ONkyo TX-NR626 Check SP Wire
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this receiver with this fault showing for like two seconds and shuts off.
    I have found the bad final transistors at channel SBL and bad 0.22Ohm resistor, so I have cut there terminal and the receiver turned on.
    Now I'm looking at bad components and I have found a transistor on the pre-amp section with these markings and I don't know which transistor would this be?
    FR 15.
    I'm attaching some pictures.
    I can't find schematics for this receiver.
    Any help would be appreciated.
    • 31305
    Re: ONkyo TX-NR626 Check SP Wire
    probably 2sa1037
    • tibimakai
      • Jan 2012
      • 3680
      How did you get to that conclusion?
      I would like to find out myself, how to read this little devices.
      It looks like the F is 2SA1037 with hFE 180-390 which is R.
        Is there another one on the board with the same P/N? Check to see if good one it is PNP type.
          • 31305
          "Turuta SMD Databook 2011"
          magnet:?xt=urn:btih:aafe741e4cb4286833c31356f7fdbfa5cb965ec5&dn=SMD+databook+turuta+2011&tr=udp%3A%2F%2Ftracker.openbittorrent.com%3A80&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80&tr=udp%3A%2F%2Ftracker.istole.it%3A6969&tr=udp%3A%2F%2Fopen.demonii.com%3A1337
            http://www.turuta.md/
            Nice site STI.
              • 31305
              yea, but the magnet link is free.
              • tibimakai
                • Jan 2012
                • 3680
                Re: Onkyo TX-NR626 Check SP Wire
                I don't understand, what is that magnet?
                  • 31305
                  download this.
                  http://deluge-torrent.org/
                  once it's installed,
                  copy the block begining with "magnet" into it.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    You are pretty certain that the 2SA1037 is that transistor?
                    I would like to place the order this morning.
                    I'm not in front of the receiver, to test it if it's NPN or PNP.
                    I don't know where to place that magnet in that software(magnet has to be in it, or just the rest). I have never used this kind of stuff before.
                      It is just general purpose PNP (60V 0.15A, if it is PNP), then you can use through hole PNP that you may have around to try it out first.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Thanks Bud, but I have to buy other blown components, so I will just buy it and see, if it will work.
                          • 31305
                          you need to copy all of this block:
                          magnet:?xt=urn:btih:aafe741e4cb4286833c31356f7fdbf a5cb965ec5&dn=SMD+databook+turuta+2011&tr=udp%3A%2 F%2Ftracker.openbittorrent.com%3A80&tr=udp%3A%2F%2 Ftracker.publicbt.com%3A80&tr=udp%3A%2F%2Ftracker. istole.it%3A6969&tr=udp%3A%2F%2Fopen.demonii.com%3 A1337
                          • tibimakai
                            • Jan 2012
                            • 3680
                            That sounds good.
                            Where should I paste it?
                            • Shinju
                              • Mar 2014
                              • 1239
                              I have this amp for my main TH set up, its great!
                              When you get her up and running MAKE SURE TO UPDATE FW!
                              There is a FW defect that the HDMI controller looses handshake and causes black screen and the only way to fix it is to reset the unit and update the FW.
                              That's the only issue I have had with it, other then that is a bad ass amp with loads of options and great sound.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Thanks for the heads up.
                                I also have a 515 and 616, one in my living room and the other in the bed room.
                                515 will have to go when this one it will work.
                                I will switch the fan connector, to the empty one(I still have to check on this), to run it all the time, when is on. I don't want to heat up to much.
                                I did the same thing on the 616.
                                The 515, I have purchased refurbished, I have not looked into it, but I believe that there is no fan in there. I have made a power only, USB cable and I have plugged it into my TV and I'm using a laptop cooler with adjustable fan control(Target $14), to set the fan at a speed level, that is not bothering me.
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8352
                                  Google "smd codes pdf"
                                  There are a few to download from including one from Digikey and the THE SMD CODEBOOK.
                                    http://www.s-manuals.com/smd
                                    • artois7
                                      • Mar 2011
                                      • 159
                                      Are you sure that component is faulty? Never seen one go wrong the whole time I've been repairing them. The only thing it tends to take out (on a 626) is the output transistors, the 0.22ohm resistor and then the occasional surface mount cap for that channel.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        There are two capacitors bulged(10uf and 220uf), 120 and 2.2ohm resistors, show a weir value also.
                                        That transitor is completely shorted. The other one next to it it's fine.
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                        • rddube
                                          Help with blowing transistor NAD T752 receiver
                                          by rddube
                                          I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                                          Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                                          I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                                          09-01-2022, 05:19 AM
                                        • ai.need.help
                                          Onkyo TX-8050 AV-Receiver no sound
                                          by ai.need.help
                                          I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                                          It doesn't play music. There is no real output from:
                                          pre-out
                                          amp-out A and B
                                          phones out
                                          The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                                          I tested with analog-input, usb and radio.
                                          I know that there is a common problem with...
                                          12-20-2022, 05:54 PM
                                        • ShotwellCoho
                                          Onkyo TX-NR363 Check SP Wire
                                          by ShotwellCoho
                                          Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
                                          I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
                                          However I have so far been unsuccessful - here is what i have done
                                          Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
                                          Put everything...
                                          08-27-2021, 07:39 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
