Those little metal tips
  • larrymoencurly
    • Oct 2004
    • 960
    What do you call those metal tips that are attached to the ends of wires (crimped to the insulation) that get soldered into circuit boards?
  • selldoor
    Slow Learner
    • 7870
    Re: Those little metal tips
    Crimp Connectors? a picture might help
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Maybe they are some sort of connecting pins for connecting wires to the circuitboard without wiring them.
      The only thing I think of is a spade connector, but those aren't supposed to be soldered to a pcb.
      Muh-soggy-knee
      • Steve.B
        • Dec 2008
        • 83
        These perhaps?
        R.S linky.
        Scroll down that page and you will see them i think.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Originally posted by Steve.B
          These perhaps?
          R.S linky.
          Maybe something like that!
          Muh-soggy-knee
          • mariushm
            • May 2011
            • 3799
            Probably this:
            http://www.digikey.com/product-searc...re-pin/1442847
            or this
            http://www.digikey.com/product-searc...-board/1442848
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Heh, I have never seen those before
              Muh-soggy-knee
              • larrymoencurly
                • Oct 2004
                • 960
                The tips are at the ends of the red, yellow, and black wires:
                Some of them are made to hold 3-4 wires together.
                That's them in the second link. Thanks!
                • JohnLWG
                  • Jul 2012
                  • 15
                  Those clips look like the same ones from a radioshack RCA plug
                  • JohnLWG
                    • Jul 2012
                    • 15
                    I can post pictures later. If theyre the same part I can send you some.
                    • orbiter
                      • Mar 2011
                      • 37
                      Terminals.
                      Don't Bin It - Repair It.
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • bulkchart32
                        i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
                        by bulkchart32
                        i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
                        Yesterday, 02:37 AM
                      • DoOm86
                        Doubts about: working laptop without a soldered ram/vga/battery
                        by DoOm86
                        I'm new to elettronic, so perhaps my question has no sense.
                        Can a laptop still work without one of the soldered ram?
                        I was wondering if a laptop (or any other device actually) can still works if removing a faulty soldered ram without soldering back a good replacement. Of course considering the mainboard has other ram chip perfectly functional.
                        I tried on a MacBook Air and also an Asus laptop and it seems no possible without a replacement. At least, not just removing the faulty one.
                        Sometimes for the seek of data recovery on a flash soldered drive on the mainboard,...
                        04-14-2023, 05:05 AM
                      • estabilito
                        Tips geting oxidized when using wick
                        by estabilito
                        Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                        i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                        Temperature: 350-365celsius
                        station: jbc cd-2bqe
                        Wick: edsyn
                        flux: warton hf rework jelly
                        Do you have any tips?...
                        04-12-2025, 11:55 AM
                      • shadow666
                        ASUS N43SM with Nvidia GT620M crash after touch metal case
                        by shadow666
                        i have a asus N43SM i7 2th gen and i have a big probelm
                        After hitting the metal part of the touchpad or the sides of the mouse is metal, the system locks and the image crashes !
                        disassemble notebook and this cover on top picture I insulated all the bases on which the screw is fastened so that static electricity does not cause this problem again but not working !
                        Sometimes, when I didn't work with the notebook for a few minutes, after I touch the touchpad, the image confused​ and the system locks ( See Down Picture). I have to turn the system...
                        01-05-2025, 08:45 AM
