Those little metal tips
  • larrymoencurly
    • Oct 2004
    • 960
    What do you call those metal tips that are attached to the ends of wires (crimped to the insulation) that get soldered into circuit boards?
  • selldoor
    Slow Learner
    • 7870
    Re: Those little metal tips
    Crimp Connectors? a picture might help
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Maybe they are some sort of connecting pins for connecting wires to the circuitboard without wiring them.
      The only thing I think of is a spade connector, but those aren't supposed to be soldered to a pcb.
      Muh-soggy-knee
      • Steve.B
        • Dec 2008
        • 83
        These perhaps?
        R.S linky.
        Scroll down that page and you will see them i think.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Originally posted by Steve.B
          These perhaps?
          R.S linky.
          Maybe something like that!
          Muh-soggy-knee
          • mariushm
            • May 2011
            • 3799
            Probably this:
            http://www.digikey.com/product-searc...re-pin/1442847
            or this
            http://www.digikey.com/product-searc...-board/1442848
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Heh, I have never seen those before
              Muh-soggy-knee
              • larrymoencurly
                • Oct 2004
                • 960
                The tips are at the ends of the red, yellow, and black wires:
                Some of them are made to hold 3-4 wires together.
                That's them in the second link. Thanks!
                • JohnLWG
                  • Jul 2012
                  • 15
                  Those clips look like the same ones from a radioshack RCA plug
                  • JohnLWG
                    • Jul 2012
                    • 15
                    I can post pictures later. If theyre the same part I can send you some.
                    • orbiter
                      • Mar 2011
                      • 37
                      Terminals.
                      Don't Bin It - Repair It.
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • questore
                        nvme and wifi error after liquid metal spill
                        by questore
                        Someone brought me a liquid metal damaged motherboard.
                        First I have removed alll liquid metal from the board.
                        0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
                        Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
                        There are 2 things that not working.
                        1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
                        2. nvme devices are not detected on either of the 2 slots....
                        11-11-2025, 01:16 AM
                      • bulkchart32
                        i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
                        by bulkchart32
                        i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
                        06-19-2025, 02:37 AM
                      • silver60618
                        How to clean Liquid Metal from under CPU?
                        by silver60618
                        Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
                        The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
                        Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
                        07-11-2025, 01:47 PM
                      • DoOm86
                        Doubts about: working laptop without a soldered ram/vga/battery
                        by DoOm86
                        I'm new to elettronic, so perhaps my question has no sense.
                        Can a laptop still work without one of the soldered ram?
                        I was wondering if a laptop (or any other device actually) can still works if removing a faulty soldered ram without soldering back a good replacement. Of course considering the mainboard has other ram chip perfectly functional.
                        I tried on a MacBook Air and also an Asus laptop and it seems no possible without a replacement. At least, not just removing the faulty one.
                        Sometimes for the seek of data recovery on a flash soldered drive on the mainboard,...
                        04-14-2023, 05:05 AM
