Directly replacing NiMh cells with Li-Ion cells - bad idea ?
    • Jul 2011
    • 6062
    Re: Directly replacing NiMh cells with Li-Ion cells - bad idea ?
    Just wait when something go wrong they will be looking for someone to blame
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #62
      I don't think he'd stoop so low as to blame ME who's clearly never touched the thing. There's CCTV in the room as well, so I only worry about HIM
      Wattevah...
        Hopefully it does not burn down your work place.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          #64
          There's a fire alarm in there
          Wattevah...
            • 31183
            so it burns down with lots of noise??
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #66
              I shall find out on Monday
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #67
                Ok guys update: so my brilliant co-worker, who is a genius (he is ! a ge-ge-ge-ge-genius ) came back to this vac which he set aside for a few days and is still trying to hack the charger portion, which is probably a good idea at its roots, but not as easy to pull off with such a complex circuit in practice.
                According to him, he discovered the batteries are being overcharged to 20v or something and that's what kills them....which is true - LiIons certainly don't take to overvolting as kindly as say SLAs do, so it's plausible, but adapting a circuit designed for NiMhs to charge LiIons is tough or maybe impossible IMO (and might be called a complete waste of time in the long run)...
                Wattevah...
                  • Jul 2011
                  • 6062
                  Not really if you take out the charging controller board that is in there now and replace it with a battery charger controller board that is made for the type of battery that you want to use you can find them on eBay
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    #69
                    Yeah, but he's trying to do it "as is" with what's already in there, that's the catch
                    Wattevah...
                      • 31183
                      we call that the "tight ass" method here.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        #71
                        UPDATE: here's the IC at last: a MC9s08sh8, so it's like a "computer" in there, making the job even harder, since it's likely going to do "UVLO" if he tries to modify just the incoming adapter voltage in an attempt to decrease the charge voltage, or sense any number of different things. "Charge voltage" is a bit of a misnomer in this case, since it's not the sole factor - CURRENT is just as important of course...
                        Wattevah...
                          • Jul 2011
                          • 6062
                          Boy did you say a mouthful
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            #73
                            Ditto
                            Wattevah...
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              #74
                              UPDATE: the solution ? Tell the client to simply not to leave it plugged in for charging more than 6 hours
                              Wattevah...
                                • 31183
                                so a question:
                                if the old fuck was willing to buy new pink-fire li-ions, why the fuck didnt he go to ikea and buy a pack of ni-mh's
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  #76
                                  Well LiIon always sounds better than NiMih, doesn't it ?
                                  "Pink-fire"....I see what you did there
                                  Wattevah...
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    #77
                                    Man, this thread is too funny!
                                    Glad you're sharing this story ("repair"?) with us, Danny.
                                    so a question:
                                    LOL. Probably because it makes too much sense.
                                    A fairly easy alternative method would have also been to rip out the charging circuit and build a simple LM317 voltage reg circuit and put a resistor to the Li-Ion cells for current limit, so that the reg circuit doesn't burn out when the batts are low and charging.
                                    This "solution" of course still wouldn't address the batteries from over-discharging. But with a few MOSFETs/transistors, Zeners, and possibly a 358 op-amp, you could design a very crude shut-off circuit. But I imagine all of that is way over your "pal's" head.
                                    Come to think of it, he should have just put a long cord on the vacuum and wired the motor straight to AC. Then tell the customer, when you want to use it, just plug it in.
                                    Come to think of it, this is what a "technician" at a repair shop I worked at before did to some PS3 fans. He thought that since the PS3 fans are 12V and the AC line is 120V in the US, they would just run "10 times as fast".
                                    The result can be seen in this thread, where I actually managed to repair his mess.
                                    https://www.badcaps.net/forum/showth...ht=playstation
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      #78
                                      Odyssey more like
                                      Glad you're having fun. I sure am (I'm such an ass, aren't I ?). Just yesterday he rummaged through the box of wall-warts hoping to find one of lower voltage to try and replace the 20v 200mA the vac comes with...don't know what he was hoping that would achieve, since I'm willing to bet that chip would just "UVLO" and would tell that inferior charger to f-off....he couldn't find one, so he abandoned the idea (thankfully ?). He's still fixated on the idea the batteries overcharge, but there's definitely more to it than that....current consumption, overdischarge, temperature...OMG. While it MIGHT just be possible the circuit DOES protect against overdischarge by cutting out the motor and probably blinking an LED or something, it's threshold is probably not "tuned" for LiIons...
                                      Now about the circuit: it's actually not possible to "remove" the charge circuit by ITSELF, at least not with extensive mods, since the "system control" is part of that board I pictured in the handle and it's required for speed control, on/off and other functions. It's got a 1-button, 3-speed setting on it, as well as control for the roller brushes, so all those would be lost along with the board unless you have a lot of time on your hands to emulate those functions again.
                                      It's about to get even funnier since he's not done with it yet, so I'm REALLY curious to see where all of this is going and how it shall end. That's another thing about this guy: he takes on 20+ different projects, starts work on several of them simultaneously, completes none, sets them aside, comes back to them after days/months/years(!), eventually completes (or half-asses) some of them and hands them back AFTER said time period. No joke: just a couple of days ago he returned some doohickey that's sat in the shop for 3 years ! 3 ! (Actually it was I who eventually fixed it, but NVM >_>) Big surprise: the chap on the phone had no idea who we were and what that device was - took a few minutes to reenact the whole story to him. Needless to say by that point he had purchased a replacement for said device....so now he has a backup At least props to "Mr. Knowitall" for being persistent, what can I say...
                                      Wattevah...
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        #79
                                        Pfftt...it got even better: just yesterday I was strolling through a mall and found the Li-Ion version of this Electrolux ErgoRapido, exactly the same vac on the outside, for almost the same price that was invested in the job my buddy is trying to achieve - I lost a bit of sh!t there No joke, I did the math: 2 sets of batteries, plus labour so far ended up costing the guy the same exact price as the Li Ion version off the shelf ! It's not even funny anymore !
                                        On a side-note, I'm actually thinking of getting that one for myself as a smaller, more portable and ready to go alternative to my main Karcher vac I use around the house. I'd keep it round the kitchen to suck up crumbs and junk off the floor as well as to tidy up my car a bit every now and then. It's a good thing I had it round the shop, even in this semi-functional form, because it enabled me to assess its suction power, which is certainly not going to be on-par with a canister or mains powered vac, but still satisfactory for the aforementioned endeavors.....dat vocabulary tho
                                        Wattevah...
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          Yeah it's unfortunate that messing with li-ion cells by themselves can cost more than replacement cost, unless you get a good deal on the cells.
                                          I don't know what I want to do with my handheld. Currently I just use my power supply to power it if I need to use it. Better to have a cord than to leave the mess on the floor...
                                          • AlexVG
                                            Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                            by AlexVG
                                            I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                            I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                            (This board does not respond, only the LEDs light up in a circle.
                                            The liquid damage is catastrophic and restoration is impractical).
                                            (I bought this board to get the WiFi module and camera).
                                            The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                            If...
                                            10-22-2024, 07:20 AM
                                          • Chaks
                                            The ups takes 3 x 18650 cells in Parallel - Can I extend to 6 x 18650 safely?
                                            by Chaks
                                            I need help to extend the runtime of the ups board (see attached image).
                                            This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
                                            Thanks and kind regards,
                                            chaksindia...
                                            01-21-2025, 11:39 AM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
                                          • Petr0x
                                            Bosch 12V and 18V chargers modification
                                            by Petr0x
                                            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                            05-24-2024, 01:00 PM
                                            ZD-915 vacuum pump motor mount service alert
                                            by sam_sam_sam
                                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                            09-19-2021, 02:15 AM
