Using an SMPS to charge a car battery
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Went out this morning and the damned car wouldnt start.. I kept trying and dragged the battery down to 12.2V and it would do anything... I cycled to the local motor place and bought a plug in charger, but this got me thinking.
    But how about this.. If I'd chosen to be MacGyver this morning,
    - take the SMPS out of my PC
    - plug it in to the wall.
    - jump pin 14 to ground to turn it on
    - pull out a 12v DC + and GND - connection (one of the HD/CDROM connections) and hook it up to the battery..
    - check the charge periodically with my voltmeter.
    Would this not charge the battery with a smaller current, the same as the 8 amp charger that I bought, but obviously more slowly?
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Re: Using an SMPS to charge a car battery
    Actually I'm just thinking of the first problem.. The battery in the car needs to be charged to 12.6-12.8V, the SMPS 12v rails wont be that high.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8715
      The next problem is there is no current limiting. The ATX PSU is constant voltage, even if you did increase the voltage to the ~13.8V that's needed to charge a flooded lead acid battery, it'd dump 50A and fry the PSU...
      • mariushm
        • May 2011
        • 3799
        You can adjust the feedback circuitry of an ATX power supply to raise the output to 14-15v, and even above but you have to worry then about the output capacitors being rated for maximum 16v. If you change them to 25-35v you can do more.
        I suppose you could use some diodes to prevent current flow going backwards into the power supply...
        You'll still have to take care of current limiting and other protections from the power supply though.
        Someone was successful in raising his battery voltage a bit: http://www.aussiemagna.com/forums/sh...ad.php?t=75037
        • selldoor
          Slow Learner
          • 7870
          Youd be at least a week late
            If you fly model aircraft (my hobby), try this trick:
            https://www.youtube.com/watch?v=6DnLjpoUwDM
            https://www.youtube.com/watch?v=1w_K08fwZnA
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8715
              The nice thing about charging batteries, for the most part you can dump (or at least reduce) the output capacitors, usually batteries don't care about clean power, ripple is OK (and those desulfators... they're all about huge ripples!). Backflow isn't a great problem, the rectifier diodes do prevent some of it but the overshoot protection resistors will drain batteries if the SMPS is left unplugged.
              But again, current limiting is the key issue. Some serious mods are needed to the PSU to prevent it from getting fried when a super low ESR device of lower voltage is hooked up to the output.
                Most computer SMPS use a simple on/off current limit. When the current exceeds the rated limit, the power supply shuts off. Or, if it has no current limit, it attempts to source hundreds of amps, resulting in rapid failure -- sometimes, even with flames!
                Ideally, the supply would be current limited, with a constant voltage. An LED driver is a good possibility: most will not shut down on even a shorted load.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8715
                  Oh... and my posts seem to imply that protecting the PSU is the only issue... no, also protecting the battery too. The I^2*R (ESR) heating of the battery is not good for it either. Plus charging it too fast may cause heating and coupled with any hydrogen generated....
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    My ancient Sears battery charger (probably Schumacher) uses just a triac or SCR to regulate current, and the 741 op-amp circuit that controls it has absolutely no capacitors.
                    How about a laptop charger with a 5-10 ohm, 10W resistor in series? They typically put out 19VDC.
                    • JonathanAnon
                      • Jul 2012
                      • 457
                      • Ireland
                      Okay this was the bit I was confused about.. i.e. how much current would it draw... Because the battery isnt a conventional load which defines the amount of current/voltage required, I wasnt sure what would happen when you hook up the SMPS to it.
                      So I guess the difference between the SMPS and my battery charger (in respect of current) is that the battery charger defines two current ratings, creatively named "Fast Charge" 8AMP and "Slow Charge", and will not allow the battery to draw any more than this. Whereas the SMPS does not limit current, except by the means described by tom above, where it detects overcurrent and shuts down.
                      My brother is a frustrated model aircraft flyer tom... He's been messing around with them for years, but the only thing I've seen him fly successfully was on the simulator software..
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8715
                        Yes, that's one way to do it, this will work. The resistor will prevent the high current rush, but it will not prevent overcharge which is the other issue.
                        Basically if your PSU voltage is lower than the battery voltage, nothing.
                        If it's the same... nothing.
                        If it's greater... Remember V=IR, I=V/R. V is the difference of the battery and the SMPS voltage. R is the sum of the ESR of the battery, resistance of wires, and the effective ESR of the PSU (NOT the caps). Typically each of these three are in the milliohms. So, say the battery is 12 volts, the SMPS PSU is 14 volts to be enough to charge it, and the ESR of the battery, PSU, and resistance of cables = 10 milliohms each, then current draw = (14V-12V)/(30 milliohms) = 66 AMPS. While theoretically possible to charge that fast, but if anything is just not right...
                        Oh... and fast/slow on those "cheap" car chargers tends to be a winding or so selected off the transformer to change the voltage. There typically is some resistance in the wire or an actual resistor to limit the charge current a bit, but typically it will still go over the rate suggested by the switch...
                        • JonathanAnon
                          • Jul 2012
                          • 457
                          • Ireland
                          Okay so taking your example above, if there the voltage of the SMPS is 14V and the voltage of the battery is 12V, the you could limit the current to 2amps (within the remit of the 12V rail of the SMPS) by a 1 Ohm 4 Watt resistor
                          I=V/R
                          2amp = 2V / 1 Ohm
                          P=VxI = 2vx2amp = 4Watts
                          (albeit there is still the issue with you needing to shut it off when the battery reads about 13.7V)
                          • mariushm
                            • May 2011
                            • 3799
                            Power dissipated in a resistor would be I x I x R or V x V / R
                            Yeah, it would dissipate about 4 watts, so to be safe you'd have to use a 7-10w resistor. It would still be hot.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8715
                              The tricky part of selecting the resistor too is that when the battery is nearly flat, say at 10V, that 1 ohm resistor during the initial part of the charge would be dissipating (14-10)^2/1 = 16W... or worse if the charging connectors were shorted... so that initial 10W resistor will not do so hot, and rather be very hot.
                              • JonathanAnon
                                • Jul 2012
                                • 457
                                • Ireland
                                Okay that makes sense.. So I guess when you're not using a defined current source, and you dont know what current a load will draw of it's own volition, you need to limit the current yourself.. That's answered my question...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8715
                                  hmmm. I wonder if there's any interest in a mod for, say, ka7500/tl494 psu's to current limit so you can use for charging once you up the voltage to 14-odd volts... need some current sense... hmm...
                                  project idea... 2 stage smps charger using a pc psu...
                                  • amzee94
                                    • Nov 2012
                                    • arslan
                                    Whoo awesome idea
                                      You can have the power supply feed the 2A constant current source, the output of the current source will feed the 14.5V Voltage regulator, the output of the regulator will feed the Adnode side of a 3A Diode, the Cathode will be connect to the batteries.
                                      The maximum current will always be limited to 2A by the constant current source. When the batteries voltage reach about 13.5V (14.5 -1V Vf of the Diode), the Diode will not be bias on so the charging will stop.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8715
                                        Getting a constant current source is not cheap either. The rub is to make a CC source with the guts of the SMPS... I think all one really needs is an op amp, a transistor, and a few resistors to mod a tl494/ka7500 smps to limit current...
                                        Or quite possibly all the stuff is already there, just need to repurpose...
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • huzo
                                          Lenovo y700 not showing battery charge state
                                          by huzo
                                          The above mentioned laptop with the board NM B-163 is showing 1% battery charge in OS,but the battery holds for about 2h when unplugged from the charger ....when plugged in the windows says plugged in,the voltage goes up from 13.6V when empty to 15.7V when full,nominal voltage is 14.8V for that battery....SO it does charge and it does deplete, but it doesn't show charging or goes up from 1% on the battery meter....Here is the schematic for the battery charge connector, how should i test data and clock lines? They are connected to the EC on the mentioned pins,so no brekage,i don't have an oscilloscope...
                                          11-21-2025, 07:36 AM
