Sceptre X505BV-FMDR
  • BadGoo
    • Dec 2014
    • 22
    Sceptre X505BV-FMDR
    I have a Sceptre X50 TV that has no picture, but audio. It just went off instantly. There was no slow dimming or buzzing etc. Upon further investigation, I can see the picture using a flashlight on the screen. My question is, can I replace the power supply board to fix this or could it be the backlight inverter or both?
    Thanks for the help!
    Re: Sceptre X505BV-FMDR
    It could be either. Can you supply photos of the boards in the TV? https://www.badcaps.net/forum/showthread.php?t=39740
    • nomoresonys
      • 12123
      • U.S.
      if all your voltages are correct on ps it's probably the inverter board.
      • BadGoo
        • Dec 2014
        • 22
        Sorry for the extreme delay. The friend who I'm doing this for put it on hold and forgot about it. Here's where I'm at now. I still need to test voltages but here are the photos. Visually everything looks OK unless I'm missing something. Indicator lights, sound and picture is working (minus the backlights)
          Please upload the pictures of the whole back side of the TV so we can see how all the boards are connected together.
          • nomoresonys
            • 12123
            • U.S.
            disregard, jumped too soon, needs testing, may need to see if main is sending bl-on signal.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Originally posted by BadGoo
              My question is, can I replace the power supply board to fix this or could it be the backlight inverter or both[
              LED lit tv so No inverter board, possibly a Led driver board
              • nomoresonys
                • 12123
                • U.S.
                right, couldnt tell because op did not put type of tv in title.
                • willyam1
                  • Feb 2012
                  • 112
                  • israel
                  same problem in pilot 50''smart the power supply is AY160D-4HF01.
                  ALL VOLTAGE OK 12V 24V 5V 5VSTBY EXEPT NO VOLLTAGE TO THE LED BACKLIGHT BLON IS 4,65V OK
                  in the back of the p.s ther an ic BD9211F that drive the leds section. pin 1 vcc=11.8v pin 2 stby on /off 4.65v ther no pulses in the output pin 18+17 could be the bad ic?
                  • willyam1
                    • Feb 2012
                    • 112
                    • israel
                    did you manage to fix your tv?
                    • willyam1
                      • Feb 2012
                      • 112
                      • israel
                      anyone?
                      • nomoresonys
                        • 12123
                        • U.S.
                        another one of those NO FOLLOW UPS.
                        • willyam1
                          • Feb 2012
                          • 112
                          • israel
                          sorry was sick but what do you mean by NO FOLLOW UPS.
                          • nomoresonys
                            • 12123
                            • U.S.
                            it pertains to posters who never post back about their results, a lot of people fix their tv and never reply back, so other folks are just left hanging as to what the outcome was, which doesnt help anyone else with similar problem, who may have been following thread, as it appears badgoo has done here, no biggie, it just doesnt help any.
                            • willyam1
                              • Feb 2012
                              • 112
                              • israel
                              You are right but its not me i hope that i can fix mine and i will post the result thanks willyam
                              • marcoclo
                                • 2
                                • usa
                                I'm having the same issue ordered a new power supply that controls led light voltage with no result. My leds don't power on the TV still has sound with no backlight display I will be taking a better look this week to determine if maybe a led is shorted causing the backlight not to turn on.
                                • nomoresonys
                                  • 12123
                                  • U.S.
                                  looks like your on the right path, been reading many many posts about led light strings messing up one way or another. makes me want to stick with plasama or lcd for personal use.
                                  • willyam1
                                    • Feb 2012
                                    • 112
                                    • israel
                                    after replacing the ic that control the valltage to the led strings can see that the valltage is starting to rise and then falling slowlly but still no backlight i plugged out one of the 3 pluggs and put an externall led string and then tv works ther was a backlight. i shorted the plug tv works but ther a dark spot in the backlight
                                    the valltge is neggativ -234v
                                    willyam
                                    • BadGoo
                                      • Dec 2014
                                      • 22
                                      I apologize for the no follow up. The person's TV I was attempting to fix gave up and he just notified me that he will be giving me the TV all together for me to attempt to repair and keep. I'll post photos of the boards connected within a day or two.
                                      • BadGoo
                                        • Dec 2014
                                        • 22
                                        And he delivered quicker than I thought! Ok. Here's the wiring.
                                        EDIT: All voltages coming off the supply are correct.
                                        • howardc64
                                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                          by howardc64
                                          Problem
                                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                          Model & Board Pics
                                          Conflicting Spec
                                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                          https://www.shopjimmy.com/vizio-gj-2k1...
                                          10-10-2024, 01:16 PM
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
