Help troubleshooting homemade ESR meter
  • ELItheICEman
    • Sep 2011
    • 25
    Ok, I built an ESR meter using the schematic and instructions here (I think it's fairly popular, maybe one of you guys have built this before?). I've went through the process of tracing all the components through the circuit and comparing to the schematic, All seems well. The problem most likely lies in my knowledge of transformers, I ordered the EA-77-188 Tiny double E core and the same gauge magnetic wire used in the guide (AWG #36 and AWG #26). On my first attempt I initially started winding the #36 wire perfectly around the bobbin, each loop adjacent to the last winding. That is until I realized it would probably take at least an hour to wind 400 turns like this. So I kind of sped up the process of winding while negatively affecting the uniformity and neatness. I finished up with some masking tape and started the next run (20 turns of #26 wire). Again I used masking tape to finish up. I then slid the E cores into place (although I didn't glue them in any way). I then put the transformer onto my circuit board and applied voltage to the circuit. The needle on the uA meter jumps ever so slightly upon turning on the circuit but nothing else. I've tried a few caps and resisters on the test leads and adjusted the trim pot in every position. I'm getting a steady 5V on the board, but I haven't really found many other helpful results from other test points. I have an oscilloscope but I'm not exactly fluent in using it...
  • cmj21973
    • 267
    Re: Help troubleshooting homemade ESR meter
    1) When you say masking tape, do you mean paper painters tape or something else? hopeful you mean electrical tape.
    2) Did you check to see if the two coils were isolated, meaning no continuity?
    While the "E" cores don't need to be glued, they need to be wrapped with tape to hold them together
      Can you read continuity of both windings?
      • Toasty
        • Jul 2007
        • 4171
        Are C2 & C3 installed correctly?
        - Neg of C2 to T1 // Pos to U1 Pin 1
        - Neg of C3 to test lead/R6 junction // Pos to R7
        You should also have 2.5v on U1 pins 3 & 5.
        Toast
        veritas odium parit
        • cmj21973
          • 267
          Yes. You should have continuity on each coil, but you should not have continuity between the two coils.
          If you have continuity between the two coils then the coils are shorting out to each other.
            The reason I ask if he can read continuity of each windings is to make sure he does remove the enamel coating off the wire before soldering.
            • cmj21973
              • 267
              Of coarse the best way to test the transformer is with a ring tester (FBT/LOPT)for high Q inductive components.
                Like this?
                http://s807.photobucket.com/albums/y...0cap%20tester/
                • cmj21973
                  • 267
                  Yeah, that has a ring tester function.
                  The ring tester I'm reffering to is this one:
                  http://www.anatekcorp.com/bluert.htm
                  • ELItheICEman
                    • Sep 2011
                    • 25
                    Ok, so I checked the caps and had to change one around, I didn't notice polarity was indicated in the schematic. I checked the voltages on the IC, pin 3 was around 2v and pin 5 was closer to 3v. I pulled the transformer off, the 2 coils are not connected shorted. When I check continuity on the 400 turn (#26) coil I get a high pitched tone from my meter instead of the normal beep and a reading of 19 ohms. I am going to *patiently* rebuild the transformer soon. Any tips on the actual making of the transformer? I couldn't find any help online. The first transformer I made I ripped the wire trying to sand off the enamel and had to start all over. Any help would be greatly appreciated, and I'm sorry it took me so long to get back to you guys!
                    • senz_90
                      • Aug 2013
                      • 328
                      • Indonesia
                      hello everybody. i need help to make my panel meter. i designed esr meter from this website
                      http://kakopa.com/ESR_meter/
                      and i think that's function. but i get problem with meter measurement. i try to fix my small vu meter with esr wizard i found on googling.
                      the problem is the panel meter didn't match the exact value with resistor i measure.. of course i think esr wizard don't have a same specifications with my esr meter. it was factory built of course with good quality
                      i just try anyway.
                      when i test 15 ohm resistor it just nearly 15 ohm on my meter. don't exactly pointed on 15 ohm . when i test with 10 ohm resistor it give me a same result as before i just try to modified value on that image with photoshop. but it didn't makes me satisfied enough.
                      so i think i need a software designing my panel meter. i try googling and got result Front Designer 3.0 but it just using Russian language. i didn't understand Russian language so the point is i want a software that could design panel meter easily and freeware of course.. hehehe.
                      please someone help me suggest a freeware software to design panel meter or if you don't mind u can send your software that u usually used for design panel meter to my email too.
                      i really want a professional looks on my esr meter.
                      "There is no shortcut to be successful. No pain, no gain."
                      Best Regards
                      Rudi
                      Thank You
                      • senz_90
                        • Aug 2013
                        • 328
                        • Indonesia
                        hmm.. i just think this is a good forums because it's likely discuss more about caps and repairment and the first thing i think crucial is ESR topic!!
                        But after one day, that's no one wanna go to reply instead help me.
                        yeah. it doesn't make me upset.. maybe i wanna go to another forums and try their helped !!
                        Best Regards
                        Rudi
                        Thank You
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4951
                          • New Zealand
                          You would probably get better results if you use a vector-based image editor like Inkscape or Illustrator
                          -David VanHorn
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            i just try anyway.
                            The output on the meter is likely non-linear, I.E. at one end of the range the resistance values are closer to each other.
                            P.S. Have you tried adjusting the 1K ohm potentiometer yet?...
                            Muh-soggy-knee
                            • senz_90
                              • Aug 2013
                              • 328
                              • Indonesia
                              would u mind give me a link that i can download it? but hopefully it can free. maybe u think that im crazily man who is always wanna free software. but i just think i may using that software for a 3-4 times, not more. after my meter have been done. maybe i just lay it down on my computer
                              yeah at one end of the range the resistance values are enough closer to each other. so what i must to do make it linear likes as other esr meter? i just want to make my meter can read even 0.xx resistance like this esr wizard meter
                              yes, i have tried to adjusting the potentiometer and the scale can deflect to 0 ohm on my vu meter (-3 values on vu meter)and the led is glow with probes lead shorted >>i think that my project is success and i have tried it measure any leaky caps between good caps.. i just try to fix esr wizard scale panel meter and the result is just like I said before on my post. it must to rescale again because it didn't match. i have ever read on another homemade esr meter link that it is always must to rescale with small value resistor. so i try to measure it and it didn't give me a satisfied result about the scale.
                              so i think the problem just make a new scale looks profesional that describe the value same as when i measuring small value resistor. i have edited before with photoshop but you know what i means. it didn't present any real scale. just present 1-30 ohm resistor, for notes i just measure and the max scale that i can measure is 30 ohm and it almost not a deflection (little deflection) on my left panel meter. so i means that it can't present when we want measure different between 0.22 ohm and 0.33 ohm value.. maybe the esr meter doesn't success yet?? or i just have to make a new panel meter to fix on my vu meter?
                              my vu meter looks like this
                              Best Regards
                              Rudi
                              Thank You
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                As stated in the article (although not tested by the writer), try changing R14 and R15 to 47K. Then, change the resistors R10 and R11 to, say, 10 ohms.
                                The difference is fed to op-amp C which amplifies it. The feedback resistors in the original were 47K but this led to a certain problem which was solved by lowering the gain by lowering the value of the resistors to 27 K. After building my prototype I am thinking that it may have been better to leave the 47 K resistors and lower the value of the two lower resistors of the bridge from 22 ohm to 15 ohm or even 12. That would make the instrument more sensitive to lower ESRs. I may try that in the future.
                                Muh-soggy-knee
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4951
                                  • New Zealand
                                  http://inkscape.org/download/?lang=en
                                  -David VanHorn
                                  • senz_90
                                    • Aug 2013
                                    • 328
                                    • Indonesia
                                    i haved makes changed already. i use R10 and R11 15 ohm
                                    and R14, R15 47k. because when i hadn't make changed, my meter couldn't deflect to 0 ohm scale. after did it my scale looks normal.
                                    the problem is just likes what you said. maybe it's not linear.. but I haved try to measure any bad caps that i haved and it function where is the one bad caps i tested don't make my meter deflect. and the others didn't have a small ESR. it looks like more than 3-4 ohm with high capacitance caps likes 470 microfarad. btw it not a bad result of course. i think this esr meter is so useful. now i wanna go to download any software to try to fix my panel meter..
                                    i just compare with other new caps and it makes different whereis the new caps have a very low ESR near 0 ohm on my meter..so it is worth to build homemade esr without many feautures. but i think this is useful for a colleger likes me with a little of money because don't have works yet..
                                    anyway thank you for your advice sir
                                    thanks sir for your help. i am newbie on electronic. but i'll try my best with a useful equipment to be a good technician..
                                    Best Regards
                                    Rudi
                                    Thank You
                                    • RetroComputingGrotto
                                      IBM LTO 7 Tape Drive - Dust Sensors??
                                      by RetroComputingGrotto
                                      I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                      I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                      09-19-2024, 01:54 AM
                                    • chth96
                                      Is it possible to test small ceramic disc capacitor with analogue meter?
                                      by chth96
                                      I read EBOOK of Testing Electronic Component and found that
                                      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                      Is it really possible to test small ceramic disc capacitor with analogue...
                                      03-09-2024, 10:03 PM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • UNITRAX
                                      Tape recorder Sharp RT 1155 - DC voltage in the VU Meter circuit
                                      by UNITRAX
                                      I have a faulty right VU meter.
                                      At the poles, the DC voltage varies between 0.5 - 1.5 V
                                      The indicator does not respond to the ohmmeter at all.
                                      I checked
                                      transistors Q202, Q203
                                      capacitors
                                      C230, C231, C412
                                      D202 diode.
                                      Variable resistor VR 204
                                      T 201 coil
                                      Anyone have an idea how to get rid of the DC voltage?...
                                      05-13-2023, 04:28 AM
                                      Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                      by sam_sam_sam
                                      I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                      I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                      12-31-2023, 06:04 AM
