Altec PC410 (BGA Rework) to communicate with PC
Re: Altec PC410 (BGA Rework) to communicate with PC
I had one that worked but it was a bit iffy. Eventually what I did is simply say F*** it and spent $20 on a Pentium 4 laptop with real serial and parallel ports and used a straight RS232 cable.Leave a comment:
Can you please post some pics how you did it?Leave a comment:
hello to all, well after some time my altec stop 232rs connection.. try everything. adapters 340, pl2302.... etc.. and fck nothing.. altec became deaf.
so lets go inside.. RX is arriving at cpu, after the max232 and optocoupler, good signal in osciloscope, but nothing!!! he does never accept income data. rebuild the rs232 new max232ene+, new coupler, check cond.. all good but no comunication......
so i have in "bag ttl-usb" lets go direct to cpu .. and fck ... voila...
communication perfect everytime
PSoft Rework working good
solution: kill the rs232 ..kkkkkkk
Ps- sorry for the writing.
now my pc 410 is up and running again.... loooking forward to use my achi station...
Its very important for me to use the usb ttl virtual com port with 9600 baud. otherwise it´s not working in software. i´m using original software from achi (com port is fixed @com1) and PSOFT Rework in wich the port is changeable an its possible to change settings.. absolutely perfect... thanks a lot...Last edited by stormanimal83; 04-26-2023, 02:55 PM.Leave a comment:
Hi there thanks for all the Information shared. Im another guy who just bought a second hand achi ir pro with pc410 and im not able to connect to my pc via com port rs232.
Can you (kukasIII) please share the way you connected this usb via the USB TTL?
You just soldered the red white and yellow wires to the pc410 board and then connected this usb ttl adapter with the rxd and txd ?
i also tried different usb rs232 adapters with different chipsets.
ALSO can anyone please share their menu settings for the pc410 (when you press and hold the PAR/SET Button so Adress bAud all values please)
Thanks a lot and hopefully i will get it to work some dayLeave a comment:
Ps- sorry for the writing.Leave a comment:
Does your ch340 get recognized by the OS? Going from memory here, IIRC, you have to download a driver for the ch340, there aren't "certified" drivers for them. Has been so long since I have been using this chips for a very long time, I don't quite remember what I had to do to get them owrking.
Glad you got it working though!Leave a comment:
Some links if you want to read up more on what clearchris mentioned:
https://zeptobars.com/en/read/FTDI-F...is%20deep-down
http://hackaday.com/2016/02/01/ftdi-...e-chips-again/
The original schematic of the achi ir pro sc V1, the pin top to the right is ground, the left top pin is TX and the bottom pin is RX.
In my achi pro the Right top pin is RX and the left top pin is ground and the bottom pin is TX. I made the 3-pin din cable with GX12 plug to female rs232 plug as I could not find any to buy. I acquired the second hand BGA working station about 3 months ago and all going well.
I have attached pictures if that can be of any help to others. I do not really need to connect to pc for it to work but can be useful when learning to get better. I can save profiles and tweak them to suit certain board. Easy to send and upload profiles.
Mine is working and so the quest for me stops here and hope someone can find a better way and solution to make the psoft software work easily with laptop or pc.Leave a comment:
http://hackaday.com/2016/02/01/ftdi-...e-chips-again/Leave a comment:
there is no logical process in this.
I bought several usb to rs232 serial converters and they all failed although they were all recognised as com port.* I bought the Digitus USB 2.0 to serial convertor FTDI chipset, Ugreen usb* to rs232 serial cable with PL2303 chipset, Dtech 3 pin to usb to TTL serial and finally usb to rs232 XTVTXb pl2303HX to TTL.
None of them worked when plugged in directly win 11 and in my good old reliable Sony sve1713z1eb win 10. However, connecting to my very old pc in win 7 directly in rs232 port, it connected and worked but glitchy in win 7 and did not work on another PC with win xp
These cables will work under linux just fine as FTDI and Prolific did not write those linux drivers and did not black list the fakes. They may also work on older windows systems that did not get newer drivers that black list the fakes. Older windows systems also may not support the newer chips like XP and pl2303HX IIRC.
The solution is to just buy ch340 adapters. They are cheap chinese chips, and no one is faking them.
Sucks for FTDI and Prolific, they were losing revenue from the fakes, but I just will not buy any of their products because there's a (high) risk of getting a blacklisted fake. Arduinos pretty much all moved away from using the fake chips in favor of the ch340 chips, but the fake chips are still very much present in usb to TTL adapters.Last edited by clearchris; 07-17-2022, 09:56 AM.Leave a comment:
*After giving up on the the 2 laptops, and after many days have passed I was reaching for something on a shelf an old usbV1 hub fell in front of me and I picked it up and I said let me try to connect that to my laptop and to the achi pro* sc V1 and to my astonishment it worked on both latops.** I was very happy and started to ponder why is it working via the usb hubs but not directly via the latops usb ports and in my view very strange. I thought may be it is to do with drivers of the PC410 or win drivers. I cannot explain and I do not know the answer. I eventually found out that it does work via usbv2 hub too.
The way I connect via the laptops, I ensure port settings in device manager match the port settings in psoft menu then first tab, configure com port. I connect cables to Achi pro first and then connect cable to laptop using an ordinary usb to rs232* serial converter to the USB v1 hub, from USB hun to pc, start laptop wait for it to boot to windows, I then switch on achi pro then open psoft and voila it works. When it connects the com port in psoft flashes green intermittently and on pc410, com flashes red intermittently. It can be temperamental too and If it does not work repeat the process switch off Achi and close psoft and start again and try in another port. It does work 99% of the time in my case.
I would also check inside the Achi which wire is ground, rx and tx to Din rs232 port (mine) or usb port may be in Achi v2, v3 and v4. Mine was different to the schematics which I found on a utoob video. There is no logic in this, I am merely sharing my experience.Leave a comment:
Hi sir maybe you can help me out. https://www.badcaps.net/forum/showthread.php?t=97677. It's easy to remove the controller you just press a tab on the right side and pull the unit out. Just make sure you don't plug it in the wrong direction like I did.Leave a comment:
The landing page for these modules:
http://altec.cc/english/products/tem...c900/PC900.htmLeave a comment:
Perhaps we can help.
We have been designing I/O adapters with 232/422/485 for the past 30+ years.Leave a comment:
Hi Pronester,
i have the same problem and my connection is via RS232 to USB ?
have you found the solution ?
Can you give me feedback
thxLeave a comment:
From what i see that's precisely his mistake, imho.
The CH341 based is an USB to Serial converter, not an USB to RS232 converter!
[@pronester see here how Serial and RS232 are different, already mentioned by @R_J]
Therefore PC410 won't acknowledge connection.
Either use the motherboard COM port or a truly USB to RS232 converter.Leave a comment:
If the pc has an rs232 port, just use that instead of a usb to rs485 adaptor, It looks like the PC900 series (PC-410) will work with rs232, rs422 or rs485, One parameter that can be changed on the controller is the baud rate, so check what it is set to and match it.
acording to the ORDER CODE it could also be that the pc-410 is preconfigured for a certain communication configuration so check its complete part numberLeave a comment:
by VaNDAL_UKHi,
Anyone know how to get the Altech PC410 to initiate a P.I.D Tune?
I can see the option, turn it on and it just flashed "tune" but nothing happens. Even tried running a profile after selecting tune.
I remember doing it years ago on another machine but for the life of me I can't work it out this time.
TIA. -
by mr.DataI tried installing the software that came with this new IR6500 but I get a C++ undefined error so I am stuck with non working software.
Tried downloading this software:
https://www.badcaps.net/forum/troubl...nicate-with-pc
It did not open as well.
Anybody with an IR6500 that can help me out a little bit?... -
REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
- No Clean Formulations
- Low residue
- Range of activity to deal with different component solderability
- Halide free
- Suitable for dispensing
- Compatible with solder coatings and/or No Clean flux cored solder wire product range
Both products are supplied in syringes or cartridges for application by dispensing....-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:02 AM -
by learnmoreHello Community,
Based on your experiences and knowledge, which BGA Rework stations would you recommend for general use for an enthusiast at the low-mid-to-high price range? Based on what I've seen, £6000 may be considered high. I particularly like those with adjustable focus, built-in suction and ball alignment features, but I appreciate that they may be on the high end.
Also any thoughts on the PUHUI T-862++ IR Rework Station, LY GXX models, WDS-XXX models? -
by yuzupatogikHello,
I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
I can't find datasheets for the Samxon in any of the following variants:
10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...-
- Loading...
