ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
    • 31269
    ESR meter upgrades
    so - rotary encoder time.
    get your rotary encoder and bend and trim the center pin so it sits on the top of the board - like this:
    • 31269
    Re: ESR meter upgrades
    next, take the original switch off, and scrape some laq off the top of the pcb for the center pin like this:
    (only for this model of meter)
      • 31269
      next, solder the encoder in,
        • 31269
        next you need a pair of 1k resistors and a pair of 10k resistors and some thin wire.
        just to be clear, the place the 10k resistors join the wire is NOT connected to the pcb!
          • 31269
          next you need to link the 2 cpu pins to the resistors.
          WARNING - this is pro-soldering!
            • 31269
            if you do it clean, it should look like this:
              • 31269
              back to the top of the pcb,
              solder the center tab of the encoder to the ground-point you remembered to scrape-clean on the pcb.
                • 31269
                2 foto's i had left.
                  • 31269
                  and does it work?
                  NO - i have to compile new firmware first.
                  still, the hardware is done now.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    Thank you for the walk through!
                      • 31269
                      AND - IT'S HERE!
                      latest firmware compiled for this model by me.
                      with rotary encoder, new fonts/gfx, serial-port etc.
                      • elval
                        • Nov 2015
                        • Hrvatska
                        Thank you
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          what extra functions does this firmware/encoder mod gain?
                            • 31269
                            depends.
                            if your tester is pretty new and id's as 1.12k then nothing really, just a lot easier to use the menu function.
                            if your tester is old and running 1.11k or older then probably lots of new stuff.
                              • 31269
                              i am going to be making some updates to that file.
                              just saying.
                                • 31269
                                update:
                                btw, i'm willing to compile this for the T3 / T4 boards if asked.
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  Thank you man. You're sure to be on Santa's nice list for this
                                    • 31269
                                    bugfix.
                                      • 31269
                                      config fix.
                                      previous builds wont read inductors properly.
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        There is one thing ESR meters should have, which is Kelvin sensing (4-wire measurement capability), which keeps measurement errors to a minimum.
                                        • chth96
                                          by chth96
                                          03-09-2024, 10:03 PM
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          by jorpec
                                          Hi
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • irepair559
                                          ps4 1215 model Changed port and encoder still no video?
                                          by irepair559
                                          hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                          Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                          ps4 seems to boot fine blue light then solid...
                                          01-01-2023, 12:41 AM
