How to clean Liquid Metal from under CPU?
  • silver60618
    • May 2021
    • 36
    Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
    The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
    Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
  • dogfish404
    hp probook 430 G4 liquid metal damage
    by dogfish404
    hi just a few days ago i had a VERY similar thing happening which led me to this forum, ie this post!
    it all began with me applying liquid metal to my probook 430 g4 7200u AND buyin a backlit keyboard on ebay.
    after few hours everthing went well. plus then i ordered myself a new hdd door, some 16gb ram, etc.. a new FAN, the old was too loud, etc..
    so i ended screwing on my laptop few more hours opening and closing.. in this procedere TWO things happened:
    some lquid metal escaped and was teared around the bios chip , special not on it but on...
    07-08-2022, 03:22 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • Hondaman
    Liquid cooling?
    by Hondaman
    I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
    (After previous generation hardware [Gigabyte] didn't...
    05-08-2025, 09:37 PM
  • kurland
    Strange liquid on damaged GTX1080 card
    by kurland
    I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
    As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
    Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
    11-17-2020, 07:14 PM
  • mitchw
    MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
    by mitchw
    Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
    It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
    I quickly took it apart and washed the liquid residue off the mainboard.
    The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
    The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
    Now the laptop...
    07-16-2025, 07:55 AM
