Dell 2007FPB Yellow Light Problem
  • multimesut
    • Nov 2024
    • Türkiye
    Hello friends,
    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard. I turned it off immediately. When I removed the Fli5961-LF, the high current and heat issues were resolved. The EM636165TS no longer got hot.
    Can we be sure that the Fli5961-LF is broken in this case? Will it be fixed if I buy one and replace it?
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • zwect
    Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
    by zwect
    I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
    Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
    Here is the original BIOS dump from the 25R256JVEN chip.
    09-11-2024, 05:54 PM
  • ckom26
    Dell 2007FPB compatible boards
    by ckom26
    Hello, folks.
    Please, forgive this dumb question but I own a 2007FPb whose logic board is FUBAR (really). Obtaining a replacement is not easy any more (or unreasonably expensive) so I was wondering if replacing the logic board with one from the same line (e.g. 1708FP or 1907FP) would bring it back to life. Are the resolution capabilities for each one "hardcoded" into the main GENESIS chip or auto-sensed and applied? Has anyone tried something similar?
    07-04-2025, 07:02 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • totalgearhead
    Dell 2007FPB Component ID Help please!
    by totalgearhead
    Hi All, I need help identifying a replacement for D1 (same as D2 through D5) on the Dell 2007FPB board please? The board ID is an LG Philips LM201W01-SLC1-F11. Thank you for any help! It popped under power while troubleshooting, oops!
    03-11-2024, 07:19 PM
