solder joints on the transformers.
        2. There are two identical circuits for each inverter. Either (or both) transformer can have bad solder joints. Usually only one pair of transistors fail.
        3. You need an ohmmeter to determine which transistors are shorted.
        4. If you replace the transistors without resoldering the transformers the new transistors will also fail.
        5. Several different boards were used in each model of the monitor. Without determining which version you have, it is impossible to give you a location number.
        6. There are pictures of some of the different versions of the board in this thread. Since you were unable to identify which one you have, a picture of YOUR monitor will be necessary. See my signature for information on taking and attaching one.
        PlainBill
        • coolcurrent
          • Oct 2010
          • 98
          #124
          my monitor model is E153FPb. one unique thing about mine is that you have to whop the monitor on the back, then it will come on and work just fine. then after powering off for long hours, the cycle restarts again
          • PlainBill
            • Feb 2009
            • 7034
            BFD!!! I had assumed you were smart enough to post in a thread that was related to your monitor. That STILL doesn't tell me what power supply / inverter board Dell happened to use in it!!! It is easy to identify the likely defective parts by looking at the board, I know of no way to do so without opening up the monitor.
            PlainBill
            • coolcurrent
              • Oct 2010
              • 98
              #126
              PlainBill
              Here is the board picture
              • smason
                • 1652
                Seems obvious to me, between reading the rest of this thread, the fact that if you whack the monitor it comes on, and from that (not terribly good) picture.
                BAD SOLDER JOINTS
                • PlainBill
                  • Feb 2009
                  • 7034
                  Good grief, couldn't you make it smaller? Fortunately I was able to match it to a real picture.
                  Large blue circles - transformers with bad solder joints. Remove as much solder as possible from the pins and resolder
                  Red circles - bipolar transistors (2SC5706 or 5707). Test and replace both if either transistor in a pair is shorted.
                  Small blue circles - FET transistors, one for each pair of bipolar transistors. Sometimes fail when the bipolar transistors fail. Test and replace if shorted.
                  Yellow circle. Picofuse. Test and replace if open.
                  PlainBill
                  • alexanna
                    • Mar 2010
                    • 1346
                    #129
                    The2 gray capacitors in the area of PlainBills Red circles are known for poor solder joints also. If you gently wiggle them sometimes you will see the solder move.
                    Al.
                    • coolcurrent
                      • Oct 2010
                      • 98
                      #130
                      thanks for the fast response, i'll do my homework and give feed back tomorrow.
                      without a sucker, which method is best for removing components with a soldering iron, i presently use brush with trimmed tips, but the brush seems to go bad quickly after few uses
                      • coolcurrent
                        • Oct 2010
                        • 98
                        #131
                        PlainBill
                        Hello, thanks i solved the problem by just entirety de-soldering the two transformers you mentioned and re-soldering them again.
                        i will be watching it for a day or two
                        thanks
                        • PlainBill
                          • Feb 2009
                          • 7034
                          thanks
                          Cool!!! You might also consider buying a lottery ticket. You might get lucky twice. Not only was the problem easy to fix, but nothing was damaged.
                          PlainBill
                          • josh_zedlav
                            • Feb 2011
                            #133
                            Hi Folks I'm New here I need help regarding may Dell E153FB.. I've been working on my monitor for almost 3 days.. I tried all i have read from this forum like changing the 4 transistors, resoldering the transformers and other components, and changing the fuse.. It's just that it still keep on turning on and off.. Any possible solution you can give guys? thanks in advance
                            • Welchs101
                              • Sep 2008
                              • 979
                              Have you checked the "bulbs"?
                              If its turning on and then abruptly turning off then you might want to check the bulbs.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #135
                                How long does it stay on? 2 seconds? 2 minutes? 2 hours?
                                --- begin sig file ---
                                --- end sig file ---
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  Caps?
                                  • ASUS ROG Maximus IX Code
                                  • Intel Core i5-7600K 3.8GHz
                                  • Windows 10 Pro x64
                                  • GeForce GT1050
                                  • josh_zedlav
                                    • Feb 2011
                                    #137
                                    hi tnx for the reply.. can you tell what is the proper way of checking the bulbs? another problem i encountered is that I cannot push the button while the lcd is on this mode.. It only took seconds to turn on and off.. then long minutes on then off again
                                    • rukirie
                                      • Feb 2011
                                      #138
                                      I just wanted to share my experience:
                                      My father-in-law had a Dell 153FPB that 'died', i.e. had no backlight.
                                      I saw it flash a bit when I plugged it in so I decided to google a bit to see if these things had a common point of failure (usually bad caps in my experience).
                                      Fortunately, I read this forum and that pointed my attention to the PF751 fuse, not very obvious for an amateur like me I must confess.
                                      I measured great resistance over the PF751 fuse, an indication of a blown fuse, so I replaced it with a 2A slowblow fuse and lo and behold!
                                      We have a backlit image again! I hope the new fuse holds.
                                      Thanks for the groundbreaking work,
                                      Eric Benedikz
                                      ps.saw this picture of the culprit:
                                      http://s807.photobucket.com/albums/y...g=Dell+E153FPB
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Eric Benedikz
                                        Important!!! Resolder all inverter transformers or you will be replacing the fuse again. And some transistors.
                                        For future reference, note the links in my signature on the proper way to attach pictures.
                                        PlainBill
                                        • EGuevarae
                                          • Nov 2008
                                          • 1336
                                          I measured great resistance over the PF751 fuse, an indication of a blown fuse, ...
                                          • GeForce GT1050
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                          • multimesut
                                            Dell 2007FPB Yellow Light Problem
                                            by multimesut
                                            Hello friends,
                                            A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                                            11-13-2024, 07:00 AM
                                          • boyebaran
                                            hisense 65k560 back light problem
                                            by boyebaran
                                            hi to all
                                            tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                                            in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                                            please advise me tnx
                                            05-20-2025, 07:11 AM
                                          • Matias1997caba
                                            Problem with Dell pp35l bios
                                            by Matias1997caba
                                            Hello everyone! I'm having a problem with the BIOS of a Dell PP35L motherboard (DA0RM5MB8E0 Rev:E Y509R Rev:A00). It powers on, beeps 5 times, then 6 times, but there's no display. The problem is that it has two 16MB BIOS files, and all the ones I found online are 1MB and 4MB. I flashed them anyway, but with those BIOS files, the fan doesn't even turn on. Any help would be greatly appreciated! I've attached the BIOS files. Model: Dell PP35L.. Mother DA0RM5MB8E0 Rev:E Y509R Rev:A00. Service Tag: GRZR9M1...
                                            11-26-2025, 08:33 AM
                                          • SDNarcia
                                            Dell 15R-5521 keyboard problem (KBC?)
                                            by SDNarcia
                                            Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                            As additional information,...
                                            07-20-2024, 10:47 PM
