Directly replacing NiMh cells with Li-Ion cells - bad idea ?
    • 31200
    Re: Directly replacing NiMh cells with Li-Ion cells - bad idea ?
    chinese SZN's
    nothing wrong with SZN's, but the asshole i got these from had soldered to them and damaged a couple of the insulator rings.
    so i was suspecting problems from the start!
    out of 6, i'm down to 3 - just testing.
    2 had case damage, one tried to go thermonuclear.
    the other 3 charged o.k. - now i wait a few days to see if they hold.
    if they do then i'll do a discharge test to check capacity.
    i'm not confident though - i think they guy fucked them when he soldered to them.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      #42
      Originally posted by stj
      i suspect this is the type of repair shop that would re-use the solder if they could.
      But then they can advertise they are an Eco/Earth-friendly shop.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Then there's the irony of reusing lead solder for being eco-friendly :o
        Sigh. I wish it were easy to make all the waste solder I have back into wire, I sure would reuse this solder for noncritical uses... solder is solder, just need flux!
          • 31200
          you can put it in a solder-pot for tinning wires.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            #45
            Just purchased new cells for my colleague...even higher capacity, even higher price...this is going well - at this rate he'll get fired These are pink "Unicell"...cells with a rating of 4200mAh apparently - that's what the chap at the store told me.
            The vac says 14.4v on it, so we can work this out: 4 3.7v cells would indeed add up to 14.8v.
            Wattevah...
              • 31200
              you dont have a Liitokala Lii-500-Engineer there do you?
              you should if using lion batteries, they cost under 20€
              then you could analyse them, because you know damned well the highest capacity yet acheived is 3600mAh
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #47
                Pfft...the joint barely has enough light fixtures Ancient fluorescent sh!ts that buzz my brains out the whole 9 hours continuously (! !) so a device like that would be completely superfluous and would only see use just this once probably...if that Though I'll probably get one myself, why not - good idea
                Wattevah...
                  • 31200
                  they are very handy.
                  https://lygte-info.dk/review/Review%...-500%20UK.html
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    #49
                    Wa-wait - what's that I hear behind me ? It's the sound of the vac trying to come back to life with the new cells but not charging...followed by my super skilled colleague's obligatory "f-s" and *insert whatever curse word you can think of here*
                    So once again, it appears to run, but the LED on the dock doesn't light to indicate it's charging....could be because the higher voltage of such cells indicates the unit doesn't require charging...there's 4 terminals on the back of the handheld portion, so GND, VCC, NTC (?) and SENSE (?)...just a hunch...
                    I just about heard him mutter "15v" when measuring the voltage on the batteries, because that's another thing that's really "cute" about this guy: he mutters all his thoughts, so you can follow along at your desk and go head to head in fixing something - not very good at keeping secrets Aaanyway
                    Wattevah...
                      • 31200
                      maybe the charger is fucked from last time.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        #51
                        I snapped some pics of the thing today. Here's the batteries I got this time that my boy put in and also a close-up of the IC that's in there...had to do it rather on the sly so unfortunately the model is not visible, but the point is it HAS some pretty advanced tech in there. It probably handles charging and motor speed control. It's an Electrolux ErgoRapid or something like that, forgot to mention for anyone who might be interested...at least that's what it says on the outer case - I don't know the exact model because I didn't bother.
                        The green Samsung cell is what he attempted to use the first time when it failed.
                        I actually got it wrong: the charge circuit is built into the handheld part, as you can see, but the LED I was talking about is at the top of the handle which you use for converting it into an upright vac for the floor. This whole apparatus then slips into a dock which does nothing but connect the wall adapter to the handheld portion which has the 4 metal shims I mentioned and handles the charging internally. The LED on the handle now comes on as well when docked...apparently, according to him, someone had been inside before they brought it back in and they had messed up some wires or something along those lines. Either way, it looks like the problem's solved - at least partially...we'll see how long it lasts this time.
                        Wattevah...
                          So the charging Voltage for 4 cells is about 16V, is that the charger putting out? He should also monitor the charging current.
                          https://batteryuniversity.com/learn/..._with_voltages
                            • 31200
                            that chip looks like a charge controller - there is no way in hell it will touch those cells!!
                            the green cells arent bad - lets not speak about the ultra(fire) ones!
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #54
                              Originally posted by Dannyx
                              Either way, it looks like the problem's solved - at least partially...we'll see how long until it catches fire and burns down the customer's house.
                              FIFY!
                              BTW, I just saw it in the news today... a second person here in the US died from those vape pens / e-cigs. Apparently battery exploded and shrapnel cut an artery in his neck. Not that anything like that might happen with this vacuum cleaner, as the customer won't be wearing it in their pocket or have it near their face. But still, it goes to show that Lithium batteries can be dangerous if not designed to charge/discharge properly or are of poor quality.
                              ... because that's another thing that's really "cute" about this guy: he mutters all his thoughts, so you can follow along at your desk and go head to head in fixing something
                              I think that's an age-related thing. My grandmother often does it too.
                              Heck, even I've done it a few times if I didn't talk to anyone for an entire week.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                #55
                                Best case scenario, the controller will just shut off or act in some way to prevent catastrophic failure...
                                Wattevah...
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  #56
                                  The wall adapter puts out 20v at 200mA. I just had a peek for curiosity's sake and I also heard him saying the pack reached around 16v or thereabouts and the LED was still on and apparently charging - probably in "trickle charge" specific to NiMhs....not sure if LiIons like to be trickle-charged. I've read they're topped up to full capacity (let's assume 100%), then the charge is cut off entirely and they're only topped up as necessary (let's say when they fall back to 90% or less), while NiMhs are kept on the charger even when full, at least based on some online resources and I imagine this may vary with charger design. This one looks pretty smart...
                                  Wattevah...
                                    • 31200
                                    too bad we cant see the number on the chip.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      #58
                                      Should I seize another opportunity to sneak a peek at it, I'll post back undoubtedly.
                                      Wattevah...
                                        • Jul 2011
                                        • 6066
                                        Why are you playing with fire
                                        Just put in a BSM board for the right battery voltage and right type of battery and use right type of charger
                                        And be done with it and be safe about it
                                        I think you like to play with fire
                                        • Dannyx
                                          CertifiedAxhole
                                          • Aug 2016
                                          • 3912
                                          • Romania
                                          #60
                                          It's not my project since I know this stuff fairly well. Tell that to my super stubborn workmate and see what happens
                                          Wattevah...
                                          • AlexVG
                                            Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                            by AlexVG
                                            I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                            I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                            (This board does not respond, only the LEDs light up in a circle.
                                            The liquid damage is catastrophic and restoration is impractical).
                                            (I bought this board to get the WiFi module and camera).
                                            The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                            If...
                                            10-22-2024, 07:20 AM
                                          • Chaks
                                            The ups takes 3 x 18650 cells in Parallel - Can I extend to 6 x 18650 safely?
                                            by Chaks
                                            I need help to extend the runtime of the ups board (see attached image).
                                            This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
                                            Thanks and kind regards,
                                            chaksindia...
                                            01-21-2025, 11:39 AM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
                                          • Petr0x
                                            Bosch 12V and 18V chargers modification
                                            by Petr0x
                                            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                            05-24-2024, 01:00 PM
                                            ZD-915 vacuum pump motor mount service alert
                                            by sam_sam_sam
                                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                            09-19-2021, 02:15 AM
