Hanns G HG216D flashing power button
  • sebtailor
    • 9
    Re: Hanns G HG216D flashing power button
    C805 measures exactly 313 V DC between the pins, with only the logic board connected, the screen itself is plugged of.
    I'm aware that the caps' installment isn't looking good, but it shouldn't make a difference now, should it? I'll try to improve that now anyway, since I have nothing better to do until you come up with another idea ;-)
    Thanks for everything so far.
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      1) What is the part number of the yellow and red circled components?
      2) Provide a URL datasheet for both.
      --- begin sig file ---
      --- end sig file ---
      • sebtailor
        • 9
        Red one:
        Designation: FQPF7N65C
        Type: 650 V N-Channel MOSFET
        Datasheet: alldatasheet.com
        Yellow one:
        Designation: LD7575PS
        Type: Green-Mode PWM Controller with High-Voltage Start-Up Circuit
        • selldoor
          Slow Learner
          • 7870
          #44
          Originally posted by selldoor
          I have been reading the previous thread. and two measurements you could do
          are the one to the Jumper L803 and also the measurements on the voltage regulator at I104 and also state the part number of that.
          Hi - think you may have missed this bit.- Voltages at L803 power supply and on the regulator I104 which is on the main board.
          • sebtailor
            • 9
            Didn't miss it, the values are the same as the ones of the original poster. I measured them again on my board anyway:
            L803 has 26.6 V
            I104: pin 1: 0V, pin 2: 3.29 V, pin 3: 4.75 V, which should be within tolerance of that part.
            • terry
              • Oct 2007
              • 91
              • Milton Keynes, Bucks
              #46
              Not sure if is going to help, I have one HG216D and ten HC174D all with the flashing power button. They all have the same problem "eeprom is corrupt".
              I have tryed to get the eeprom of a good one with no luck.
                "When I disconnected the logic-board from the power-board, I got an all white screen."
                It sounds like the main power supply is OK since the backlights do come on.
                • Rik8119
                  Hi guys,
                  i had the same Monitor with the exact same Problem. i test everything over and over. All bigger Caps were complete well, no shorts in any component, exchanged the 1084-33 and the eeprom I108. Finally i give in and disassembled the hole screen. In the end i have seen one of the neon tubes for background ligh was broken. Scince i dont know if it was broken before disassembly or during and there is no way to put it back together im out for this screen. But maybe this post can help anyone, could this be the reason why the screen is not switching on?
                  Greets Rik8119
                  • selldoor
                    Slow Learner
                    • 7870
                    #49
                    Rik8119
                    If you have one bulb you could continue testing the boards by using one of budm's test bulbs made from a cfl.
                    https://www.badcaps.net/forum/showth...ght=test+lamps.
                    If you decide to throw it out - perhaps give it away on freecycle
                    http://de.groups.yahoo.com/group/freecycle-bonn/
                    • infinity
                      • Feb 2013
                      • tunis
                      #50
                      salut tt les monde je recherche les tension de sorti de cette allimentaion é merci
                      • lachlaan
                        • Feb 2013
                        • Italy
                        #51
                        And here comes a little bit of necroing. I've got the same monitor, Hanns G HG216D, with more or less the same problem. When I plug it in you can hear a high pitch sound coming from the power board, between the filter cap and the transformer. If I hit the turn on button, it blinks with more or less the same pattern , producing a few clicks, followed by a high pitched sound, and then rinse and repeat. All the while the tension on the on/off switch goes from 3-4v to 0 and back up. The screen tries to light up, blinks white for a half a second then goes black again, with each loop of the led blinking. The voltage accross the large filter cap is as in sebtailor's case 325v DC. I checked the pins of the power connector to the main board, and all of them had the right voltage. The on/off pin displayed the same voltage bounce I read on the actual switch/button, and the 24v pin displayed 0V. Also the same as in sparks' case, if i detach the main board from the power board the backlight comes on. If you guys need more details I'll be glad to provide them, as well as photos.
                        • selldoor
                          Slow Learner
                          • 7870
                          #52
                          We have not had much success with these -please post 4 good clear pics of the front and back of each board -good light but no flash
                          pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                          Examples of what is needed
                          https://www.badcaps.net/forum/attach...7&d=1280167246
                          https://www.badcaps.net/forum/attach...6&d=1280167246
                          https://www.badcaps.net/forum/attach...4&d=1280167246
                          • lachlaan
                            • Feb 2013
                            • Italy
                            #53
                            Alright, after many attempts I've managed to get somewhat clear images of the boards, front and back. Not so much the connectors, but I'll see about adding info on those tomorrow morning. If need be I also have a service manual PDF I could attach.
                            Power board front
Name:	powerboard front.jpg
                            Power board back
                            Main board front
Name:	mainboard front.jpg
                            Main board back
                            • graymon76321
                              • Mar 2014
                              • phillippines
                              #54
                              it is true or not cause the pin1,3,4 and pin2,5,6 is the same line? please answer cause i have hanns-g same model here and same problem. i want to know the true output cause i want to try to use other power supply w/ the same output. thanks
                              pin 1 no dc volts but 3.6v ac
                              pin 2 2.9v dc
                              pin 3 low voltage pulsing in time with front power led about .8v dc
                              pin 4 5v dc
                              pin 5 5v dc
                              pin 6 0v
                              pin 7 0v
                              pin 8 5v dc
                              pin 9 0v
                              • mikrodev
                                • Nov 2013
                                • Spain
                                #55
                                Hi, I've got two identical HannsG monitors like this, one of them has this same problem. Boards look exactly like the ones already posted, no sign of anything damaged.
                                @graymon76321: I think your readings are ok, check them with the service manual here.
                                Both monitors were making that buzzing sound previously described, I resoldered C805, L805 and DS-3319. Great improvement, nearly silent now.
                                Tried the working power source with the broken control board; same result, blue led blinking.
                                I suspect the problem lies near Q107 in control board, voltages there are
                                B 2.62v C 2.49v E 3.26v for the working one and B 2.44 C 3.25 E 3.26 for the other.
                                Replaced caps near there, no change. Hope this helps
                                Dån
                                • mikrodev
                                  • Nov 2013
                                  • Spain
                                  #56
                                  Fixed it
                                  The problem is in the main board, not the power board. The D124 diode reads 1100 with the diode tester (while still soldered to circuit). Should be around half that value.
                                  D124 is a 1A 100V rectifier (service manual says it should be a GS1B, but it is an M2). I replaced it with an M4 (1A, 400V) from a really broken board from another device. And... IT WORKS NOW!
                                  I also replaced nearby caps while trying to repair the board, so it is possible that C124 was also damaged (however, I think it was not).
                                  If anyone has a HANSS-G monitor with this problem, this should help.
                                  Dån
                                  • graymon62321
                                    • Apr 2017
                                    • Philippines
                                    #57
                                    Hi, I have monitor like this I just want to ask what is the value of big cap c805? Thank you
                                    • valentin32
                                      • Mar 2016
                                      • 4
                                      • Украина
                                      #58
                                      Hello, same problem with the flashing LED with this HANSS-G monitor, Q107 in the control board, the voltage is E-3.26 B and the C-voltage "jumps" is not stable, what's the reason? Thanks
                                      • valentin32
                                        • Mar 2016
                                        • 4
                                        • Украина
                                        #59
                                        So thanks to you mikrodev, replaced D124, VOLTAGE ON LINE 1.8 STABILIZED, MONITOR ON "GORIT" BLUE INDICATOR, PRESSED ON BUTTON ON "BURNING" 6 SECONDS AND 1 TIME IN 1 SECOND "DOES NOT COME" WHERE TO "KAPAT"? THANK YOU
                                        • valentin32
                                          • Mar 2016
                                          • 4
                                          • Украина
                                          #60
                                          Kind time of day of the state experts, please I ask you tell me how to check the monitor's monitor for performance? Or a link to read, I have the signal RST # on the processor 0, the amateur himself, not professional.hobby electronics, thank you for your understanding
                                          • themosttogain
                                            HP Envy 13-BA1565na with intermittent power button
                                            by themosttogain
                                            Hope someone can give me some suggestions on this because i'm at my wits end with it...
                                            I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                                            Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                                            07-12-2024, 03:03 AM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • dj-bobr
                                            Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
                                            by dj-bobr
                                            I kindly ask for help with Thinkpad BIOS/ME repair.
                                            Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
                                            It worked fine until I tried to remove whitelist.
                                            Steps taken:
                                            - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
                                            - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
                                            03-05-2024, 04:28 AM
                                          • reessi
                                            Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                                            by reessi
                                            With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                                            No corrosion any where!
                                            Tried a replacement power button off ebay and the same.
                                            Very occasionally it will work with the power button connected!
                                            Same results with or without the battery.
                                            Can it be a fault with the Audio board or the mainboard?
                                            The touch Id assembly connects through the Audio board first then to the Mainboard.
                                            Flex...
                                            06-26-2024, 03:31 PM
