Doubts about: working laptop without a soldered ram/vga/battery
  • DoOm86
    • Nov 2022
    • 42
    • italia
    I'm new to elettronic, so perhaps my question has no sense.
    Can a laptop still work without one of the soldered ram?
    I was wondering if a laptop (or any other device actually) can still works if removing a faulty soldered ram without soldering back a good replacement. Of course considering the mainboard has other ram chip perfectly functional.
    I tried on a MacBook Air and also an Asus laptop and it seems no possible without a replacement. At least, not just removing the faulty one.
    Sometimes for the seek of data recovery on a flash soldered drive on the mainboard, could be a useful thing to not look for a ram replacement which sometimes it can't be found.
    What about without a dedicated but soldered vga (if not in the same bga of the cpu)? If the cpu has integrated vga also, desoldering the dedicated vga would not make the laptop works. But is there a way?
    And there are cases where without the lithium battery connected a laptop can't work at all even if plugged in with its original charger?
    For example, I read that few laptops have a new hybrid charging topology circuit which can work with a supplement battery+charger mode to provide additional power.
    Thanks to everyone.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Doubts about: working laptop without a soldered ram/vga/battery
    No, only if the entire rank is disabled (which is not always possible) and there is another working one (soldered or on a SODIMM module). Reason is that memory bus is always 64-bit on a given channel and several ICs of 4, 8, or 16 bits are used to make 64 bits so you can't remove one 16-bit IC and get a bus width of like 48 bits. (sometimes there can be only one IC of 64 bits but it's not that common)
    That's generally called "dis-to-UMA conversion".
    Yes but very rare, mainly some ARM laptops or very low-end Atom laptops that are more alike to a tablet.
    But some other laptops require a battery to work properly. (MacBooks for example)
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Workstations also might require a working battery to turn on. ZBook comes in mind.
      There's a workaround tho.
      And some models might require a working battery to boot into OS. Like T480s.. Sometimes..
      • DoOm86
        • Nov 2022
        • 42
        • italia
        First of all, thank you for the reply. I wasn't sure to get one.
        RAM related:
        Your explenation makes perfect sense and it helps me a lot to understand better the topic. If i find a corrupted RAM then, most of the time i'll have to look for a replacement. I guess, like it is for the Graphic Cards, i can just replace the defected one and not necessarily the whole rank, right? I just got a Macbook Air in my lab with a dead RAM chip (16 total) and it's the perfcet occasion to learn more about this matter.
        VGA related:
        this "dis-to-UMA conversion" is something completely new for me and i'll study it, thanks.
        BATTERY related:
        As i imagined, since i have never encounter a similar circuit on a laptop, but i read somewhere it was starting to be a bit more frequent nowdays on very base laptops or very high demanding power laptops.
        Unfortunally i did not check this in recent apple macbook, in old ones yes and they were working just fine without it, of course with all the cons on not having a battery connected.
        • DoOm86
          • Nov 2022
          • 42
          • italia
          Thanks for your reply.
          There is always a workaround, it's the beauty of electronics as i am starting to understand since i'm not an expert
          That's interisting, looking forward to put my hands on one and try to learn something new.
          • piernov
            • Jan 2016
            • 4437
            • France
            If you are able to figure out which IC is bad, yes.
            If the failure is a partial or full short to ground, very often several (or all) ICs are a damaged.
            Note that if it is an 820-3023 board (2011 13"), replacing RAM ICs won't fix it permanently, it may come back to life for a short while but will fail again.
            • DoOm86
              • Nov 2022
              • 42
              • italia
              I wanted to thank you again for the informations you provided.
              I successfully changed the faulty chip ram and now the Mac air is working well (it has been a week or so). It was a Mac air 2010. I informed my client about the risk of having the same issue again regardless what you mention about a similar but not smae motherboard, but he accepted the job anyway.
              I also studied about the "dis to Uma" and so far it's out of my league to be honest, since the only way to do it is to study the schematic and find a way to do it. My knowledge in electronics is not that good yet even though I can read schematic, I can't play with it.
              If someone has general documentation about it (whatever it is) and the willing to share it, I would like to study it.
              What I found so far online are information about specific cases and not about general knowledge to learn how it really works or have more info about it.
              • serious_electron
                Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                by serious_electron
                Hello Everyone!
                I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                06-28-2025, 02:57 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • ahmarzo
                Acer TMX314-51 laptop battery problem
                by ahmarzo
                I have acer laptop tmx314-51 with part no 6050A3020501.
                The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                The schematic is not available...
                04-11-2025, 09:14 AM
                ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                Narrow VDC applications where the system power source is
                either the battery pack or the regulated output of the charger.
                This makes the max voltage to the system equal to the max
                battery voltage instead of the max adapter voltage. Operating
                at lower system voltage can improve...
                11-05-2024, 04:43 PM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
