Multifix 425-01 and 450-01 Rework Flux Datasheet
  • Boardview and Schematic Bot
    • 116876
    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
    - No Clean Formulations
    - Low residue
    - Range of activity to deal with different component solderability
    - Halide free
    - Suitable for dispensing
    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
    Both products are supplied in syringes or cartridges for application by dispensing. The user should select the product most appropriate to the application.
    Multifix 450-01 leaves visible but clear residues that do not require cleaning. It has good activity for rework operations.
    Multifix 425-01 is less active. However, the residues are clear and barely visible while soldering activity is still sufficient for many users.
    RECOMMENDED OPERATING CONDITIONS
    There are many applications for these products and users may find that their own process requires particular conditions. The following information can therefore be for guidance only.
    The main function of these fluxes is threefold. They provide a thermal pathway from the heat source to the workpiece, ensuring that it is evenly heated. The viscous fluid protects metal surfaces from rapid oxidation at soldering temperature and, finally, they break down surface contaminants to allow solder spread. On tin/lead surfaces, this may be a purely physical effect causing oxide skins to flow away from the molten coating but chemical dissolution may also be required.
    Where a component is to be soldered into place for the first time, the alloy for the fillet may be provided by the fusible coating on the PCB and to some extent, on the component termination. The PCB may be of conventional design or it can be specially fabricated with a flat, thick solder coating (eg. produced by the Solid Solder Deposition (SSD) process). In either case, Multifix 425-01 and Multifix 450-01 will provide a sufficiently tacky surface to hold the component in place.
    When a component is to be soldered to a board having little or no fusible coating, it may be necessary to use Multifix 425-01 or Multifix 450-01 to clean the surface to be joined.
    Solder for the joint is supplied by wire which may be solid or flux cored. If flux cored wire is used, it is recommended that the low residue product Multicore X39 is selected since the residues from this material are minimal and totally compatible with both of these Multifix products.
    Where components have been removed from a PCB, it is important to prepare the site for the replacement device in order that the resoldering process can be carried out efficiently. Excess solder should be removed from the PCB with Multicore MCF800.
    Desoldering Wick and areas showing abnormally high levels of oxidation may benefit from pretinning.
    In all cases, a variety of heating methods may be used to produce a solder joint with these products. These include soldering irons, hot gas and hot bar devices, condensation reflow and IR/convection reflow. Specialist tools and workstations are available to assist operators but skill will often be required to adapt these to particular situations. Both Multifix 425-01 and Multifix 450-01 are tolerant of a wide range of temperature profiles and any residues left after reflow will be hard, clear and non-tacky.
    Our boardview and schematic bot.
