What do you call those metal tips that are attached to the ends of wires (crimped to the insulation) that get soldered into circuit boards?
Those little metal tips
Tags: None
Re: Those little metal tips
Crimp Connectors? a picture might helpPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
These perhaps?
R.S linky.
Scroll down that page and you will see them i think.Comment
Maybe something like that!
Muh-soggy-kneeComment
Probably this:
http://www.digikey.com/product-searc...re-pin/1442847
or this
http://www.digikey.com/product-searc...-board/1442848Comment
Heh, I have never seen those before
The tips are at the ends of the red, yellow, and black wires:
Some of them are made to hold 3-4 wires together.
That's them in the second link. Thanks!Last edited by larrymoencurly; 08-06-2012, 12:00 PM.Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by questoreSomeone brought me a liquid metal damaged motherboard.
First I have removed alll liquid metal from the board.
0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
There are 2 things that not working.
1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
2. nvme devices are not detected on either of the 2 slots.... -
by bulkchart32i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
by silver60618Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?-
07-11-2025, 01:47 PM -
by DoOm86I'm new to elettronic, so perhaps my question has no sense.
Can a laptop still work without one of the soldered ram?
I was wondering if a laptop (or any other device actually) can still works if removing a faulty soldered ram without soldering back a good replacement. Of course considering the mainboard has other ram chip perfectly functional.
I tried on a MacBook Air and also an Asus laptop and it seems no possible without a replacement. At least, not just removing the faulty one.
Sometimes for the seek of data recovery on a flash soldered drive on the mainboard,... - Loading...
