Vintage SONY Digital Clock Radio ICF-C12W no audio
  • CapLeaker
    Leaking Member
    • 8147
    Now figure out:
    A: Is the faulty unit drawing so much current that the voltage drops that much on the transformer
    B: Is the transformer delivering proper voltage?
    • UserXP
      • Apr 2012
      • 348
      • Serbia
      Yes, the power transformer in the faulty unit outputs dual ~6 volt. It is a center tap PT and measures 5.9 and 6.1 volts, giving 11.9-12 volts total. This is almost identical in the working unit, differences are maybe 0.1 volts up or down.
      Which part would you want me to check about the current, what to probe in series with the multimeter?
        • 31015
        do you get the 15v and 30v from the power rectifier circuit?
        • UserXP
          • Apr 2012
          • 348
          • Serbia
          No, I only get 2.56v and 7.56v after recification.
            • 31015
            double-check none of the new caps are in backwards
            • UserXP
              • Apr 2012
              • 348
              • Serbia
              #26
              Already done that. I visually checked each cap. Also, I took pictures of the top of the board with the old and with the new caps and compared the two. All negative stripes are oriented the same way in both images.
                • 31015
                try isolating the power circuit from each section and see if the voltages return to normal
                • UserXP
                  • Apr 2012
                  • 348
                  • Serbia
                  #28
                  I will attempt that. I am awaiting the original Sony ICF-C12W service manual. I have the C12L version. Although the function board is the same, I noticed there is a slight difference in the components layout where the power supply connects to the main board. Maybe C12W has slighly different voltages to check against. The manual should tell. I don't know what else to try, all the caps are properly soldered and in their right place, all the components I removed (diodes and a few ceramic capacitors) check out OK, but the power is still low. I only haven't checked the transistors, though the power and heat in tose sections are so low I couldn't imagine how they may have become blown or something.
                    • 31015
                    it sounds like something is pulling too much power - probably a diode or ceramic cap
                    • UserXP
                      • Apr 2012
                      • 348
                      • Serbia
                      #30
                      I did some additional measurements. I measured voltages on the transistors Q4, Q5, Q6 and Q7 (in volts). The C12L manual I currently have has two models covered: UK (with FM, MW and LW bands), and AEP (only FM and AM bands, like mine).
                      Q4 voltages:
                      E = 0.00
                      B = 0.62
                      C = 3.07
                      Q5 voltages:
                      E = 3.67
                      B = 4.27
                      C = 7.44
                      Voltages here are also less than in the manual.
                      Q6 voltages:
                      E = 3.67 (manual suggests 6.8)
                      B = 3.06 (manual suggests 6.2)
                      ​​​​​C = 0.00
                      Something appears to be drpping the voltage here by 3.2V.
                      Q7 voltages:
                      E = -0.18
                      B = 0.64
                      ​​​​​​​C = 0.00
                      • UserXP
                        • Apr 2012
                        • 348
                        • Serbia
                        #31
                        Update: I removed both 1N4001 diodes from the board and they both passed the test, 0.590V in bias, 0.L. reading in reverse, which indicates they are OK. I then tested D4, which is a VD1220, it measured 1.2V in both ways with reversed probes, which I also think is normal for this old type of diode. The two 5.1V (1S1555) zener diodes also tested OK. I then removed a small 1nF capacitor which was in paralel with D2. It also passed the testing. I powered on the board without it and the power was still the same.
                        Then I disconnected the flat ribbon cable - and only got around 0.6V on outputs where 2.56 and 7.56 used to be with the ribbon cable connected.
                        i also noticed that, when increasing the volume quickly, it hits a random place on its pot where the sound completely mutes for a second or so with a slight "pop" sound from the speaker. It stays like that for a second and then the sound reappears with the same slight pop sound. It is as if when increasing the volume fast the circuit experienced a lack of already low voltage, insufficient to momentarilly increase the volume but needs that little time to "recharge" to continue.
                        I am at a loss what else to try. Something is draining the voltage, nothing gets hot. In some areas the voltage should be around 13.5 to 14V, yet only 7.5 is there. If the radio is off from the AC power for a while, that voltage turns on at around 6.9-7.1V upon plugging AC back in, and as it stays on, it increases to 7.5 and just stays there.
                        Any ideas what else to try? I can't really understand the rectification circuit on this board if it is dependent on the small function board and which section. Please guide me with detailed steps so I can follow. Thanks in advance, guys.
                        • CapLeaker
                          Leaking Member
                          • 8147
                          A VD1221 (D4) is another component you wanna replace on sight, these destroy things downstream when they fail. Measuring 1.2V forward and reverse? I don’t think that’s good. Should only go one way, not the other. Replace it with two x 2N4148 soldered in series to get the 1.2V drop.
                          If I look at Q6 (AM RX) there are different voltages on the schematic than you say there should be. Are we taking the same component?
                          • UserXP
                            • Apr 2012
                            • 348
                            • Serbia
                            #33
                            Thank you for writing. OK, I can remove and replace D4, it is VD1220. Will two 1n4148 diodes in series work? Also, after connecting in series, I still obey the "-" (stripe) end on the diode and solder it to the "-" end on the PCB?
                            Is there a "one component replacement" for this VD1220 type of diode?
                            End-to-end or back-to-back connection?
                            Regarding the voltages, I measured those and labeled them according to the B, E an C markings on the PCB. The schematics I have is for model ICF-C12L, so the layout of the transistors is silghtly different than on my PCB, but almost everything of the AEP model section in that service manual matches what I have here.
                            • UserXP
                              • Apr 2012
                              • 348
                              • Serbia
                              #34
                              Update: I desoldered VD1220 and measured it then. It gives 1.16V one way, and 0.L. reading the other way. According to the specs, the voltage for these old diodes is 1.2 volts. So this old diode appears to be working within specs?
                              But when soldered onto the board, it measures 1.2V in diode mode on both ends (depending on the probes orientation, it just displays + or - 1.2v on the multimeter).
                              • mikey5791
                                Sony CFS-5000S radio cassette player no FM reception
                                by mikey5791
                                Hi forum members,
                                In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                                Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                                I opened the casing inside and checked for any dry solder, burned component or loose wires...
                                02-24-2023, 03:48 AM
                              • shelby5041
                                clock radio / radio lifespan?
                                by shelby5041
                                hi
                                ive got a modern digital clock radio approx 15yrs old
                                my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                it uses very little power just a few watts i would imagine that may have something...
                                09-14-2024, 03:30 AM
                              • UserXP
                                Sony ICF-C12W Radio Clock schematics (power)
                                by UserXP
                                Hello, good people. Hope you are all doing fine.
                                As the title says, I have a question about this Sony Dream Machine clock radio model ICF-C12W from the 80s. I,ve recently come into possession of it, but it is intended for 110-120V input, not 220-240V power rating which is used where I live.
                                I have this idea of replacing its inner transformer with the one that operates on 220-240V mains. I have opened the housing, there are no ratings on the current transformer. On its output side there are three wires coming out and going to the PCB. One is black, the other two are red. I...
                                11-30-2021, 11:10 AM
                              • BOSCHNJAK
                                by BOSCHNJAK
                                ABOUT ME INTRODUCTION FILE
                                2
                                024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                2022 BEV, PROJECT ?
                                2021 BEV, PROJECT ?
                                2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                12-28-2023, 02:09 PM
                              • littlejohn
                                Emerson clock radio transformer
                                by littlejohn
                                Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
                                08-30-2023, 07:13 PM
