Onkyo TX-NR363 Check SP Wire
+ More Options
Posts
  • ShotwellCoho
    • Aug 2021
    • NZ
    Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
    I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
    However I have so far been unsuccessful - here is what i have done
    Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
    Put everything back together, it blew the channel again.
    So, desoldered the main transistors for the right channel, plan was to start the amp, see that the Check SP wire goes away...it didn't, further more C5441 on the vertical board was still smoking with the main transistors out of the circuit.
    Remove C5441 and attached fly leads to read what voltage it is getting, reads ~110v....
    Hope someone can help me out here, I have run out of ideas/talent...
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • Francesc V.
    Onkyo A8200 - Not the right voltages in some transistors
    by Francesc V.
    Hi:
    I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
    With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
    Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
    Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
    I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
    04-19-2025, 07:17 AM
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • Bogdan Kolybaba
    Dell AC adapter - 1 wire protocol. How to initiate to check if adapter works.
    by Bogdan Kolybaba
    Hi all. Trying to troubleshoot issues with the Dell Laptop power supply (a lot of info here). Now I am waiting for a DC power Jack, as there is a loose contact. Want to check if the ID line of the adapter works - I have given abt 3.2 V to this line through the voltage divider, but can't see any signal on the oscilloscope. Same with the 100500% working AC adapter as well. How to initiate 1-Wire protocol transmission? As I understand, the circuit in the AC adapter should send a package for a while as soon as the supply comes to the SPID line. How to initiate this transmission correctly without...
    02-20-2024, 07:41 PM
  • spleenharvester
    Reverse engineering of 18650 4-channel tester
    by spleenharvester
    Hi friends
    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
    05-04-2025, 02:43 AM
