Sceptre X505BV-FMDR
Re: Sceptre X505BV-FMDR
I ended up cancelling my order for MSD3393LUM and bought another MSD3393LU on ebay and replaced it.
The TV works just fine now.
So these chips are interchangeable.
The first one I bought was probably a fake from china.Comment
Suffix is often for the package type or denotes lead-free versions etc, but could be anything else as well, like voltage range or temperature. Without a datasheet it's hard to say.
I think some of those controller ICs need to be programmed, could be that yours was used or blank (or not blank), or programmed with wrong code (or fake, or broken pull, who knows) or even bad soldering.... so hard to tell with something that complex and no documentation.
Glad to hear you got it working in the end!"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
by howardc64Problem
Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
Model & Board Pics
Conflicting Spec
Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
https://www.shopjimmy.com/vizio-gj-2k1... -
by eccerr0rMy cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...Today, 12:34 PM
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by GentianI have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...03-06-2023, 07:07 AM -
by valvashonFor some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...1 Photo - Loading...
