How can I charge that battery pack?
  • razenxd
    • Jan 2021
    • 11
    • Greece
    it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
    At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
    Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
    Now, I have noticed a few things.
    The "dead" battery, while connected to charger and NOT Charging will power up the robot but when the robot tries to activate its joints, it shuts down(I guess not enough voltage).
    BUT, while the robot is booting the charger lights changes and looks like the battery starts to charge, but this stops when the robot shuts down.
    So I was wondering if :
    A. Can I put a known working battery in parallel with a non working battery and try to charge it?
    B. Based on the assumption that the battery charges while the robot tries to boot, meaning that it's possible to charge it under some load, could I artificially make that load and charge the battery?
    2 of those battery packs are 1year old, and 1 is a rebuilded pack which also rebuilded last year.
    I'm trying to avoid a rebuild and if possible opening up the packs.
    you can see pictures of the battery pack here
    https://www.bartneck.de/2021/02/03/r...-battery-pack/
    Any other idea/recomendation would be great.
    Thanks a lot
  • rumpumpel1
    • Jul 2019
    • 165
    • germany
    Look for someone who has an NLBA (battery analyzer).
    • razenxd
      • Jan 2021
      • 11
      • Greece
      Unfortunately I cannot find anyone with an NLBA.
      The only option is to ship them to a different country, but I could just rebuild them for cheaper.
      Also don't know if there's the pinout available.
      I guess my ideas will not work?
      • rumpumpel1
        • Jul 2019
        • 165
        • germany
        post your problem in the NLBA forum.
        • razenxd
          • Jan 2021
          • 11
          • Greece
          Thanks for the suggestion man.
          But on their forums they provide support only for NLBA customers
            • 31283
            i would open the pack and charge each cell using a tp4056 module and some crock-clips
            • rumpumpel1
              • Jul 2019
              • 165
              • germany
              so you were not able to register?
              Then the only suggestion I have: call every repair shop in you region and ask them whether they use an NLBA. I'm pretty sure, you will find one.
                • Jul 2011
                • 6070
                The first issue is that if the robot needs power to not lose its parameters this is a poor design because in reality when it is power off it should be off not sleeping now what you might be able to do is how is just power the data retention system and make sure that the battery pack does turn on but in order to verify this you need to have access to the battery system power leads and see what the current draw is when supposedly off and see if the current draw is micro milliamperes if not why not
                Now depending on how rough the robot is on the battery pack you could have an issue with using too much current and heating up the battery cells continuously and degrading them over time and then you could have self discharging cells that in about a month or sometimes more than a month the battery voltage between cells is noticeably different which will cause the BMS protection board to refuse to turn on and if the voltage is below a certain voltage refuses to charge the battery cells with any real current and need to be charged at the battery cell rail which would mean that you would need to open the battery pack in order to do this
                  • Jul 2011
                  • 6070
                  You do not need to find someone with a NLBA laptop battery unless is a computer battery pack that it is using and then maybe
                  There is a battery tester that I use and will tell you everything you need to know about your battery cells but you have to use the computer software for this information to be available you can use the battery tester with out the software but you can not look at charging and discharging curve graphs over time which what you need to determine weather or not the battery cell is very good fair or bad
                  This would require you to test each and every battery cell to determine this
                  The model number of this battery tester is
                  EBC-A10H you can find on eBay Aliexpress Bandgood and several other online sellers
                  They run around $75.00 or more depending on what site you go to
                  • petehall347
                    • Jan 2015
                    • 4448
                    you could try giving it a second or a few seconds with a good battery pack to get the voltage up to get it to start charging . i have done this a few times now with garden tool packs .
                      • Jul 2011
                      • 6070
                      It would help if you posted a picture of the battery pack and where it connects to the robot and the charger
                      • techfreak9356
                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                        by techfreak9356
                        09-14-2023, 11:10 PM
                      • ruletero
                        Acer a515-43 low battery charge voltage
                        by ruletero
                        Hi
                        Acer A515-43
                        LA-H801P
                        Fail: Does not charge battery, has low voltaje on connector.
                        Laptop didn't want to turn on, only charge led blinked.
                        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                        10-24-2022, 02:31 PM
                        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                        I bought this from an eBay seller but unfortunately they only had one
                        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                        I bought three of from them to also make battery packs with this output power limit in mind
                        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                        04-23-2025, 05:50 AM
                      • brispuss
                        Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                        by brispuss
                        Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                        Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                        I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                        12-28-2022, 02:58 AM
                        Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
                        I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
                        I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
                        06-18-2023, 05:48 PM
