Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
Is there any solder mask that will keep new pad in place and indure soldering temperatures? or it is not possible? thx
) cable to the sauna ceiling. Is there ANY smoke detector which could survive on the ceiling with up to 100 (120?) °C there, or just all those house toys...
