ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #521
    Re: ESR meter upgrades
    Originally posted by stj
    i dont know where you got the command for USBasp from,
    try this:
    and try these files:
    copied from eevblog stj just in case you havnt saw it
    I will try to program the chip based on what I have already read with an USBASP
    I got a question if anyone knows
    it is really necessary to use a 8 Mhz Crystal for program the chip with the USBASP? The only one I got now is the one on the component tester and I have to desolder that to be able to program the chip, then solder back again again to test and so on.
    Or I can desolder the Crystal and solder a 16 Mhz Crystal in the tester? I do have spare 16 Mhz Crystals.
    But from where I live there is no electronics shops open for the weekend so I will have to wait until next Monday or go through the soldering desodering procedure.
    Belen
      • 31269
      to program an atmel, you must have all the power pins powered - there are more than 2,
      and you must have a clock running - it dont have to be 8MHz, it can be anything within range of the chip.
      so 1-20MHz - is fine.
      that's why it's best to program them in-circuit - all that is already taken care of.
        • 31269
        btw, that tl866cs of yours, i think that can do in circuit programming using a cable from the connector on the end.
        if i remember, the CS has the connector - the non-cs does not, just a blanking plate.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #524
          my tl866 just has a blanking plate stj but has loads of adaptors in the box and bag
          as per your post above for the new member i was trying to find a picture of the header and the ic wiring maybe you have one you can upload as im on my phone at the minute.
            • 31269
            you should upgrade your programmer.
            http://blackstufflabs.com/2013/11/18...l866a/?lang=en
            http://www.eevblog.com/forum/blog/ee...rammer-review/
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #526
              Thanks stj yes i have saw that video already it looks a good tool and thanks for the link i might consider the upgrades at some points i need to collect some more projects too work on as have none at the minute (well one a psp needs a replacement shell fitting but the china one provided looks rubbish quility so been putting this job off)
              • bmht
                • Jul 2016
                • 37
                • Venezuela
                #527
                I saw your post on eevblog are you programming the chip on the esr pcb? though a fitted header?
                Dear Vince thank you
                I removed the chip from the transistor tester and inserted it into a PCB
                I'm programing the chip using an USBASP and the procedure as described in here
                http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg810893/#msg810893
                I will retry now with the code provided by sjt and will right away post results
                Again many thanks to you for refering me here and sjt and other members helping me with this issue
                Belen
                • bmht
                  • Jul 2016
                  • 37
                  • Venezuela
                  #528
                  Dear guys
                  I got somehow a success
                  I was able to upload the firmware and now the display stays lit ans the led too but still nothing shows on the display just blank
                  This was my result o the programming
                  Code:
                  C:\AVR>avrdude -c USBasp -P usb -p m328p -U flash:w:Code.HEX \-U eeprom:w:Data.H
                  EX \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
                  avrdude: AVR device initialized and ready to accept instructions
                  Reading | ################################################## | 100% 0.01s
                  avrdude: Device signature = 0x1e950f
                  avrdude: NOTE: "flash" memory has been specified, an erase cycle will be perform
                  ed
                       To disable this feature, specify the -D option.
                  avrdude: erasing chip
                  avrdude: reading input file "Code.HEX"
                  avrdude: input file Code.HEX auto detected as Intel Hex
                  avrdude: writing flash (29702 bytes):
                  Writing | ################################################## | 100% 18.81s
                  avrdude: 29702 bytes of flash written
                  avrdude: verifying flash memory against Code.HEX:
                  avrdude: load data flash data from input file Code.HEX:
                  avrdude: input file Code.HEX contains 29702 bytes
                  avrdude: reading on-chip flash data:
                  Reading | ################################################## | 100% 11.40s
                  avrdude: verifying ...
                  avrdude: 29702 bytes of flash verified
                  avrdude: safemode: Fuses OK (E:01, H:DF, L:F7)
                  avrdude done. Thank you.
                  and this is how it is now
                  I'm sorry for the clips on the side but those were the cables I soldered to be able to attach and detach the crystal I did not knew I could use a 16 mhz one until today and I had already took that one out.
                  Meanwhile I receive an answer I'm going to solder the crystal back onto the tester.
                  Thank you all again
                  Belen
                  Last edited by Per Hansson; 06-16-2022, 02:02 PM. Reason: Added CODE tags, uploaded offsite image
                    • 31269
                    go do it again - the fuses didnt get programmed.
                    copy & paste from this:
                    • bmht
                      • Jul 2016
                      • 37
                      • Venezuela
                      #530
                      Dear
                      I reflashed and now the display stays lit for about 4 seconds and then display and led turns off.
                      Keep in mind that my files ransistorTester.hex are from
                      https://www.mikrocontroller.net/svnb...28_st7565_kit/
                      Code:
                      C:\AVR>avrdude -c USBasp -P usb -p m328p -U flash:w:TransistorTester.hex \-U eep
                      rom:w:TransistorTester.eep \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xf
                      c:m
                      ed
                      avrdude: reading input file "TransistorTester.hex"
                      avrdude: input file TransistorTester.hex auto detected as Intel Hex
                      avrdude: writing flash (29952 bytes):
                      Writing | ################################################## | 100% 19.04s
                      avrdude: 29952 bytes of flash written
                      avrdude: verifying flash memory against TransistorTester.hex:
                      avrdude: load data flash data from input file TransistorTester.hex:
                      avrdude: input file TransistorTester.hex contains 29952 bytes
                      Reading | ################################################## | 100% 10.39s
                      avrdude: 29952 bytes of flash verified
                        • 31269
                        it's not programming your H & E fuses.
                          • 31269
                          try just typing these individually:
                          avrdude -c USBasp -P usb -p m328p -U lfuse:w:0xf7:m
                          avrdude -c USBasp -P usb -p m328p -U hfuse:w:0xd9:m
                          avrdude -c USBasp -P usb -p m328p -U efuse:w:0xfc:m
                          • bmht
                            • Jul 2016
                            • 37
                            • Venezuela
                            #533
                            Would you advice for me to use a blank chip?
                            Maybe the chip is broken
                            How do I verify if it's programming the fuses or not?
                            Thanks again
                            Belen
                            • bmht
                              • Jul 2016
                              • 37
                              • Venezuela
                              #534
                              Code:
                              C:\AVR>avrdude -c USBasp -P usb -p m328p -U lfuse:w:0xf7:m
                              avrdude: reading input file "0xf7"
                              avrdude: writing lfuse (1 bytes):
                              Writing | ################################################## | 100% 0.01s
                              avrdude: 1 bytes of lfuse written
                              avrdude: verifying lfuse memory against 0xf7:
                              avrdude: load data lfuse data from input file 0xf7:
                              avrdude: input file 0xf7 contains 1 bytes
                              avrdude: reading on-chip lfuse data:
                              Reading | ################################################## | 100% 0.00s
                              avrdude: 1 bytes of lfuse verified
                              Code:
                              C:\AVR>avrdude -c USBasp -P usb -p m328p -U hfuse:w:0xd9:m
                              avrdude: reading input file "0xd9"
                              avrdude: writing hfuse (1 bytes):
                              avrdude: 1 bytes of hfuse written
                              avrdude: verifying hfuse memory against 0xd9:
                              avrdude: load data hfuse data from input file 0xd9:
                              avrdude: input file 0xd9 contains 1 bytes
                              avrdude: reading on-chip hfuse data:
                              avrdude: 1 bytes of hfuse verified
                              avrdude: safemode: Fuses OK (E:01, H:D9, L:F7)
                              Code:
                              C:\AVR>avrdude -c USBasp -P usb -p m328p -U efuse:w:0xfc:m
                              avrdude: reading input file "0xfc"
                              avrdude: writing efuse (1 bytes):
                              Writing |                          | 0% 0.00s ***faile
                              d;
                              Writing | ################################################## | 100% 0.04s
                              avrdude: 1 bytes of efuse written
                              avrdude: verifying efuse memory against 0xfc:
                              avrdude: load data efuse data from input file 0xfc:
                              avrdude: input file 0xfc contains 1 bytes
                              avrdude: reading on-chip efuse data:
                              avrdude: verification error, first mismatch at byte 0x0000
                                   0x04 != 0xfc
                              avrdude: verification error; content mismatch
                              avrdude: safemode: efuse changed! Was fc, and is now 4
                              Would you like this fuse to be changed back? [y/n] y
                              And it does nothing else...
                              APPARENTLY last fuse can not be written
                              I'm going to use a blank ship and I will report back
                              Thanks again
                              • bmht
                                • Jul 2016
                                • 37
                                • Venezuela
                                #535
                                This is crazy
                                I have changed for a blank chip and now it says
                                Code:
                                c:m
                                avrdude: error: programm enable: target doesn't answer. 1
                                avrdude: initialization failed, rc=-1
                                     Double check connections and try again, or use -F to override
                                     this check.
                                I'm going to use an Arduino as ISP programmer and report back
                                • bmht
                                  • Jul 2016
                                  • 37
                                  • Venezuela
                                  #536
                                  I'm getting a bit frustrated in here...
                                  With arduino as ISP programmer both the chip that came with the tester and a new black chip I get this
                                  Code:
                                  C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -C ../etc/avrdude.
                                  conf -c avrisp -P COM3 -b 19200 -p m8 -U flash:w:TransistorTester.hex \-U eeprom
                                  :w:TransistorTester.eep \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
                                  Reading | ################################################## | 100% 0.04s
                                  avrdude: Device signature = 0x000000 (retrying)
                                  Reading | ################################################## | 100% 0.03s
                                  avrdude: Yikes! Invalid device signature.
                                       this check.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #537
                                    this check.
                                    sorry but i have not used avrdude etc yet for my ic i used a tl866 programmer the only other way that may work is adding the header and soldering wires direct to the ic socket etc, stj has some pictures regarding this as im also going to try programming this way myself in the future using avrdude etc but im reading up on the programming side of things at the minute.
                                    just a thought with your crystal are you using 22pf capacitors as well? when your programming the ic
                                      • 31269
                                      this is exactly the type of bullshit that happens when people try to program chips off-board instead of in-circuit.
                                      btw:
                                      d;
                                      0x04 != 0xfc
                                      is a newer chip, 04 instead of FC is fine.
                                      so with that chip, do:
                                      avrdude -c USBasp -P usb -p m328p -U efuse:w:0x04:m
                                      • bmht
                                        • Jul 2016
                                        • 37
                                        • Venezuela
                                        #539
                                        I rebooted the computer and connected the arduino to another USB port and now I'm getting this using Arduino ISP as programmer.
                                        Code:
                                        conf -c avrisp -P COM3 -b 19200 -B8 -p m8 -U flash:w:TransistorTester.hex \-U ee
                                        prom:w:TransistorTester.eep \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0x
                                        fc:m
                                        avrdude: Expected signature for ATmega8 is 1E 93 07
                                             Double check chip, or use -F to override this check.
                                        • bmht
                                          • Jul 2016
                                          • 37
                                          • Venezuela
                                          #540
                                          Dear sjt I really appreciate all your help and I'm sorry if I seem stupid or dumb in here.
                                          I'm trying to learn in here and I got no clue of AVR programming besides arduino. I'm learning and reading as much as I can to be able to fix this issue.
                                          To be able to program the chip in circuit I believe I would either have to solder some wires to the chip or have an ICSP header on the circuit right? which I do not have in this circuit.
                                          Thanks again for all your help
                                          Belen
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
