Dell 15R-5521 keyboard problem (KBC?)
  • SDNarcia
    • Jul 2024
    • 5
    • MΓ©xico
    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
    As additional information, I deactivated the egpu because it was already having problems, could it have something to do with it?
    I have the following keyboard connector measurements:
    Pin 1 - 2.1v
    Pin 2 - NC
    Pin 3 - NC
    Pin 4 - 5v
    Pins 5 to 21 - KSO correct continuity to KBC
    Pins 22 to 29 - KSI correct continuity to KBC and there is 3.3v in all
    Pin 30 - NC
    Motherboard VAW01 - LA9101P Rev: 1.0
    EMain BIOS Winbond 25Q32FVSIQ
    EC BIOS Winbond 25Q16CVSIG
    KBC ENE KB9012QF A3
    Could it be an EC BIOS problem? Could it be solved by reprogramming it? Or is it directly a KBC problem? I attach the diagrams. I appreciate any help.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    If there is no corossion,continuity between kbd connector and KBC is fine,then very very likely kbc chip itself is bad(as kbd is ruled out by you). KBC firmware at fault is very unlikely.
    • NotEnough
      Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
      by NotEnough
      I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays β€œNo AlienFX devices found.”
      What I've Tried So Far:
      • Reseated the cables.
      • Reinstalled AWCC and AlienFX services.
      • Attempted BIOS downgrade but no improvement.
      • Inspected ribbon cables for damage.
      • Explored the possibility of BIOS or
      10-19-2024, 01:34 AM
    • Colin21958
      Keyboard problem on Dell Inspiron
      by Colin21958
      I have a Dell E1405 Inspiron, I refurbished it adding an updated (64 bit) CPU (T5500) among other things; I should mention I bought a job lot of 4 of the same laptop and did exactly the same with all of them. I also added an SSD and installed Windows 10. They all worked fine and I have since sold two of them. However, one developed a shorted motherboard; I'm looking into that, but the other one, which had been working just fine and I had put on sale, suddenly developed a keyboard problem. When you type r you get r5, q gets q', u gets u6 and so on. It's only the top two rows of the keyboard that...
      05-03-2021, 01:13 PM
    • ronaldopdias
      Dell Alienware x17 R1 - Keyboard not working
      by ronaldopdias
      Symptoms:
      No keys work apart from F1, F7, F12 function keys such as keyboard brightness, touchpad enable/disable.
      Keyboard RGB works okay and might be adjustable.
      VERY occasionally it may function but most of the time it is dead.
      The fault is down to the USB data lines not going low when the bus is idle. The keyboard connects over USB, so the issue on the USB data bus causes it to stop functioning.
      The fix is to fit a 1K resistor to the daughterboard that the keyboard + trackpad connect to. The daughterboard is located beneath the battery. The resistor...
      05-13-2025, 04:50 AM
    • toti24
      (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
      by toti24
      dell precision m4600 laptop
      i7 2760qm
      8gb ram 750gb HDD
      intel hd 3000 integraded and nvidia quadro 2000m
      pleasea bear with me english isnt my language and ill try to be as clear as possible
      note i live in mexico in a very small town..
      thank you.
      laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
      the brick happened when i was installing win 10 using usb.
      used rufus and officia microsoft.iso
      it finished copying files from usb...
      03-06-2022, 08:39 PM
    • MrDadosz
      Lenovo Legion 15IMH05 keyboard problem
      by MrDadosz
      Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
      When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
      In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
      Shortcuts Fn + F1-F12 are working. Keyboard is fine.
      I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
      08-15-2024, 05:07 AM
