ONkyo TX-NR626 Check SP Wire
    • 31191
    Re: ONkyo TX-NR626 Check SP Wire
    did you work out how to use Deluge yet?
    • tibimakai
      • Jan 2012
      • 3680
      No. It wouldn't work with utorent?
      • artois7
        • Mar 2011
        • 159
        Originally posted by tibimakai
        There are two capacitors bulged(10uf and 220uf), 120 and 2.2ohm resistors, show a weir value also.
        That transitor is completely shorted. The other one next to it it's fine.
        Is that tested out of circuit or in? The caps are in parallel IIRC. I have no access to a service manual right now but I will try and get one.
        • tibimakai
          • Jan 2012
          • 3680
          I have tested it out of the circuit and it's bad. 30 ohms and 101 ohms.
            • 31191
            go to "add torrent"
            then click "url" and past it into the address box
            • tibimakai
              • Jan 2012
              • 3680
              Nothing happens.
              I have tried uTorrent too and it can't parse the link.
              That link it's complete?
              Back to the receiver, it works!!!!
              How to adjust the bias?
              There are two pin test points, close to the final transistors and each channel has an adjustable resistor, on the pre amp board.
              I believe, that these receivers fail with this error, because some final transistor are not tightened properly. I mean, I could tighten a half a turn on some screws.
              Anybody has a good source of 0.22 ohm/5W dual resistor?
              I have only 3W one.
                • 31191
                isolate the power to the amp circuit and put a current meter inline.
                then ground the input and ajust for minimum current.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Got it, thanks.
                    You can measure the Voltage drop on the 0.22 Ohm Emitter resistor which will represent the current draw through the power transistor.
                    Do you know what the bias current should be? Just multiply the 0.22 Ohm with the bias current to get the voltage drop on the resistor.
                    I.E. 50mA bias current = 0.22 x 50mA = 11mV.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I don't know, because I don't have a SM.
                      I have measured the same voltage at those two pins, compared to other channels, 0.006V.
                        Are you saying you are reading 0.006V across 0.22 Ohm?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          At that dual pin test point. It's like PC fan connector.
                            Then I have no idea what those two pins are connected to and if they are for bias adjustment or not, but you do have have another channels that have the same 0.22 Ohms resistors for the power amp section, you can take the voltage reading and see what you get compared to the one channel that you just repaired, typical bias current for the output transistor is between 30~60mA range, it is set to give minimum crossover distortion but too much bias will cause transistor to get hot, such as the one with Class A amplifier.
                            • R_J
                              • Jun 2012
                              • 9588
                              It may not apply here but some of these Onkyo Receivers can be repaired no charge under Onkyo's Special Service Program http://www.onkyousa.com/Support/ Check your model/serial to see if it qualifies.
                              08/19/2014 Loss of Audio/Network Connection Customer Care Program
                              • tibimakai
                                • Jan 2012
                                • 3680
                                This one, it was in protect mode, so it doesn't apply.
                                In my opinion this type of defect should be included as well in a recall.
                                To me, it seems like some final transistors are not properly tightened down and they eventually will fail.
                                • artois7
                                  • Mar 2011
                                  • 159
                                  #36
                                  Across the two test points, (white plastic base with two pins sticking up) Onkyo specification calls for 9mv per FL FR and C channels and 6mv across all others.
                                  As I said, I haven't got the service manual to hand to prove it but that is the correct specification.
                                  Cut off an old fan connector and glue it to the end of a biro pen, run the wires out of the other end and splice them into some banana plugs for your meter. Nice, cheap adapter!
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Thanks, so it seems like what I'm measuring it's fine, no adjustment needed.
                                    I have purchased the 0.22 ohm resistors, from Ebay.
                                    • artois7
                                      • Mar 2011
                                      • 159
                                      #38
                                      At 0.006V yes that's fine - Sorry I've just scrolled up and read the rest of your posts since.
                                      On these 626s, often replacing the 0.22 ohm resistor will lead to a monstrously high quiescent current on that one channel as it usually takes out some of the resistor network I mentioned previously. Keep an adapter on it as you power it on and be prepared to pull the plug if it starts to ramp.
                                      I will try and get you the proper information for the above for before your 0.22 replacements arrive. I'm no longer working for the Onkyo warranty centre so don't have immediate access to the service manuals (if I'd seen this a week ago there'd have been no problem..!)
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I don't know anything about that quiescent current, or what to do about it.
                                        I'm not an expert.
                                        I have already turned it on with a 3W resistor and it's working.
                                        The pre-amp section, seems quite hot.
                                        I have transferred the fan's plug to the empty one, to run constantly. I have done it, on my other 616 also.
                                        • artois7
                                          • Mar 2011
                                          • 159
                                          #40
                                          Quiescent current = the 6mV reading you took from the test points..! (before anyone jumps in and says the current can't be taken in mV and that it doesn't make sense; this is word for word from the service manual!)
                                          The Pre-Amp section does run hot, mind, but you shouldn't be able to feel anything more than mild warmth if you put your hand on the top of the heatsink. Worth running through and checking each channel is in spec after 6-8 minutes of power-on time (no inputs or outputs connected).
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
                                          • rddube
                                            Help with blowing transistor NAD T752 receiver
                                            by rddube
                                            I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                                            Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                                            I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                                            09-01-2022, 05:19 AM
                                          • ai.need.help
                                            Onkyo TX-8050 AV-Receiver no sound
                                            by ai.need.help
                                            I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                                            It doesn't play music. There is no real output from:
                                            pre-out
                                            amp-out A and B
                                            phones out
                                            The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                                            I tested with analog-input, usb and radio.
                                            I know that there is a common problem with...
                                            12-20-2022, 05:54 PM
                                          • ShotwellCoho
                                            Onkyo TX-NR363 Check SP Wire
                                            by ShotwellCoho
                                            Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
                                            I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
                                            However I have so far been unsuccessful - here is what i have done
                                            Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
                                            Put everything...
                                            08-27-2021, 07:39 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
