IBM LTO 7 Tape Drive - Dust Sensors??
  • RetroComputingGrotto
    • Aug 2023
    • 104
    I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
    I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the library and then removed the cover so I can manually clean the read/write head with some IPA with a foam cleaning pad. Other than the cleaning hours counter, is there another way (i.e. some sort of dust sensor) that the tape drive uses to determine if it needs cleaning or not?
    If it has 'dust sensors' what do they look like so I can clean them?
    This is the tape drive just before I removed it from the robotic library:
    As you can see there is a bit of dirt/grime on the top housing so I've removed/cleaned that with a lint free cloth.
    Inbetween the rollers you can see the tiny read/write head which I have cleaned with a foam cleaning swab dipped in IPA.
    Just need to work out now if there are actually any dust sensors and if so where they are so I can clean them before I put it back together.
    • Aug 2023
    • 104
    After cleaning the read/write head I removed this much dirt. Bearing in mind the drive has already been 'cleaned' with a cleaning cartridge this is quite a bit of dirt getting in the way of reading/writing.
    I've never heard of a 'dust sensor' before that lots of people on other sites refer to so I'm going to assume it's the ill informed suffering from verbal diarrhea making uneducated guesses on something they know little about...
    Only time will tell if this fixes the issue or not - I remember 'back in the day' cleaning this much/little dirt from the heads of a VHS recorder would improve the video quality no end so hopefully this is the fix 😎
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • howardc64
      Macbook Dust-Gate Preventive Cleaning
      by howardc64
      Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
      Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
      https://www.ifixit.com/Guide/MacBook...leaning/177920
      10-09-2024, 10:10 AM
    • triplefour
      LG 75UN8570AUD panel issue fixed with tape.
      by triplefour
      I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
      add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
      07-17-2023, 10:22 PM
    • rumi409
      LG OLED C1 Pixel Cleaning Made Picture Worse
      by rumi409
      ​​​​​​ Hi,
      I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
      11-15-2024, 01:09 AM
    • macbook1967
      Lefant M201 vacuum sensors alignment help
      by macbook1967
      I can't get my Lefant vacuum go straight after a battery replacement. It continues going in circles in open field or follows the wall constantly. What happened is I had to remove a circuit board to be able to replace a battery. After putting the circuit board back in place the sensor alignment went off, and I can't find the right position for sensors 1 and 2. Sensors 3 are not adjustable. Your help would be very appreciated....
      10-03-2025, 08:53 AM
