magicspin dvd burner
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: magicspin dvd burner
    Originally posted by stj
    lite-on junk.
    I'm afraid I'm gonna have to agree about Lite-On.
    At least the SOHR-5239V CD-RW drive I have. It loves to randomly stop in middle of reading a CD, at least when less than around 70 F in the room.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      i have hand nothing but good luck with my liteon drives... every one i have owned worked... so i disagree, lite-on not junk.
      dranted, the newest one was an '08 build...
      sigpic
      (Insert witty quote here)
      • toastygoodness
        • Jul 2005
        • 813
        yeah, i disagree too. i have lite-on everything, multiple devices, all my clients have lite-on drives. not a single failure. maybe i'm just lucky. i count around 90 lite-on drives that i have.
        sony, phillips, lg, etc have all had problems with me tho for some reason.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i have good luck with sony as well... problems with lg and phillips (they suck at everything it seems these days) for me...
          sigpic
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Lube the slides [or rail] on the laser platform.
            Usually the grease has all pushed to the ends and all you have to do is re-spread it. [Use a toothpick.]
            If not then use a TINY bit of silicon grease.
            Mann-Made Global Warming.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Haven't had trouble with LG.
              Quit using Lite-on back when they were called Gold Star.
              HL-DT-ST types usually work good after a firmware update.
              Only had one Phillips and it was crap from day one.
              My [real] Plextor from back in the 90's is still going strong.
              - Dr Seuss
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                i had an lg drive out of a gateway overheat...it would never read cd's anyway... POS!
                sigpic
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  LG = HL-DT-ST = Goldstar
                  HL-DT-ST = Hitachi-LG Data Storage = what most ppl. call "LG" nowadays..
                  Goldstar -> Lucky Goldstar -> LG
                  lite-on (more like lite-off when the lasers die after half a year) has nothing to do with any of these..
                  from what i know, lite-on is somehow related to JVC.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I think your right.
                    I bought an 8x Gold Star back in the 90's and it wouldn't do Linux [which is what I specifically bought it for and it said Linux compatible on the box] and I swore I'd never get another Gold Star again.
                    I guess 10+ years later I forgot who was who.
                    - Dr Seuss
                    • kaniki
                      • 514
                      #30
                      half a year.. naa.. more like 1 year 1 day.. just out of warranty. I have had that happen 2 times with lite-on drives.. one was a DVD ROM for the PC, the other was a DVD Burner for the TV. Both crapped out just after a year and just out of warranty..
                        • 31304
                        10 years ago i was doing SGI stuff,
                        optical drives on unix was always a problem then, the drive had to have a specific block-size.
                        good drives like pioneer & yamaha had a jumper to set the blocksize for unix comptability.
                        the junk didnt.
                        the best drive i ever had - still have is my pioneer scsi slot-loader.
                        those are built like tanks with a mechanism that is pure quality.
                        i used to carry it around for doing software installs because it was soo much better than other peoples drives!
                        • toastygoodness
                          • Jul 2005
                          • 813
                          lite-on isn't related to anything. out of all the optical drives, it is the only one from taiwan. jvc, sony, plextor are japanese. lg is korean, so is samsung. pioneer is japanese too. phillips might as well be korean, they share with lg.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Plextor doesn't -make- optical drives anymore.
                            Their drives are OEM from someone else now with a customized firmware.
                            - Dr Seuss
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              Usually Lite-On OEM.
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                #35
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Yes,,, at least they used to be.
                                  Couple years ago I tracked down who made 3 or 4 of the Plextors that were current then and all but one were Lite-on.
                                  I haven't considered Plextor since then as just buying a Lite-on branded unit would get the same part for something like 20% less $$.
                                  - Dr Seuss
                                    • 31304
                                    not good these days,
                                    Plextor - gone
                                    Yamaha - gone.
                                    Pioneer - quality not always what it was, it varies from drive to drive. the 111 is a good one.
                                    NEC - now optiarc, did sony help or damage the NEC quality? i think we dont have that answer yet.
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      #38
                                      what about lg?
                                        • 31304
                                        i was only listing the good stuff!!!
                                        • kaniki
                                          • 514
                                          #40
                                          didnt sony stop making ROM's and lease out the production of them to another company a couple years ago?
                                          • lapfix
                                            RT809f not reconize bios chip !
                                            by lapfix
                                            When i try to read my bios chip , my RT809F didn't reconized even i install the last update ( 202220301 )
                                            Message : Chip ID : 0*00204309 the device is not found in the corresponding partnumber....so the message is clear ....what to do !! how to add this device !!
                                            10-10-2022, 07:26 AM
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • c_corr
                                            Asus P4C800-E VRM issues
                                            by c_corr
                                            This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
                                            This board uses mext ICs and Mosfets in VRM:
                                            - ADP3180 PWM controller - in 3 phase mode
                                            - ADP3418 as Modfet drivers
                                            - High side Mosfets STD38NH02L (from ST)
                                            - Low side Mosfets STD90NH02L
                                            Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
                                            I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
                                            02-08-2025, 11:59 PM
                                          • CapLeaker
                                            Kenmore electric range replacement infinity switch?
                                            by CapLeaker
                                            Actually this range had multiple problems but I fixed all the others already.
                                            I am stuck finding a replacement infinity dual burner switch for a Kenmore C970-605121. The dual burner is stuck full on as soon as you turn the knob either side, either the difference of either only one or both burners running full tilt.
                                            I tried cleaning it inside contacts, but that didn’t do anything.
                                            I believe the dual burner switch reads a part number of: 318191021 which is hard to find. I came across a 318191026 part number but it has 2 pins on the row missing. Is there anything...
                                            05-14-2023, 12:03 PM
                                          • madan1
                                            Diesel heater emergency power supply / poor man's UPS
                                            by madan1
                                            Hello everyone.
                                            Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                                            12-18-2022, 08:05 PM
