ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #621
    Re: ESR meter upgrades
    Originally posted by stj
    well i just built this.
    this is for the COLOUR-TFT KIT. and will be known as "AY-AT" because it's printed on the pcb.
    this is tested btw.
    bmht, mr Hansson - you want to flash this.
    Did you make any other mods to this tester stj other than the cut out fot the header.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #622
      this is tested btw.
      AY-AT ESR tester (SVN684).zip
      Mine is the mega328_st7565, not the mega328_color_kit.
        Great Sage é½Šå¤©å¤§č–
        • 31183
        just used an lm4040 instead of the tl431
        they REALLY need a 16MHz crystal though - the screen update is soo slow you can see it refresh the image!
          • 31183
          i just realised that.
            • 31183
            new manual - lots of updates.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #626
              Thanks stj for the newer manual some very good information in it.
                • 31183
                fixed a bug in the frequency generator.
                • Dutch52
                  Retired
                  • Aug 2016
                  • 9
                  • Netherlands
                  #628
                  i just built a TFT tester kit for a guy, and the test socket is defective - the contacts dont open!!
                  has anybody else seen bad test sockets??
                  Yes, I have had a few bad ones. Point is, that it is a cheap fabrication.
                  But the good thing is that you can repair them.
                  Loose the 2 little screws on the above side, remove the top plate and handle
                  and re-adjust the contactplates, so that they are all wide open.
                  Carefully place all the parts back, with a bit of 'feeling' it should work.
                  regards,
                  Willem
                    • 31183
                    a warning i just discovered:
                    the datasheet for the LM4040 has the TO-92 package pinout wrong!!!!!!!
                    it states "view from above", but the pinout is actually from below.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #630
                      ive just fitted one to my old version tester that came in todays post that im just upgrading is this data sheet the right one?
                      https://cdn.badcaps-static.com/pdfs/...757ef4e1ec.pdf
                        • 31183
                        interesting.
                        THAT pdf is correct.
                        revision H.
                        the one i had that is wrong is revision J
                        so they had it right, and then messed it up!!!
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #632
                          my 2016 tester ive fitted it wrong so i need to order some more.
                            • 31183
                            did you cut the pin off?
                            you should bend it out of the way and test the device.
                            if you hold it pins down, and flat face pointing towards you,
                            the unused pin is the left one.
                            how you know it works, if you start the tester and it only gives the battery voltage, it's not working.
                            if you also get the regulated voltage (5.00v) then it works.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #634
                              yes cut the pins off dosnt matter will order some what voltage was they im sure the ones you linked was 2.5v if i remember rite?.
                              Edit just found your link in post 224 will order some now
                              http://uk.rs-online.com/web/p/voltag...ences/5343037/
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #635
                                stj my old version tester came today i have up graded the atmega ic added a 16 mhz crystal and 2 capacitors (as non installed on the pcb) added the 2 capacitors between vcc and ground pins also added the header and the voltage regulator so what i need to do tomorrow is add the firmware i have avrdude installed now and have this command?
                                avrdude -c USBasp -P usb -p m328p -U flash:w:TransistorTester.hex \-U eeprom:w:TransistorTester.eep \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
                                now where do i add the hex files etc too? do i copy them to the avr programme folder?
                                  • 31183
                                  try both of these,
                                  tell me which works.
                                  to use avrdude, put the hex files in the same folder you use the commandline from - or use avrdudess
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #637
                                    try both of these,
                                    Hi stj ive tried to load the firmware using avrdude i use command
                                    now when i turn the tester on the screen lights up with no data on it then after a few seconds the screen flashes on and off (strobing effect) and power led on tester is flashing i can see in the enclosed picture the fuses have been set wrong? i have also tried both your files and both do the same? thanks vince
                                      • 31183
                                      that screen pic shows only the flash being programmed, not the eeprom or fuses.
                                      try 3 seperate lines in order:
                                      avrdude -c USBasp -P usb -p m328p -U eeprom:w:TransistorTester.eep
                                      avrdude -c USBasp -P usb -p m328p -U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #639
                                        using that method seems to work tried both of your files the strip grid does nothing really just lights the screen with some odd blocks now the first file seems to work says battery ok then testing then timeout! then goes off
                                        • Dutch52
                                          Retired
                                          • Aug 2016
                                          • 9
                                          • Netherlands
                                          #640
                                          The long line copy & paste for avrdude got me in trouble too.
                                          Earlier I did this without problem (using Windows 7 SP1 and Windows 10 v1511 (10586))
                                          Now I have Windows 10 Anniversary Update (14393) I have this too.
                                          I have now switched to ARVDUDESS which works fine.
                                          Anyone who can confirm this behaviour?
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
