ONkyo TX-NR626 Check SP Wire
  • jworthin
    • Feb 2017
    • 33
    Re: ONkyo TX-NR626 Check SP Wire
    I replaced all transistors and all electrolytics in the R driver. I have triple checked the SMD and discrete resistors as well.
    Idle voltages stay within service manual tolerances even as it heats up!
    The voltages across the plus and minus sides of the driver match the L and C channels.
    I have even tried reducing all channel idle voltages to 1mv and it still overheats and drops the B voltages in half (you can hear the drop-down voltage relay click in). How can the power transistors get so hot when the idle voltages/currents are so low??
    When the B voltages drop in half the unit temp drops to room temp (75F) in a couple minutes.
    The heat sink gets so hot (135F) you cannot leave your finger on it. And this is with no input, no volume, and no speaker load.
    Thanks.
    • tibimakai
      • Jan 2012
      • 3680
      Every channel is that hot, or only the R.
      The 626, has a fan?
      If I remember correctly, at 60C the fan should kick in.
      You are using a 100 Ohm resistor on each lead, when measuring the idle current?
      I have never replaced all the capacitors, usually only one is blowing, or none.
      • mmartell
        • Oct 2013
        • 3189
        Did you check the main board resistors near the final transistors as well ? There are at least two there known to go open, one being the dual package emitter resistor.
        • jworthin
          • Feb 2017
          • 33
          tibimakai:
          All channels were hot.
          The unit did not arrive with a fan but researching further looks like this model should have one. I have ordered a replacement.
          I did not have the 100 Ohms resistors installed correctly. Fixing them and resetting the idle current seems to have fixed the overheating and voltage drop back. Thanks!
          Could overheating cause the shorting of power transistors before the immediate thermal protect shutdown could protect the unit at 100F?
          mmartell:
          I checked the two base 0.22 Ohm resistors and the 5W ceramic double 0.22 Ohm resistor.
          • tibimakai
            • Jan 2012
            • 3680
            You are talking about, the 100 Ohm resistors, in the measuring leads?
            I'm not familiar, with that voltage drop thing. Why would that happen at all?
            The receiver did not show any message, that is in protection mode?
            If it was overheating, it should have shown something.
            mmartell, was referring to other resistors as well.
            • jworthin
              • Feb 2017
              • 33
              Yes, I incorrectly connected the resistors in the measuring leads.
              The schematic shows the drop-down relays are MPU controlled by SEC1H on pin 128. This appears to switch between the +-S1L and +-S1H voltages. It certainly let the amplifier cool down when it switched low. I could hear the click but there was no change in the display. The first time I 'fixed' it, it died after 4 hrs resulting in a reported VPROT fault. (from overheating???)
              Warning: I'm strictly an amateur here so I could easily be mistaken about anything I report.
              Again, thanks for your help. It is greatly appreciated.
              • jworthin
                • Feb 2017
                • 33
                In the 626 diagnostics menu there is a "confirmation of output sensor and thermal sensor" test. It reports the voltage of the VOLH port, the temp sensor, fan speed, and the amplifier power supply voltage condition (High-B or Low-B). The implication is the Low-B may be used for overtemp situations.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I know, there is a way to check the receiver's temperature, with a combination of button presses.
                  Per artois7. on page #3:
                  "From memory, I think if you hold down display and the power button, release display and press the tone button, you should get an internal temperature reading. My 609 reads around 23 degrees on first power on and will idle somewhere mid 30s-40s ish (and it's got no ventilation around it..!)"
                  • jworthin
                    • Feb 2017
                    • 33
                    Temperature and output voltage can be confirmed the following operation when the unit is powered on.
                    [DISPLAY] + [ON/STANDBY] * 2 → [TONE]
                    e.g. 001 042 F:x S:H
                    Displayed Fields:
                    (001)Voltage of VOLH port,
                    (042)Temperature of thermal sensor,
                    (x)FAN speed (x: Stop, L: Low speed H: High speed),
                    (H)Amplifier power Supply voltage condition (H : High-B L : Low-B)
                    • jworthin
                      • Feb 2017
                      • 33
                      My fan order on eBay fell through (seller lost the part). Anybody have a Onkyo TX-NR626 or 616 fan for sale? KF1225B1E-33ACD54RB or 4710KL-04W-B10-EA2. Thanks.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        If you want to keep this receiver and not resell it, I would suggest to get a 120mm PC fan and mount it to the top case from inside.
                        When I had these older receivers, I have used a laptop cooler's internals, fan and fan controller. I have ran the USB cable to the TV. When the TV it was on, the fan it was on.
                        I have adjusted the fan controller to a speed, that the fan noisy did not bother me.
                        • jworthin
                          • Feb 2017
                          • 33
                          Found another fan assembly from an eBay seller by contacting everybody that is selling or has sold any NR626 parts. No need to reply to my previous post. Thanks.
                          • jworthin
                            • Feb 2017
                            • 33
                            Replacing the fan fixed the overheating nicely but the unit still failed (VPROT) after threes days running 6-8 hours a day. Failed parts are: Q6051, R6081, Q6061, and R6091 the R channel power transistors and their 0.22 ohm base resistors.
                            On the driver board R channel: R5351, R5471, Q5461 and Q5411 failed.
                            Service manual link:
                            Any suggestions would be greatly appreciated.
                            • jworthin
                              • Feb 2017
                              • 33
                              I bought a working NR626 and swapped driver boards to try to solve this problem. The old driver board in the working NR626 works fine but the working driver board in the old chassis blew the same R channel components. With no input nor volume this second unit combination has 354mv on the R amp output (before it eventually blows). It also has 254mv voltage difference on the differential pair bases for the R channel while the L channel has only 8mv on the differential pair bases. It also drops to the low B voltages after about an hour.
                              I'm assuming the swap test points to the motherboard amp section. I believe I have double checked all those R channel components at least twice.
                              Please help...
                              • tibimakai
                                • Jan 2012
                                • 3680
                                The only thing I can say is, that you have missed some bad component(s).
                                There is no point, in buying other boards. You still have to find the bad part.
                                • jworthin
                                  • Feb 2017
                                  • 33
                                  I was hoping the point of the other boards was to eliminate the driver board components as possible suspects, thereby narrowing the search for the bad part(s).
                                  • jworthin
                                    • Feb 2017
                                    • 33
                                    Update: After repairing the R channel several times I finally cut the PCB trace from the power transistor emitter resistors to the output relay and replaced it with a wire and the unit no longer blows the channel. Maybe when the receiver warmed up the PCB trace somehow shorted to ground. There were no obvious signs of a short though.
                                    • redwire
                                      • Dec 2010
                                      • 3900
                                      Onkyo driver boards are super easy to solder bridge. Close spacing, lead-free solder and teardrop pads. Then the heat from some transistors turns the PCB brown. It's just really fragile, pads and traces lift off easily.
                                      I spend 1/2 an hour under a microscope checking each channel for poor connections or bridges.
                                      • jworthin
                                        • Feb 2017
                                        • 33
                                        The thing that keep perplexing me was every time I fixed it, it would work fine for a few hours or even a few days and then blow the channel.
                                        • redwire
                                          • Dec 2010
                                          • 3900
                                          Not much has a few days time-constant, aside from a bad connection or a damaged (but not dead) transistor.
                                          The amp might go into thermal runaway, where once it gets hot, the idle current keeps going up (=gets hotter) until it roasts the output transistors. So I would suspect the three transistor VBE multiplier (one on power amp, two on driver board) may not be working properly.
                                          Don't forget Q6001/R6232/R6021, temperature sense on the heatsink. If it goes lazy or open you will lose the bias multiplier and it would wreck the o/p transistors. The resistors (trimpot) nearby might be worth checking. If Q5411 died then an overload could work its way back to Q6001- although the resistors should smoke first. You can always compare readings with other channels.
                                          My experience with the Onkyo TX-NR636 is the idle current tracking is not so great, it's very low when the amp is cold and I can hear a little cross-over distortion. After 10 minutes that goes away and the amp settles into the right idle current.
                                          It's supposed to be the other way around - as temperature goes up, bias goes down. The design is not the best IMHO.
                                          • rddube
                                            Help with blowing transistor NAD T752 receiver
                                            by rddube
                                            I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                                            Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                                            I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                                            09-01-2022, 05:19 AM
                                          • ai.need.help
                                            Onkyo TX-8050 AV-Receiver no sound
                                            by ai.need.help
                                            I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                                            It doesn't play music. There is no real output from:
                                            pre-out
                                            amp-out A and B
                                            phones out
                                            The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                                            I tested with analog-input, usb and radio.
                                            I know that there is a common problem with...
                                            12-20-2022, 05:54 PM
                                          • ShotwellCoho
                                            Onkyo TX-NR363 Check SP Wire
                                            by ShotwellCoho
                                            Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
                                            I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
                                            However I have so far been unsuccessful - here is what i have done
                                            Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
                                            Put everything...
                                            08-27-2021, 07:39 PM
                                          • wnlewis
                                            New wire for my RDE3340 Whirlpool electric range
                                            by wnlewis
                                            OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                            Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                            This is a Whirlpool RDE3340 electric range.
                                            The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                            Where may I find parts...
                                            01-08-2025, 11:21 PM
                                          • emeskay
                                            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                            by emeskay
                                            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                            08-06-2024, 07:13 AM
