Samsung 2253bw black screen
  • Rtech
    • Jul 2010
    • 1095
    #41
    Re: Samsung 2253bw black screen
    So have you identified the Part Code ????
    • e3gsr
      • Aug 2012
      • 36
      • N Wales
      #42
      Originally posted by budm
      The 8-pin chips on the bottom side are Dual MOSFET's
      "244.6 ohms
      439.8k
      0.1 ohms
      5.4 ohms"
      Are these the resistance reading that I asked to check by leave one probe on any one of the pins on the right side of the chip (pins on the right are connected together) as shown in my redlined picture, then another probe on each pin top read the resistance? If that's the case, then you have bad chip (shorted).
      Can you read the numbers on them?
      yes that is correct i thought one may be faulty given them readings. cant make it out clearly but my wife said it looks to her like etstm 8309.if i disconnect and remove the shorted one should the other one then work?
      • Rtech
        • Jul 2010
        • 1095
        #43
        Probably, but need both to work to get the Monitor back on,Part Code is a new one on me, perhaps budm may have some idea //You could try finding something like it on the Alldatasheet webpage
          They are dual MOSFET's setup as bridge drive so you will need both chips, there should be more than one lines on the chip, you may have to wet it to read the numbers.
          • Rtech
            • Jul 2010
            • 1095
            #45
            Got them STM8309
            http://pdf1.alldatasheet.com/datashe...P/STM8309.html
              Great job ritech!
              He should replace both of them.
              See the typical setup fot this circuit.
              • Rtech
                • Jul 2010
                • 1095
                #47
                Looks like China stock them only based on UK Ebay, RS and Farnell do not.
                  That is strange since ST Micro is European company, I would think they will be easy to get.
                  • Rtech
                    • Jul 2010
                    • 1095
                    #49
                    Located in UK ;_
                    http://www.dalbani.co.uk/catalogue/p...s.php?id=35171
                    • selldoor
                      Slow Learner
                      • 7870
                      #50
                      I dont think the STM is ST Micro - datasheet says manufacturer is
                      Sam Hop Micro electronics corp
                      • Rtech
                        • Jul 2010
                        • 1095
                        #51
                        Post 49 identifies them as Sam Hop
                          I see, thanks.
                          • e3gsr
                            • Aug 2012
                            • 36
                            • N Wales
                            #53
                            wow you guys are awesome thank you very much for all your help so far. I will do a bit more work on this board and report back with the results.
                            Once again thank you very much for all your help you are all very kind.
                            • somem
                              • Greece
                              #54
                              Please, can anyone tell me the c301 and c302 are 1000μf or 820μf?, also the same about c112, c118, c113 and c108, thangs to all
                              • selldoor
                                Slow Learner
                                • 7870
                                #55
                                Can you post a good clear straight down picture of the board & mark where they are if it is not obvious.
                                (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                                Example of what is needed
                                https://www.badcaps.net/forum/attach...7&d=1280167246
                                • Sparks88
                                  • Sep 2011
                                  • 110
                                  #56
                                  I have brought up this thread because i have the same board but 2 secs to black, board recapped, mosfets all ok no shorts,all transformer solder joints reworked as well as a few others which looked suspect, i would like the schematic if at all possible my board is out of a 2233BW (LS22CMKKFV/EN), by the way there are 2 caps the wrong way round
                                  C113 and C116.
                                  • chstech
                                    • Jun 2013
                                    • scotland
                                    #57
                                    I have read these posts about the Samsung 2253bw and hope some one can assist.
                                    I have this monitor, and someone has started a repair - removed the caps, and I need to know which one is which for the locations shown as C301 & C302, C108, C113, C116, C112.
                                    • lexwalker
                                      • Feb 2011
                                      • 307
                                      • Malaysia
                                      #58
                                      What was the model and revision of that IP board? If its IP-49135B then these should be the usual values...
                                      For C301, C302, C108 & C112 => 820uF 25V 105C
                                      For C113 & C116 => 1000uF 16V
                                      Markings may vary for different versions of the same board model. Trace the rails, anything that goes to the inverter side, usually +13V or more, should be using 25Vdc rated capacitors. For the other rail, usually +5V one, should be 16Vdc rated capacitors...
                                      Generally for 820uF capacitors on the supply rail, I always never use the original values but rather replace them with 1000uF which have lower ESR, lasts longer (despite aging) and much cheaper (yes, believe it or not... those 1000uF are actually cheaper than 820uF ones!).
                                      • BigDaddyAdy
                                        • Jan 2014
                                        • 14
                                        • Romania
                                        #59
                                        Hello, I have this invertor board IP-49135B.
                                        At first, the monitor shut down suddently.
                                        After opening it I found 4 bad caps. After replacing all caps, still nothing. I checked U202, U203, both shortened. I replaced them and now the monitor displays image for 2 seconds, after that it goes dark again.
                                        It seems there is a problem with the OVP circuit.
                                        Can you please tell me the values for R241, R214 and C207?
                                        I have marked them on the image, in case i misread them.
                                        On my board R241 is showing overheat marks and i can't read it. I measured it and it looks like 330K, which i don't think is good.
                                        Also, c207 has a strange color, it looks more like an inductor then a cap, but on the board it is c207.
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #60
                                          Whilst the screen may be dark can you still see the image - it will be very dark and might just show if you shine a flashlight at different angles.
                                          • turmix
                                            AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                            by turmix
                                            Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                            The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                            At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                            During another reassembly, I made a mistake, and...
                                            01-29-2024, 03:48 AM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • totof
                                            Samsung UE50KU6070 black screen
                                            by totof
                                            I have my TV model UE50KU6070 which I am trying to repair.
                                            BN41-02528A / BN94-10800C motherboard.
                                            If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                            When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                            After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                            09-26-2022, 02:34 PM
