Dell N5110 problem
  • Achille15
    • Mar 2025
    • Algeria
    Dell N5110 problem
    so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be PL4501 which is part of 1D05V_PWR net with PU4502 and PU4503 part of it too (they were shorted), so I removed the first mosfet and checked its rail and it was intact, so I removed the second one (PU4503) and just like its sister the rail didn't have any short but the inductor was still shorted, so I thought may be the short is on the other side of it, so I removed PL4501 and yes, only one side of if was shorted (the opposite side to PU4502 and PU4503) on that side there are 3 components PC4508, PTC4509 (don't exist on the PCB by default) and PT4502, but even when removed these capacitors were shorted, I read an old post where spleenharvester​ said that "1D05V_PWR appears to become 1D05V_VTT, see the same page of the schematic. Might be worth removing PR4505 to verify the short is not on that side, then remove components one by one", the problem is that even after removing PR4505 the short still exists.
    The question is what's next? what should I do now?
  • Ashik Technology
    Supporter
    • Mar 2025
    • Bangladesh
    Please check the pl4501 impedence. 1D05V-PWR will show short but it's not short.I thik your problem in thermal protection circuit.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      What is the exact resistance to GND on 1D05V rail? A low resistance is expected on this rail.
      • Achille15
        • Mar 2025
        • Algeria
        The resistance value between 1D05V rail and GND is 27, what should I do next?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          The resistance to GND value for 1.05V rail seems perfect to me.
          You can try a lower specs cpu like i3 or i5
          i7 cpu wont run without dedicated graphics chip,so you cant disable graphics chip.
          However, if you want to downgrade to i5, then i can hep you to disable discrete graphics chip.
          Dont see any other reson for heating.
          • tomodachi
            • Apr 2012
            • 610
            • Turkey
            Common problem with that generation of Dell laptops is bad heatsink, check to see if fan side of heatsink is hot or cold during operation.
            if cpu side is hot and fan side is cold, and I mean literally cold, then you have a broken heatsink copper issue
            During operation each side of heatsink must be hot
            • Achille15
              • Mar 2025
              • Algeria
              Well, without even switching on the laptop, just plugging the power to it, CPU and GPU get hot, so this must be a broken component
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Now this become a totally different issue. You dont shared this info at the beginning forcing us in the wrong direction.
                Do you have a dc supply? If yes, whats the consumption in off mode? The mb turns on with display?
                To me,it seems like 3VS/5VS is generated in off mode which is wrong.
