ONkyo TX-NR626 Check SP Wire
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this receiver with this fault showing for like two seconds and shuts off.
    I have found the bad final transistors at channel SBL and bad 0.22Ohm resistor, so I have cut there terminal and the receiver turned on.
    Now I'm looking at bad components and I have found a transistor on the pre-amp section with these markings and I don't know which transistor would this be?
    FR 15.
    I'm attaching some pictures.
    I can't find schematics for this receiver.
    Any help would be appreciated.
    • 30940
    Re: ONkyo TX-NR626 Check SP Wire
    probably 2sa1037
    • tibimakai
      • Jan 2012
      • 3680
      How did you get to that conclusion?
      I would like to find out myself, how to read this little devices.
      It looks like the F is 2SA1037 with hFE 180-390 which is R.
        Is there another one on the board with the same P/N? Check to see if good one it is PNP type.
          • 30940
          "Turuta SMD Databook 2011"
          magnet:?xt=urn:btih:aafe741e4cb4286833c31356f7fdbfa5cb965ec5&dn=SMD+databook+turuta+2011&tr=udp%3A%2F%2Ftracker.openbittorrent.com%3A80&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80&tr=udp%3A%2F%2Ftracker.istole.it%3A6969&tr=udp%3A%2F%2Fopen.demonii.com%3A1337
            http://www.turuta.md/
            Nice site STI.
              • 30940
              yea, but the magnet link is free.
              • tibimakai
                • Jan 2012
                • 3680
                Re: Onkyo TX-NR626 Check SP Wire
                I don't understand, what is that magnet?
                  • 30940
                  download this.
                  http://deluge-torrent.org/
                  once it's installed,
                  copy the block begining with "magnet" into it.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    You are pretty certain that the 2SA1037 is that transistor?
                    I would like to place the order this morning.
                    I'm not in front of the receiver, to test it if it's NPN or PNP.
                    I don't know where to place that magnet in that software(magnet has to be in it, or just the rest). I have never used this kind of stuff before.
                      It is just general purpose PNP (60V 0.15A, if it is PNP), then you can use through hole PNP that you may have around to try it out first.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Thanks Bud, but I have to buy other blown components, so I will just buy it and see, if it will work.
                          • 30940
                          you need to copy all of this block:
                          magnet:?xt=urn:btih:aafe741e4cb4286833c31356f7fdbf a5cb965ec5&dn=SMD+databook+turuta+2011&tr=udp%3A%2 F%2Ftracker.openbittorrent.com%3A80&tr=udp%3A%2F%2 Ftracker.publicbt.com%3A80&tr=udp%3A%2F%2Ftracker. istole.it%3A6969&tr=udp%3A%2F%2Fopen.demonii.com%3 A1337
                          • tibimakai
                            • Jan 2012
                            • 3680
                            That sounds good.
                            Where should I paste it?
                            • Shinju
                              • Mar 2014
                              • 1239
                              I have this amp for my main TH set up, its great!
                              When you get her up and running MAKE SURE TO UPDATE FW!
                              There is a FW defect that the HDMI controller looses handshake and causes black screen and the only way to fix it is to reset the unit and update the FW.
                              That's the only issue I have had with it, other then that is a bad ass amp with loads of options and great sound.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Thanks for the heads up.
                                I also have a 515 and 616, one in my living room and the other in the bed room.
                                515 will have to go when this one it will work.
                                I will switch the fan connector, to the empty one(I still have to check on this), to run it all the time, when is on. I don't want to heat up to much.
                                I did the same thing on the 616.
                                The 515, I have purchased refurbished, I have not looked into it, but I believe that there is no fan in there. I have made a power only, USB cable and I have plugged it into my TV and I'm using a laptop cooler with adjustable fan control(Target $14), to set the fan at a speed level, that is not bothering me.
                                • CapLeaker
                                  Leaking Member
                                  • 8000
                                  Google "smd codes pdf"
                                  There are a few to download from including one from Digikey and the THE SMD CODEBOOK.
                                    http://www.s-manuals.com/smd
                                    • artois7
                                      • Mar 2011
                                      • 159
                                      Are you sure that component is faulty? Never seen one go wrong the whole time I've been repairing them. The only thing it tends to take out (on a 626) is the output transistors, the 0.22ohm resistor and then the occasional surface mount cap for that channel.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        There are two capacitors bulged(10uf and 220uf), 120 and 2.2ohm resistors, show a weir value also.
                                        That transitor is completely shorted. The other one next to it it's fine.
                                        • rddube
                                          Help with blowing transistor NAD T752 receiver
                                          by rddube
                                          I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                                          Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                                          I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                                          09-01-2022, 05:19 AM
                                        • ai.need.help
                                          Onkyo TX-8050 AV-Receiver no sound
                                          by ai.need.help
                                          I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                                          It doesn't play music. There is no real output from:
                                          pre-out
                                          amp-out A and B
                                          phones out
                                          The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                                          I tested with analog-input, usb and radio.
                                          I know that there is a common problem with...
                                          12-20-2022, 05:54 PM
                                        • ShotwellCoho
                                          Onkyo TX-NR363 Check SP Wire
                                          by ShotwellCoho
                                          Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
                                          I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
                                          However I have so far been unsuccessful - here is what i have done
                                          Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
                                          Put everything...
                                          08-27-2021, 07:39 PM
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
