What is a mechanical solder sucker?
  • johnnyh55
    • Oct 2015
    • 44
    I read the steps to replace capacitors and the step 2 of the equipment needed found here:
    https://www.badcaps.net/index.php?pageid=overview
    says to not use a mechanical solder sucker, they can damage the board. I was planning on using a vacuum one like this
    Is that ok? If it is, what exactly is a mechanical solder sucker, can anyone link to a picture of one?
    • 30985
    Re: What is a mechanical solder sucker?
    that's one type of "mechanical solder sucker", the other is a plastic ball.
    read this.
    https://www.badcaps.net/forum/showthread.php?t=34998
    • SteveNielsen
      Retired Tech
      • 2327
      I'm not sure but I think the warning about using a squeeze-ball or spring-loaded sucker is that operation of it causes movement (how ever slight) of the sucker and in the hands of an inexperienced person can cause the soldering iron to move or bounce on the board, potentially damaging traces nearby. That said, I've used the spring-loaded for years but I can't say that I like them. I'd much rather have a continuous vacuum pump.
      Another thing I'm not sure about is the recommendation that a 40W soldering pencil with fine tip will work. On a 6 layer board? Yeah, it might eventually but where caps are soldered to the ground plane traces you're gonna be heating it up for a really long time.
      • johnnyh55
        • Oct 2015
        • 44
        Well I was planning on using a solder sucker from radio shack to replace motherboard caps, do you guys think it will suffice? I did invest a in hakko fx-888d soldering station, I was hoping the solder sucker would be a minimal investment.
          • 30985
          shack still exists?
          • johnnyh55
            • Oct 2015
            • 44
            Not quite, I refer to it as radio shack but in Canada the stores were bought out by Circuit City and were then called The Source by Circuit City and when they went bankrupt, BCE(Bell Canada) bought the stores and they are now called The Source. But they're still referred to as radio shack by many.
            • SteveNielsen
              Retired Tech
              • 2327
              I can't afford a constant vacuum desoldering device either (although I am trying to make one, still in experimental stages), so I use a spring loaded solder sucker. It doesn't always work that well and has to be cleared frequently but I can't say using it has ever caused any direct harm to me or what I was working on.
              • diif
                • Feb 2014
                • 6978
                • England
                I've never damaged a trace either using mine (the end is a softish plastic) although they do annoyingly crap bits of dried solder into your board occasionally to remind you to clean them.
                  • 30985
                  i recomend you use an airhorn pump and an electronic relay as the basis.
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    I just use a straw.
                    sigpicThe Sky Is Falling
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      I worked for a radio/electronic shop back in `75. The boss used an old canister vacuum cleaner duct-taped up to an automotive neoprene vacuum hose as a solder sucker. When it clogged up he'd cut the hose back.
                      I have a direct coupled electric motor piston pump I am trying to adapt. It is a nebulizer pump I have connected to the intake port a tube adapted to the body and tip of an old mechanical sucker and it works (very loudly) but I've got some leaks and it's a little clumsy.
                        • 30985
                        weller DS80 used a pump very similar to an airhorn,
                        very fast to get 1Bar negative!
                        that's the other thing, fit a vac guage on a T piece so you can see how your pump is performing and spot blockages.
                        • SteveNielsen
                          Retired Tech
                          • 2327
                          I've look at vac gauges online too.
                          • johnnyh55
                            • Oct 2015
                            • 44
                            Well I was able to remove 4 capacitors but I was only able to get one hole completely cleared from the solder. I have tried using a piston type solder sucker and solder wick to no avail. I also had to add a little bit of solder to get the caps removed but some overflowed and are now touching the metal lines beside it. What would be the easiest way to clean those up? I am using 1.2mm solder, maybe that's too big?
                            Also any ideas how I can clear the solder from the remaining holes, I don't have a dentist pick on hand. I am using the chisel tip on my hakko fx-888d maybe I should be using a conical tip? Here are some pics of what I have done so far
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Maybe you haven't got your iron hot enough ?
                              I use a chisel tip and mechanical pump. I add a little solder, heat the hole then slide the iron to the rim so the hole is exposed with the molten solder in. I get the pump in tight to the iron and click the pump, this should clear the hole.
                              • johnnyh55
                                • Oct 2015
                                • 44
                                I have the iron set at 842 degrees Fahrenheit, is that hot enough?
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  That seems too high, i have my cheapo iron set to 400c, turn it down and hold it on until the solder melts. Maybe practice on some scrap boards. It took me a little while to get my soldering right.
                                  • ChaosLegionnaire
                                    HC Overclocker
                                    • Jul 2012
                                    • 3264
                                    • Singapore
                                    i use a safety pin instead of a dentist pick that is the same thickness as the hole. have a few safety pins of differing thickness for different sized holes. never seen the solder adhering to the safety pin. it must be made of stainless steel too.
                                    never ripped out a via or trace after fully recapping three boards. (that means i've cleared over a hundred holes with the safety pin) never burnt myself either holding the safety pin to clear the hole. if the pin gets too hot, it means u are overheating the board with the iron!
                                    • johnnyh55
                                      • Oct 2015
                                      • 44
                                      Oh, I was following the recommended temperature listed here:
                                      https://www.badcaps.net/index.php?pageid=cap_removal
                                      Good idea, I never though of using a safety pin. When I was removing the capacitor I was feeling it getting hot in my hand, was I overheating the board?
                                      • johnnyh55
                                        • Oct 2015
                                        • 44
                                        Also what size solder should I be using? And can I use the very end of the tip of the iron to solder or you have to use the side? It's kind of awkward to use the side with a chisel tip on something small, maybe I would need to use a conical tip?
                                        Another thing I noticed is when I melt the solder in the hole with the iron, the solder comes up and follows the tip, as soon as I remove the tip the solder is already too solid to suck it up with the solder sucker.
                                        • corrize
                                          Best way to solder LVDS connector for beginner (and qfn) ?
                                          by corrize
                                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                          See the test :
                                          https://youtu.be/bNAzC-EvqHs?t=1767
                                          With hot air from bellow the board, that's...
                                          03-09-2023, 02:57 AM
                                        • myth77
                                          UV solder mask - high temp resistent, recomendation?
                                          by myth77
                                          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                          Is there any solder mask...
                                          03-28-2022, 04:04 AM
                                        • petemanuk
                                          BGA solder balls not connecting - help pls
                                          by petemanuk
                                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                          11-16-2022, 05:21 AM
                                        • flat-earther
                                          Hoover FM216LI cordless vacuum refuses to charge
                                          by flat-earther
                                          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                          06-06-2025, 03:14 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
