Help with replacing Capacitors on Altec Lansing ATP 3
  • yuzupatogik
    Banned
    • Feb 2025
    • 18
    I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
    I can't find datasheets for the Samxon in any of the following variants:
    10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and order some to replace the rest.
    10uF 25V
    100uF 25 V
    1uF 50V
    0.47uF 50V
    2,2 uF 50V
    0,1 uF 50V
    4,7 uF 50V
    47uF 16V
    470uF 16V
    0.68uF 50V
    Now, can i just replace them with some Nichicon UFG/Rubycon/Panasonic FR/FM? If so, what Series?
    If anything, could you please provide some generic tips like ripple current, ESR ballpark values?
    Thank you!
    Click image for larger version  Name:	IMG_20250214_011006.jpg Views:	0 Size:	978.6 KB ID:	3571915 Click image for larger version  Name:	IMG_20250214_011035.jpg Views:	0 Size:	944.3 KB ID:	3571916 Click image for larger version  Name:	IMG_20250214_011157.jpg Views:	0 Size:	821.0 KB ID:	3571917 Click image for larger version  Name:	IMG_20250214_013210.jpg Views:	0 Size:	1.48 MB ID:	3571918 Click image for larger version  Name:	IMG_20250214_011054.jpg Views:	0 Size:	1.10 MB ID:	3571919 Click image for larger version  Name:	IMG_20250214_011202.jpg Views:	0 Size:	967.5 KB ID:	3571920
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Judging by the rather big capacity of that 10000 uF bulk filter cap, it looks like this system uses a linear (line-connected) AC transformer... so none of the caps have to be low-ESR / low impedance, or anything special. Just get quality Japanese-made 85C or 105C caps, and all should be OK. That said, I find that some low-ESR series are usually cheaper than the general purpose 85C or 105C parts. In cases like that, you can go with the low-ESR series. But I wouldn't bother looking at datasheets for this kind of application. So long as you stick with the known good Japanese brands (Rubycon, Panasonic, Nichicon, and United Chemicon), you shouldn't have to do this type of repair for at least a 2-3 more decades.
    Now, if you really want to go "all-out" on this, some of the pre-amp circuits in this unit might behave "better" with audio-grade caps - particularly with small caps in the signal path, as audio-grade caps tend to have lower leakage current and thus should be less noisy/hissy (in theory anyways!) I personally don't think one would be able to notice any appreciable change in sound with these IC-based audio systems, so I tend to use whatever caps are the cheapest usually (but good quality brands, nonetheless.)
    That being said, I don't know if new caps will cure the line hum, if it's very very faint. At least from my own Altec Lansing VS-4142, it appears that the slight hum is due to poor PCB routing design. But if you have more-than-subtle line hum, then most likely either the big cap or any "ripple filter" caps for any of the power amps might be going bad. Another thing that could cause hum are poor solder connections, especially on an old system like this that's been through a lot of use... so give all the solder joints a thorough check. Any resistors that run hot are most likely to be affected... though I don't really see any on your board (for once a not-so-terrible design, I suppose ).
    Anyways, have fun recapping and let us know how it goes.
    *edit*
    By the way, for the 0.1 and 0.47 uF electrolytic caps, consider replacing them with metal film polypropylene type capacitors. These are generally considered better for audio-signal circuits (but again, I can't say if it would be worth it on a system like this.)
    • Tyran
      Replacing capacitors on a 12v 5000w Pure Sine Inverter .
      by Tyran
      Greetings folks. I darn near blew the heck out of my 12V inverter the other day by connecting it to a 24V battery source. :poof . Well lesson learned...... or maybe not . But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
      04-22-2022, 08:26 AM
    • frannyjunk
      Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
      by frannyjunk
      Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
      Any thoughts if OK to use these higher voltage capacitors?
      11-04-2021, 05:59 PM
    • dragon3x
      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
      by dragon3x
      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
      power on.
      Here are some examples :
      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
      switching supply area).
      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
      than 6.3 V.)
      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
      I replaced capacitors with aluminum-polymer.
      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
      03-21-2025, 02:46 PM
    • r-p
      Maldischarge-link that fixes it with replacing caps
      by r-p
      Starting this thread because Capkid doesn't seem to be reprogramming controlboards anymore (LG 60PZ950 with red maldischarge) and my game-plasma also has maldischarge (Hitachi 42PD3200). So I will grasp at straws to keep them running. I am extremely bad at throwing stuff away.
      Is there any merit to this link?
      Very short version: Specific caps seem to loose their capacitance and/or increase their ESR. This may cause the maldischarge. Replace them with better/bigger/newer ones and problem solved.
      From the limited knowledge I have on the subject, I think...
      01-21-2020, 05:16 PM
    • Oldschool297
      KM400-M REV 1.0B Socket 462. Replace capacitors.
      by Oldschool297
      I got a bluescreen error in Windows Vista Ultimate and after a restart i got Bios checksum error and A: error. I do not have a A: drive. Now the screen only is black, the fans and harddrives start but the screen is black. I tried my graphic card in another computer and it worked. I also tried to remove the memorys. Can it be the bios or caps? It start with the bad caps but no screen is visable. There are 6 bad 6.3v 1000uf. I got 6.3v 1500uf but i guess these won't go?...
      08-10-2023, 04:27 AM
