ONkyo TX-NR626 Check SP Wire
  • RJARRRPCGP
    • Jul 2004
    • 6301
    Re: ONkyo TX-NR626 Check SP Wire
    Originally posted by jworthin
    The heat sink gets so hot (135F) you cannot leave your finger on it.
    More like 160F! If you can't leave a finger on it.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    "Β‘Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MΓ­ mismo
    • rddube
      Help with blowing transistor NAD T752 receiver
      by rddube
      I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
      Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
      I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
      09-01-2022, 05:19 AM
    • ai.need.help
      Onkyo TX-8050 AV-Receiver no sound
      by ai.need.help
      I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
      It doesn't play music. There is no real output from:
      pre-out
      amp-out A and B
      phones out
      The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
      I tested with analog-input, usb and radio.
      I know that there is a common problem with...
      12-20-2022, 05:54 PM
    • ShotwellCoho
      Onkyo TX-NR363 Check SP Wire
      by ShotwellCoho
      Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
      I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
      However I have so far been unsuccessful - here is what i have done
      Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
      Put everything...
      08-27-2021, 07:39 PM
    • wnlewis
      New wire for my RDE3340 Whirlpool electric range
      by wnlewis
      OK. I got the rocker switch figured out thanks to the good advice on this forum.
      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
      This is a Whirlpool RDE3340 electric range.
      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
      Where may I find parts...
      01-08-2025, 11:21 PM
    • emeskay
      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
      by emeskay
      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
      08-06-2024, 07:13 AM
