Preemptively Recap Motherboard?
  • Uniballer
    • Jul 2013
    • 334
    An ASUS M2N68-AM PLUS motherboard is being used to manage environmental controls in a range of greenhouses. It's a pretty good board for that purpose because it has a parallel (printer) port, serial port, PCI and PCIe slots, gigabit ethernet, can use unbuffered ECC RAM, etc.
    The caps for the CPU VRM are polymers, but there are UCC KZG caps on the board. None appear to be bulging and leaking, and the board seems to work fine at this time. Should I preemptively recap the KZG's? Or leave it alone unless it starts misbehaving? I have a blue ESR meter, and a DE-5000 LCR meter, but feel that if I have to pull the caps to test them then I might as well just replace them. What do you think?
  • mockingbird
    • Dec 2008
    • 5484
    Re: Preemptively Recap Motherboard?
    I would worry more about the fact that it uses a known defective nVidia chipset...
    If I were you I would look for an alternative. M2A/M3A series boards are far more reliable because they use the AMD chipset. Regarding unbuffered ECC ram, do you mean that you specifically require a board that supports ECC capability? I ask this because if you must use unbuffered ECC modules because that's all you have, all boards should accept those modules, even the ones that don't have the ECC capability.
    • Uniballer
      • Jul 2013
      • 334
      ...Regarding unbuffered ECC ram, do you mean that you specifically require a board that supports ECC capability?
      Yes, for stuff that runs 24/7 (e.g. environmental controls, telephone PBX) I use ECC RAM and expect it to actually correct single bit errors and hopefully never have to report double bit errors. Some of the board manufacturers do not support ECC even though the chipsets do.
      Tell me more about the chipset problems. I have put four of these boards into service for various people and haven't heard of any problems, but they all run cool. Are the problems heat related? Or something else? I read that there were problems with the Nvidia 65nm and 55nm designs, but I believe that the parts on this board are 110nm. More information would be appreciated.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        I think it's a good rule of thumb to always replace KZG the second you see them. They often go bad without symptoms. If it hasn't seen a ton of use, I'd recap it, and reapply thermal paste to the chipset at least, look for a bigger heatsink for it if you can.
        And always remember that Asus PCB's make it look like the caps are installed backwards, so always check and double check polarity when recapping
        • mockingbird
          • Dec 2008
          • 5484
          Ok, but I should first point out that eventhough the CPU is made by AMD, there were two chipsets during that time that were used, nVidia and AMD. And that is what I mean by M2A and M2N. Boards with the 'n' in it have the nVidia Northbridge.
          There were a few problems with their manufacture... Firstly, nVidia was undergoing a stage of managerialism and decided to cut costs by firing engineers. This resulted in a chip that was designed in a way that it could not radiate heat out properly. Secondly, they used the wrong metals to make contact between the substrate and the die. Thirdly, they used the wrong underfill.
          Don't worry about it then, but keep it in mind for the future if you ever have to replace them. I agree with Pentium4 that you should in fact preemptviely re-cap them. Regarding which generation are affected, it is anything after nForce4 (Socket939), so your generation is definitely affected.
          Having said that, keep in mind that YMMV. I have an HP mini PC with a minature motherboard that uses a chip from that generation and AFAIK it has been running flawlessly for years (After I re-capped the MB and PSU). OTOH, I was once called upon to inspect a bunch of computers of identical spec that invariably suffered from random crashes because of it. They were all scrap as far as I was concerned.
          • Uniballer
            • Jul 2013
            • 334
            OK. I will recap 'em as time allows.
            I don't know how much it matters but the board is used as a headless controller. Users talk to it with a web browser. The onboard video is in text mode, and not doing anything much. I assume this greatly reduces the chipset heat output, and probably nobody would notice if the video output failed as long as everything else kept working. The parallel port is cabled to an OPTO-22 PB16H board to control discrete outputs. There are additional serial ports installed to communicate with remote sensors and control modules via 1-Wire.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              sounds as if it has a rather easy life.it might live a long time that way or puke its nb and caps tomorrow.caps are easy.nb,mcp not worth it.
              • Uniballer
                • Jul 2013
                • 334
                Agreed.
                Aside from the 820uF 6.3V KZGs and the polymers there are only Panasonic 100uF 16V CMHs, and one Panasonic 470uF 16V FJS. I assume that I can leave the Panasonic caps alone.
                Would you say Nichicon HNs to replace the KZGs (polymers would be twice the price)? Or is there a better value?
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  You can leave the Panny's. And 820uF 6.3V nichicon HN are a perfect replacement, they have slightly lower ESR and a little more ripple current
                  • c_hegge
                    • Sep 2009
                    • 5219
                    It's thermal cycles that kill the chipsets usually. If it sees 24/7 use, it's only going through 1 thermal cycle in its life, and it will probably have a long life.
                    • Uniballer
                      • Jul 2013
                      • 334
                      The first board went fine, except I couldn't get the soldapullt in deep enough between the PCI slots. I had to heat up the vias and push the cap in a little at a time. That took longer than I was comfortable with heating the pads but nothing broke.
                      • Uniballer
                        • Jul 2013
                        • 334
                        The second board I looked at was loaded with Panasonic FJS caps instead of the UCC KZGs, so I didn't mess with it. There's no visible flux or anything on the board so it's either a really professional grade recap or (more likely) FJSs from the factory.
                        • Uniballer
                          • Jul 2013
                          • 334
                          The third board is full of KZGs, so I stuck in a spare board I had already recapped and I'll recap the one I pulled out before checking the fourth.
                          • Uniballer
                            • Jul 2013
                            • 334
                            I bought a couple more boards on ebay for another headless controller application. Both of these boards have TK 6.3V 820uF 105 degree C caps. They also say ATWY 024A. Are these any good? Or should they be replaced, too? I still have plenty of the Nichicon HN caps.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              TK is even worse than KZG IMO. I've seen that many of them fail after 2 or 3 years on boards which have only had light use that I always replace them.
                              • mockingbird
                                • Dec 2008
                                • 5484
                                Hey Uniballer,
                                Are the $6 Chinese knock-off Soldapullt as good as the $20+ ones? Or are the $20+ ones just the $6 Chinese ones with brands on them?
                                BTW, I sold that M2A-VM I picked up in the trash a while back. It replaced an HP-Branded M2N with a defective chipset. The M2A-VM had a visibly damaged internal USB header (open SMD fuse and burnt ceramic cap), but that wasn't a problem because I didn't need all the internal USB headers. What irritated me though was that one of the memory slots was dead, so I couldn't make use of dual-channel mode.
                                For that I knocked the price down for the replacement from $75 to $60 (I re-capped that M2N the client had before for a steeply discounted price beforehand, and also tinkered with the PSU, so I felt $75 was reasonable), and I also upped them to a dual-core Athlon and more RAM to sweeten the deal.
                                $60 for picking it up on the curb and a little work.
                                  • 31137
                                  what's a "Soldapullt" ??
                                  if you mean a pump,
                                  i have a weller pro-desold that costs about $25,
                                  i'v seen *exactly* the same pump at DX for about $5 and a better built one for about 50c more.
                                    • 31137
                                    o.k. - found it.
                                    those are dangerous - you can get hit by the plunger.
                                    if you dont mind that, DX has those too - a friend has one.
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      I've been looking at the ss-02 for desoldering, i like the idea of the silicone at the end to get really close to the job.
                                      http://www.amazon.co.uk/innovative-s...ds=desoldering
                                      • Uniballer
                                        • Jul 2013
                                        • 334
                                        I don't know. I can't remember actually using anything but the Soldapullt pumps since around 1983. I did pick up an OK Industries pump for 1$ at a flea market (it's really an Introvac SP made in Sweden, and so clean I bet it's never been used), but I don't think I've actually used it (yet). Both of those designs protect the user from the plunger hitting them on release. The Soldapullt protection is better IMO because the back end of the plunger is fully enclosed.
                                        If a cheaper Chinese pump works just as well then that's OK with me. The biggest things that are good about the Soldapullt are the self-cleaning action (the tip of the plunger pushes solder flakes out when the pump is cocked), strong suction, the user protection, replaceable teflon tip, tool-free teardown and reassembly, and the fact that it is long lasting and reliable. I use Permatex 22058 Dielectric Grease on the O-ring when needed. It's cheaper than the Edsyn grease and seems to work just as well.
                                        EDIT: I just bought one of these to try out. I'll report back on it if I remember .
                                        M2A-VM ... $60 for picking it up on the curb and a little work.
                                        Good job!
                                        That pump does not protect the user or surroundings from plunger impact on release. I go right ahead and push the Edsyn teflon tips right up against the iron, but maybe it could melt if you leave it there too long.
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                        • varunviolin007
                                          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                          by varunviolin007
                                          Hi guys,
                                          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                          Looking for someone experienced with older PC boards who uses...
                                          07-29-2025, 11:53 PM
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
