Treadmill motor not working
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    I have a horizon adventure 925t treadmill, which I'm trying to get working for someone. It was working fine one day when my friend smelled smoke. Now, the LCD display still works, and there is power going to the motor controller board as the LED lights up and the relay clicks when you trigger it to start. The motor starts sometimes but then almost immediately stops.
    The motor is similar to this one:
    Is there generally some sort of start or run capacitor to generate a second phase with these types of 180V DC motor? I would like to test it independently, could I do this with a few car batteries in series or what sort of voltage would I need to get it to budge at all..
    thanks,
    (I know there are a few related threads at the moment, but I didn't want to hijack...)
  • selldoor
    Slow Learner
    • 7870
    Re: Treadmill motor not working
    Read the threads- there are wiring diagrams that might answer you phase query but it is a dc motor? so is that relevant I dont know. I have read quite a lot lately as I have a treadmill awaiting attention, and motor should a, turn freely b, run quite well on 24vdv.
    Does the motor smell burnt- no signs of where the smoke came from?
    What voltage is power supply outputting - we might do better with pictures of the boards
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Yeah selldoor, normally I wouldn't post without pictures, but the treadmill is an awkward place to start dismantling... and doesn't fit out through the door of that place as we found out .... ;-)
      He says he doesn't know where the smell came from, there was no smoke, no sign on anything wrong on the boards.. albeit without a very close inspection.
      But if 24V will get it to start, then that is enough to let me test the motor to start and I'll proceed from there.. thanks.
      • selldoor
        Slow Learner
        • 7870
        I can sympathise with that mine is in my sons garage its too cold to face working on. Perhaps make a note of the board numbers -maybe a controller
        board and a power supply board (on one thread just a controller and a couple of components on the mains line in)
        • Agent24
          I see dead caps
          • Oct 2007
          • 5084
          • New Zealand
          Even a tiny SMD transistor will smell lovely if it fries - but just looking at it quickly you may notice nothing. If the motor is still OK you need to inspect the boards carefully.
          -David VanHorn
          • JonathanAnon
            • Jul 2012
            • 457
            • Ireland
            Okay, I'm about to attack this tomorrow... It's very awkward cos I cant just get it in on my own floor and have a right look at it... But I've hooked up two twelve volt batteries in series, with an inline 10a fuse, and two small male spade connectors which will hook up in to the female spades coming from the motor... (I'll draw this up with photoshop and post here to show others).
            This whole thing where the motors comes on and then stops has me a bit confused though... Is this a common failure? Perhaps if the MOSFET had shorted drain to source, or if a current sense resistor had failed? Cos I'm expecting to hook up the 24V to the motor and for it to run fine...
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              Okay strange one this...
              Connected up the batteries (measuring 24.6V in series) to the two wires of the motor and no movement.. tried moving the motor round to different positions in the 360 degrees and reconnecting the battery, but couldnt get it to move... eventually found one position where I hooked up the motor that it turned.. Motor sparked like mad for about eight seconds, before I pulled the voltage...
                • 31264
                does it use brushes?
                • JonathanAnon
                  • Jul 2012
                  • 457
                  • Ireland
                  Unfortunately, as I've said above, the treadmill is in a room that I cannot remove it from, nor do I have easy access to it.. When I brought in the battery this evening my plan was to confirm that the motor was working, and then take away the motor controller board with me.. I was more than a little surprised to find that the motor would not turn...
                  This is a picture of the motor label.. It's a permanent magent DC motor, and I presume that there's a commutator with brushes, and that that is what is causing the sparking... It is not easy to picture IN the treadmill, but it is almost identical in form to the picture in my first post..
                    • 31264
                    you lost me.
                    that says 180v
                    your testing with 24v
                      This motor can be tested with 24VDC just to see if it will spin.
                      Basically the same as this one:
                      https://www.badcaps.net/forum/showthread.php?t=43064
                      @JonathanAnon, did you hook up the batteries to the Red and the Black wires?
                      The dcr of the motor will be VERY LOW.
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        Originally posted by stj
                        you lost me.
                        that says 180v
                        my 230 volt drill spins on 24 volts just slow and very low torque.
                        My pc
                        CPU : AMD PHENOM II x4 @ 3.5Ghz
                        MB : ASUS M4A89TD PRO USB3
                        RAM : Kingston ValueRAM 16gb DDR3
                        PSU : Cooler Master 850W Silent Pro
                        GPU : ATI Radeon HD 6850
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          Perhaps the the thermal fuse inside the motor?
                            • 31264
                            i'v never seen a motor with a fuse inside.
                            if it did, it would just play dead,
                            • JonathanAnon
                              • Jul 2012
                              • 457
                              • Ireland
                              Hi guys, I got that idea for testing the motor with 24V on this site, but it seems to be commonly done to test the treadmill motor with the 19.2V battery from a powertool... https://www.youtube.com/watch?v=sdR4JGcygnQ
                              @JonathanAnon, did you hook up the batteries to the Red and the Black wires?The dcr of the motor will be VERY LOW.
                              Yeah I hooked them up properly. I put two 12v batteries in series with an inline fuse, and put a couple of male spade connectors on the end. Measured 24.6V dc on the spade connectors and then connected them to the female spade connectors of the motor. I found it very hard to get a DC resistance measurement. Only in one position could I get a measurement of 216 ohms, and in every other position it measured in the high K ohms. I would have assumed that I should be getting the same low resistance measurement across commutator / coil / armature in each position.
                              next step is to pull out the motor and get a look at the commutator / brushes. Cant seem to get those motors online. I'm trying to learn about DC motors anyway, so this is great practice.
                                It sounds like you have bad winding or brushes:
                                Typical treadmill motor http://www.mc70repairexpert.com/default.html
                                It should be VERY LOW Ohms.
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  It could be the commutator needs to be cleaned.
                                  • trebo
                                    • 514
                                    • Wales, UK
                                    sounds like the armature had it, you use to be able to get them rewound years ago, not sure if you can get them done these days
                                    • JonathanAnon
                                      • Jul 2012
                                      • 457
                                      • Ireland
                                      Yeah, I'm gonna have a look at the commutator... But I would have thought at the very least that in certain positions I would have got a good resistance measurement... Unless there is huge amount of damage to all parts of the coils or commutator..
                                      I did that other test, where you change to volts DC, hook up the red and blue to your probes, and spin the motor with your hand.. I was getting 2-3V as it turned.... But I'm not sure this test is of much use... I would have thought that testing the resistance would be a "purer" test of the state of the rotor.
                                      • adgor
                                        • Feb 2015
                                        • 16
                                        A working DC motor will "generate" DC voltage. With the motor still mounted in the treadmill... unplug the motor wire harness and only connect a DVM to the motor power wires. Walk on the treadmill. If the console is working, your speed will be displayed from the spinning front roller (magnet & lief switch). If the maximum treadmill speed is 12 mph and max motor voltage is 120vdc, you should see about 30vdc on the DVM when walking at 3 mph. If the voltage is considerably less than that.... you have a bad motor.
                                        Made by ICON Health & Fitness. Maybe their website can help.
                                        • wzamoyski
                                          Treadmill controller (zipro dream (?)) - PCB-ZYXK9- 1111-V1.2.PCB not working
                                          by wzamoyski
                                          Hello
                                          I received a treadmill controller (probably Zipro Dream) for repair (more like replacing parts). Board designation: PCB-ZYXK9-1111-V1.2.PCB. existing in it were:
                                          • mosfet Q9 (originally MDF4N60 was installed) - mounted on P10NK60ZFP;
                                          • resistor R64 (replaced);
                                          • F2 protection.
                                          After turning on the power of AC1 and AC2, the components burned again. The existing elements were desoldered and new ones were soldered. The controller has not been connected yet because I'm afraid they would be destroyed again.
                                          There are no additional restrictions that can be applied,...
                                          02-26-2025, 02:29 AM
                                        • MMH3
                                          Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                          by MMH3
                                          i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                          Never ever i experienced problems with that.
                                          Now i have one 5050sff machine, where this jumper isnt working at all.
                                          I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                          The history of the machine is that i used it in my office...
                                          03-23-2025, 09:28 PM
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                        • obelix24
                                          Macbook Air 2020 (a2179) - touch id not working
                                          by obelix24
                                          Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                          I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                          02-09-2025, 12:57 PM
                                        • sbt123
                                          charnwood w821 mini wood lathe motor problem
                                          by sbt123
                                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                          10-27-2024, 03:43 AM
