ACHI IR6500 getting it to work
  • mr.Data
    • Sep 2018
    • 75
    • Netherlands
    I tried installing the software that came with this new IR6500 but I get a C++ undefined error so I am stuck with non working software.
    Tried downloading this software:
    https://www.badcaps.net/forum/troubl...nicate-with-pc
    It did not open as well.
    Anybody with an IR6500 that can help me out a little bit?
  • GlennB1975
    • Mar 2024
    I have the same issue, i tried downloading directly from the ACHI website but it didn’t work, I believe there are so many clones of this machine its probably something to do with no being genuine, mine did come with a disk but i need to check what’s on that before i write mine off as not working properly.
    • mr.Data
      • Sep 2018
      • 75
      • Netherlands
      I setup manually and it works although I don't think it's worth the money. When I set the bottom heater at max of 420 degrees the motherboard only gets to 80 degrees after 20 minutes
      • kurtsta11
        • Sep 2022
        • 5
        you need a transformer to be able to get the temperature up
        • hollox123
          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
          by hollox123
          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
          1. Laptop keyboard doesn't work
          2. The backlight on the laptop keyboard doesn't work
          3. The x2 side LEDs (red) on the laptop don't work
          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
          But I am strongly aiming that it is somehow a BIOS-related problem,...
          05-11-2025, 08:05 AM
        • chrislyons
          help with achi ir6500 profiles
          by chrislyons
          hello i am looking for profiles heat settings for this bga station achi ir6500 .at momemt its just ps4 thank you
          05-19-2021, 03:35 AM
        • resistor83
          lenovo 330s-15ikb, led num lock key always on and numbers don't work
          by resistor83
          hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
          I tried updating the bios but the problem remains
          https://s...
          05-29-2025, 08:06 AM
          DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
          I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
          If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
          One —>the LEDs might be bad
          Two —> the buck converter or regular might be bad
          Three —> the controller might not...
          08-08-2023, 05:12 PM
        • Rhaverz
          My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
          by Rhaverz
          Good afternoon friends
          I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
          I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
          I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
          03-30-2023, 03:56 PM
