help with a APC ups mod
    Re: help with a APC ups mod
    "all apc i know of must have a battery to do anything." Including the communication with the PC if the power switch is off? I know the charger is an always on no matter the power switch is on or off
    • chozo4
      Nothing Special
      • 134
      With the 750watt one I have (got for $1 at a garage sale) it will run without a battery but just won't provide anything beyond surge protection as expected. It also won't shutup with incessant beeping without a battery either unless configured to not do so using the 10pin data cable. Thankfully batteries are relatively cheap in comparison to a whole unit.
      Even crap caps can be useful... such as blank rounds for prop gunfights.
      • x_orange90_x
        by x_orange90_x
        01-29-2025, 09:24 PM
      • Gentian
        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
        by Gentian
        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
        03-06-2023, 07:07 AM
      • valvashon
        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
        by valvashon
        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
        01-04-2024, 01:44 PM
      • eccerr0r
        A modified sine wave inverter + a grid tie inverter?
        by eccerr0r
        If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
        Next thing is trying to charge the batteries using solar power, but that's another issue ...
        08-31-2023, 09:14 PM
      • caseyjay_48
        Sony KDL-46BX450 Inverter Troubleshoot Logic
        by caseyjay_48
        I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
        I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
        09-23-2022, 08:08 PM
