Re: ESR meter upgrades
I posted my message above also on eevblog, madires replied with:
My reply:
Aww thanks!
When I open the firmware file for the flash my programmer asks if it should be in Intel encoded format which I answer yes to.
Next for the EEPROM "data" window I simply used drag and drop.
It does not ask then about the format so I assumed it uses the same as for the flash.
Well turns out that is not what happens at all!
The files I've tested are named TransistorTester.hex for the flash and TransistorTester.eep for the EEPROM.
Well turns out if I rename the TransistorTester.eep to "Something.hex" it also does not ask about encoding format.
But it does then convert it to Intel encoded format!
And now while testing it some more to get some screenshots it always converts even the eep file to Intel hex without asking!
Murpy's law!!!
I do a manual erase, then power off and on, then blank check, then write each time I program the chip.
					Originally posted by madires
		Aww thanks!
Murpy's law!!!
