iiyama ProLite X486S dead - psu / inverter issue
+ More Options
Posts
  • kbs1
    • Feb 2012
    • 61
    #61
    Re: iiyama ProLite X486S dead - psu / inverter issue
    While I sort this out, I remember the readings (I was just verifying them when the fuse blew out), so here goes:
    CCFLs connected, logic board connected, LCD panel disconnected:
    2) What is the DC voltage for pin 3?
    standby - 14.95V
    monitor on - 16.92V
    3) What is the DC voltage for pin 7?
    standby - 12.04V
    monitor on - 13.36V
    4) What is the DC voltage for pin 5?
    standby - 1.04V
    monitor on - 1.05V
    Also, the monitor would randomly turn itself on (from standby) when I measured the chip. Also, I'm pretty sure that the high frequency noise coming from the board is made by IC901 (the one I measured).
    • kbs1
      • Feb 2012
      • 61
      #62
      Bought new F901, soldered, plugged in, instant burnout of the same fuse. What could be wrong?
      • kbs1
        • Feb 2012
        • 61
        #63
        well at least Q903 (big transistor near big capacitor) is nicely shorted.
        D-G 16ohms
        D-S 0ohms
        G-S 16ohms
        Also main Rubycon capacitor shows 1.5ohms (shorted), but I think it's the transistors fault (same leads and whatnot)
        Also DB901 shows shorted on pins 1-4 but again, it's the same PCB leads as the C905 is hooked onto.
        From your personal experience, which part is faulty? Is it the transistor? What does blow up most commonly first (other than the fuse)? When I look at it, IC901's pin 8 goes directly to Q903's gate, so when I shorted the pins, bad things could happen
        I know many people including me would advise to let it go and throw the monitor in trash, but I like to learn, and even though I've blown it this time, I still hope it is repairable.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #64
          Sorry i dont know but if you remove DB901 you can test it like this
          http://www.youtube.com/watch?v=dqkT6hF0O3E
          • kbs1
            • Feb 2012
            • 61
            #65
            Thanks that is a nice video. I will desolder the rectifier, main capacitor and main transistor tomorrow and try to test them.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #66
              Originally posted by kbs1
              Those IC901 contacts are so tiny, that it's really hard to control your hand like that ulness your are a surgeon
              Easy to be wise after the event but you dont always have to use the pins.
              It is sometimes easier to follow the trace out to the next component and use that as the test point.
              • kbs1
                • Feb 2012
                • 61
                #67
                Damn that's a really good idea Why couldn't I think of that sooner? Anyway three parts are about to be desoldered today and measured (maybe tomorrow if I'll run out of time). I'll let you know what I find
                • kbs1
                  • Feb 2012
                  • 61
                  #68
                  Desoldered Q903, shorted. No other parts show as shorted on the circuit at this time. Did not desolder anything else at this point. I'm going to replace the transistor. Do you think it's enough or should I desolder something else (like DB901) and test it out?
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #69
                    I'd desolder the DB901 and test it properly
                    • kbs1
                      • Feb 2012
                      • 61
                      #70
                      I'll do that, but first I need to get my hands on Q903 (totally shorted). It is not available in any local shops, they said they might have replacements for it but I did not have time to personally go to the mentioned shops recently (too much work & school). I'll try to visit the stores next week, and if I don't find any suitable replacement (or if the replacement will be expensive), I'll order a few pieces off ebay (2$ postage, 2 pieces - 4$, total 6$, approx 4.2€ - fine). I'm also planning to buy a new multimeter capable of testing capacitors and a new soldering gun - thin. I currently only own the standard old-fashioned soldering gun and it is hard to work on electronics with that one
                      By the way the part number is AP2761I-A and it is a N-CHANNEL ENHANCEMENT MODE POWER MOSFET.
                      • kbs1
                        • Feb 2012
                        • 61
                        #71
                        So guys, after a long research & parts availability checking I have replaced AP2761I-A with STP12NM50FP, and also of course replaced fuse F901. The monitor now "works", so it works like before - no backlight at all. I have also found & resoldered another two dry joints on the board, this time on the far side (the F902 side of the circiut) of T901 (big ?transformer?).
                        What should I check next? The IC901 voltages are correctly measured the last time I did it (before Q903 was shorted).
                        Thanks!
                        • kbs1
                          • Feb 2012
                          • 61
                          #72
                          As far as the "faint blue led" problem goes, the LED does not work at all now. Only the orange standby does. The voltage on BLUE led is 2.24V when ON, 0V when Off. Voltage on orange LED is 1.84V when Off (standby), 0V when ON.
                          Why is this voltage difference present? Is it because the led had burnt out? I don't care about the led, just wondering if it has something to do with the general backlight problem.
                          • kbs1
                            • Feb 2012
                            • 61
                            #73
                            Also, T901 is shorted on one side (the "f902" side). I traced the PCB leads and think that shown contacts are not connected by any direct PCB lead. They measure 0 ohms. The other side is always out of range even on 2000K multimeter setting. Also any other pin combination is also always out of range. Maybe this is normal, if not let me know
                            • kbs1
                              • Feb 2012
                              • 61
                              #74
                              What about this?
                              http://www.ebay.co.uk/itm/Replacemen...-/230363518011
                              Would I be able to test my lamps with this?
                              • kbs1
                                • Feb 2012
                                • 61
                                #75
                                Hello guys, sorry to revive an old topic, maybe I should establish a new one. But long story short, I've geared up in terms of equipment and some troubleshooting knowledge.
                                Gear:
                                + 20mhz oscilloscope
                                + much better soldering iron
                                + good LCR meter
                                Now using this and some great help on EEVBlog forum, we have finally checked all the
                                * diodes (good)
                                * caps (desoldered, checked, good, visually good)
                                * transistors (not shorted)
                                * mosfets (not shorted)
                                * no other obvious shorts / failures
                                The problem very much seems to be in main driver chip, IC201. Datasheet is posted in IC201.pdf.
                                Consequence of the problem: there is exactly 13.18V flat line DC on the input of inverter transformers. 13.18V is provided with no load from D902 (12V main diode) - input to the inverter section.
                                Possible cause of the problem: blown IC201 (mosfet driver). The IC should drive the mosfets with a saw tooth PWM wave from pins 11,12,19 and 20. The problem is, only pin19 shows any reading at all. Pins 11,12 and 20 are completely dead during normal operation (0 volts DC).
                                In standby, also pin19 has 0 volts, which is expected with backlight off. Main consequence of the problem: backlight does not work, never, at all.
                                Other measurements at IC201:
                                pin 1 = 0V
                                pin 2 = 0V
                                pin 4 (SST) = 4.63V
                                pin 5 (VDDA - Supply voltage) = 4.83V
                                pin 6 (GNDA - Signal ground) -> OK (continuity)
                                pin 7 (REF - Reference voltage output) = 3.30V
                                pin 14 (DIM) = 2.03V; 0.60V in standby
                                As far as I understand it, those measurements should indicate normal driver operation. However as described above, only one of P-mosfet drivers, pin 19, is working. "peak to peak" value of saw tooth wave on working pin19 output is ~4.3V. Other three driver outputs are dead.
                                Attached is:
                                * toshiba.pdf - monitor uses almost the same power supply, see page 30 for inverter schematic (applies to mine as well), and page 41 for troubleshooting instructions
                                * IC201.pdf - datasheet for suspected blown driver chip
                                * some random pictures - pictures of the board with helpful wiring diagrams for pair of eight mosfets that drive the inverter transformers (4 for each).
                                Now the question is, did someone ever witness an IC blow up partially like this? If the IC is not blown, what problem could cause only one driver output to work? Is there anything else I can check? I am going to buy CCFL extension connectors so that I can measure the chip with lamps connected, but in the meantime, I'll be glad for any input on the matter.
                                Thanks and please ignore previous topic messages, this is a fresh start
                                • mikey5791
                                  Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                  by mikey5791
                                  Got this working ips led monitor by the brand of
                                  Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                  Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                  09-04-2023, 03:50 AM
                                • double_DD
                                  How can I be sure that my EC chip is dead?
                                  by double_DD
                                  As the title suggests, how can I be sure that my EC chip is really dead?
                                  I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                  Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                  03-12-2025, 07:47 AM
                                • x_orange90_x
                                  Vizio E55-E1 bad backlights or bad inverter?
                                  by x_orange90_x
                                  I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                  I don't know how exactly to test the inverter itself. Is it...
                                  01-29-2025, 09:24 PM
                                • Gentian
                                  APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                  by Gentian
                                  I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                  It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                  03-06-2023, 07:07 AM
                                • valvashon
                                  Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                  by valvashon
                                  For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                  History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                  01-04-2024, 01:44 PM
