hisense 65k560 back light problem
  • boyebaran
    • Sep 2015
    • 249
    • iran
    hi to all
    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
    please advise me tnx
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • multimesut
    Dell 2007FPB Yellow Light Problem
    by multimesut
    Hello friends,
    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
    11-13-2024, 07:00 AM
  • Mschrenkz@gmail.com
    Hisense 60R6E - No backlight - stuck in boot loop
    by Mschrenkz@gmail.com
    I joined hoping I'll be able to verify which component I need to replace on my Hisense 60R6E. When I plug it in the red light comes on and stays on for several seconds then blinks off and then on again. There is no back light but I can see the logo screen "Hisense Roku" (using the flashlight method) come on while the red light is off. Then it dissapears and the red light is constant again. This cycle keeps repeating. I tried pressing the reset button and it has absolutely no impact. Even held it in for 30 seconds also tried holding the power button in with the TV unplugged - nothing...
    05-09-2023, 08:53 AM
  • koby058
    vostro comes up with back light but no picture
    by koby058
    Hi people!!
    The owner said it showed bad picture once in a while (attached)
    I see that there is back light but no picture.
    I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
    Also attached schematic and BDV
    LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
    07-13-2025, 01:03 PM
