What is a mechanical solder sucker?
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: What is a mechanical solder sucker?
    Practice and experience will teach you a lot.
    • johnnyh55
      • Oct 2015
      • 44
      Originally posted by stj
      personally i would be using a pump - i'v never got braid to work on something large like that.
      A pump as in a solder sucker? I have one too but it seems like there is not enough solder to suck, unless my solder sucker is not that good.
      • trebo
        • 514
        • Wales, UK
        #63
        This link may help you, https://www.youtube.com/watch?v=Z38WsZFmq8E
        I always add flux to my wick just before using it, along the bottom 2 inches
        • redwire
          • Dec 2010
          • 3912
          The best I worked with, in a repair shop 500x a day, are the Edsyn soldapullt or the anti-static version. Haven't tried the chinese knock-offs of it.
          Trick is to put a little Lubriplate (grease) on the o-ring and inside tube. That makes a huge difference.
          Many solder suckers have crappy suction and poor technique can also make people give up.
          • johnnyh55
            • Oct 2015
            • 44
            Well I got the holes cleared enough to put the caps back in and I tried to solder them but there is one of the legs that solder doesn't flow in the hole when heat is applied. Maybe I lifted the pad and removed it? What does the pad look like on a motherboard capacitor? All the picture I see online seem to show a pad from a small PCB and it doesn't look like what I am seeing on the motherboard.
              • 31283
              foto time.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                I agree, clean and lube the sucker and get a good photo of the board with the problem. If you've lifted a pad that can be dealt with but a good picture is needed of it to advise properly.
                • johnnyh55
                  • Oct 2015
                  • 44
                  And I was looking at getting a good solder sucker, now is soldapullt a brand that belongs to edsyn? Or it's an actual word that any company can use because I see some soldapullt made by different companies. The edsyn seems hard to fine.
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    Yes, it's a brand name and there's no difficulty finding sellers that I can see from here in the US.
                      I use Edsyn Deluxe SOLDAPULLT with ceramic tip (very hard to find), use it for years and years and years, just have too keep it clean like redwire said. Stay away from the Chinese knockoff.
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        Did you clean and lube your solder sucker? It makes a big difference even on a cheap one.
                          • 31283
                          i have one with 2 o-rings for extra suck - and i modded it for faster travel! it has some kick!!
                          oil the ring(s) and put a bit on your finger and wipe the inside of the barrel.
                            I always keep my clean and lube (the barrel, the tip, the 'O' ring, the shaft, the spring).
                            • johnnyh55
                              • Oct 2015
                              • 44
                              No actually I didn't clean and lube it, just removed the excess solder by pressing on the button and the plunger sticks out ejecting the solder. I didn't know I had to lube either.
                              • SteveNielsen
                                Retired Tech
                                • Jun 2012
                                • 2327
                                Advice doesn't work if you don't take it. Go back to post #64.
                                • johnnyh55
                                  • Oct 2015
                                  • 44
                                  Ok so I was confused, the store what listing the supplier and I though it was the brand of the product. So the one I am looking at is actually a Edsyn soldapullt DS017-P maybe ill pick it up tonight and see if it works better than mine.
                                    • 31283
                                    you only need to lube it "sometimes"
                                    like when i dries up or clogs with solder dust.
                                    how often depends on how much you use it.
                                    • johnnyh55
                                      • Oct 2015
                                      • 44
                                      What kind of lube do you use? Does it need to be something real specific?
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        Now that it's mentioned I need to clean and lube mine
                                        What solder sucker do you have? Just curious, but whatever it is it certainly isn't going to hurt to open and clean it anyway.
                                        I just use a bit of petroleum jelly (vaseline).
                                          http://www.lowes.com/pd_316733-1003-...ductId=3152031
                                          • corrize
                                            Best way to solder LVDS connector for beginner (and qfn) ?
                                            by corrize
                                            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                            See the test :
                                            https://youtu.be/bNAzC-EvqHs?t=1767
                                            With hot air from bellow the board, that's...
                                            03-09-2023, 02:57 AM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
                                          • petemanuk
                                            BGA solder balls not connecting - help pls
                                            by petemanuk
                                            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                            11-16-2022, 05:21 AM
                                          • myth77
                                            UV solder mask - high temp resistent, recomendation?
                                            by myth77
                                            Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                            Is there any solder mask...
                                            03-28-2022, 04:04 AM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
