ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
    • 30979
    Re: ESR meter upgrades
    that looks like aT3,
    it should work on it.
    put a 16MHz crystal on it - that will give it a good upgrade.
    • bc989
      • Oct 2015
      • 21
      • Asia
      #142
      Its pretty hard to ID them, most T3 google images show the battery cables under the LCD, but there are still a couple of differences to mess it all up.
      Anyhow, great! I'll likely test with the 8MHz first. And while waiting for the rotary encoder, can I go ahead and flash the test file first? Will basic functions still work with the std button?
        • 30979
        test file is o.k. but dont go into the menu - you will get stuck.
        • bc989
          • Oct 2015
          • 21
          • Asia
          #144
          Just in case, I need to revert or reflash back to recover... are there any dump of the original factory default software/firmware that came with these T3/T4?
            • 30979
            there is this, but i dont think it's original
            https://yadi.sk/d/yW8xa5NJgUo5z/LCR-T4(T3)
            • GoNz0
              • Sep 2012
              • 28
              #146
              Hi all, is this one any good to get ? gm328rhttp://www.ebay.co.uk/itm/2016-EZM32...sAAOSwtJZXU~VA
              or should I get the gm328a? http://www.ebay.co.uk/itm/2015-versi...kAAOSwHnFV2EJw
              Thanks.
                • 30979
                the 2016 328R looks good.
                rotary encoder etc already fittted.
                if they had put a programming header on it, it would have been perfect!
                another good option is the banggood unit that has an optional case.
                http://www.banggood.com/DIY-M12864-G...-p-997023.html
                or the case may fit the ebay model.
                i hope you notice they are both KITS you need to build.
                • GoNz0
                  • Sep 2012
                  • 28
                  #148
                  Yep so long as they come with destructions I am fine with soldering & would rather save the fiver along with an excuse to get the solder station out
                  Can either have a header fitted for programming should I need it later down the line?
                  initial use will be testing caps on my broken UPS.
                  Thanks for helping.
                    • 30979
                    you can put a header on with jump wires - unfortunatly they didnt route the tracks to any pads for one.
                    i'v said this to people before, but put a good 16MHz crystal on it.
                    you will increase the accuracy, and enable the crystal/resonator tester.
                    (needs a software upgrade.)
                    on that subject - if you dont have a programmer yet.
                    http://www.ebay.co.uk/itm/272041588746
                    • GoNz0
                      • Sep 2012
                      • 28
                      #150
                      So the bangood DIY M12864
                      USB Programmer
                      And what 16mhz crystal do you suggest -/+10ppm I saw a few pages back?
                      Thanks.
                        • 30979
                        yep, and not a full 49' type, a low profile one.
                        you can probably salvage one from some junk
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          How difficult would the build be for an electronics amateur like myself ? (AKA how good are the instructions, if there are any)
                          better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                            • 30979
                            how should i know - i dont know your skills or equipment.
                            so what iron and experience do you have?
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              Soldering not the concern, rather assembly of components to PCB, what goes where
                              No need to respond further, found one of the reviewers had posted assembly video
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #155
                                can you link the video? as i may look into this upgrade too many thanks.
                                • bc989
                                  • Oct 2015
                                  • 21
                                  • Asia
                                  #156
                                  Before I reprogram my T3, I traced the programming pad and found the RESET pad is not connected to the atmega328 reset pin. Instead it goes to pin 30 (rxd/pcint16/pd0) see attached pic.
                                  Shouldn't the programming pad RESET be connected to pin 29 (RESET)?
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    https://www.youtube.com/watch?v=rSLW...ature=youtu.be
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #158
                                      thanks theres some good videos on his page.
                                        • 30979
                                        can you double-check those pads, they use that to program them after assembly.
                                          • 30979
                                          about that video - NEVER BEND THE FUCKING WIRES OVER.
                                          it makes stuff much harder to remove again without damaging the pads.
                                          damn i hate these amateur video's teaching people bad stuff.
                                          and make sure you use 99% IPA to remove all the flux afterwards.
                                          it may not seem important usually, but on something like this, it can effect the readings!
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
