"A disk read error occured"
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    I've run into this issue several times with computers I've sold. I know it's not a hardware problem, as it's occured with completely different hardware. It happens regardless of component manufacturer, chipset, HD manufacturer, etc. It happens on computers with perfectly functional hardware (it passes all tests). It happens on computers with a good sized APC UPS. As far as I can tell, it's a Windows XP problem and Microsoft doesn't know what it is and won't / can't fix it.
    What happens is, after the system is in use for a period of time, anywhere from a day to 5 years, it will come up with "A disk read error occured Press CTRL / ALT / DEL to restart" right after post, before loading the OS. I've only seen it on computers with XP.
    Sometimes chkdsk (from another computer) will fix it. Sometimes it wont. Sometimes changing the SATA cable will fix it. Sometimes it wont. Sometimes plugging the drive into a different SATA port will fix it. Sometimes it wont. Sometimes changing the drive from SATA 300 to SATA 150 will fix it. Sometimes it wont. It's a crapshoot, and I'm spending a lot of time on it when I could be doing other things. It sucks!
    While troubleshooting this problem in the past, I've replaced hardware under warranty. I've taken this hardware, installed Linux, and it works perfectly! WTF? I'm even using a hard drive that had been getting this error every week, that I replaced, on my personal system running Fedora Linux. It's a 250GB Samsung. It's been running for a year and a half perfectly.
    So anyway, what the **** is going on? Is XP really that unstable? Has anyone else on here seen it? Does anyone know how to prevent this error, or at least what is causing it?
    A man convinced against his will is of the same opinion still.
  • Wizard
    • Mar 2008
    • 2296
    Re: "A disk read error occured"
    This is hardware that caused this. Dodgy ram, mainboard dropping a bit etc. Investigate deeply. I don't ever see this happen on a good computers.
    PSU as well.
    List out the sources and what hardware that usually had this happen. Also Maxtor and Seagate had a run of bad drives that corrupts.
    Cheers, Wizard
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      powered off while writing to the disk.
      same as pulling a flash drive while writing.
      corrupts it.
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        It has happened on...
        Biostar TF-7025-M2
        Biostar GF-7025-M2
        Biostar TP45HP
        Gigabyte P45 P45-UD3L
        Various Nforce 4 / 570 boards
        Various Asus boards
        Various Samsung and WD hard drives
        Silverstone, FSP, and AcBel PSU's
        Both AMD and Intel CPU's.
        It would be a book if I listed every hardware component. I highly doubt it's that.
          • 31094
          xp suffers from memory leaks and the hardware drivers are virtually alpha release.
          make sure you install the drivers for the chipset and dont try to run 24/7, you cant.
          i know people who do run 24/7 in corporate networks and they reboot overnight every couple of days to a week depending on the machine.
          • seanc
            • Nov 2008
            • 1319
            I don't have this happen unless hardware is failing, usually the disk. You checked that disk for bad/pending sectors?
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              I used to leave my daily use XP machine on for months at a time... no reboots. Now it's running 7 and is even more stable.
              As for the OP problem... usually caused by failing hard drives or RAM.
              Ludicrous gibs!
              • acstech
                GrumpyModerator
                • Jul 2007
                • 1432
                Ok I ran an extended SMART self-test, on the one I'm currently working on, using the tools in Linux.
                The results show no drive problem. No bad sectors, no pending sectors.
                I ran memtest86 on it. No problems there either.
                An additional piece of information: Right before the the problem occurs, the Windows event viewer records several event ID 11 errors.
                • seanc
                  • Nov 2008
                  • 1319
                  Controller errors?!
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    could be cables that don't have good contact?
                    • ethaniel
                      Capacitor n00b
                      • Apr 2010
                      • 27
                      SATA + old XP version = problems. You should be using XP with at least integrated SP3 these days, and make sure you use IDE mode for SATA drives in the BIOS. AHCI is a nightmare under XP. Some drivers are good, but for some motherboards you still need to load separate drivers using a floppy disk (yes, a floppy disk). XP SP2 will be shot down in june. You should consider making the jump to Windows 7 if the hardware allows it, or sticking to Linux. I've been running Ubuntu 10.04 and it works really nice so far.
                      AMD Phenom II X2 555 3.0Ghz @ 3.5Ghz - ECS A780GM-A v1.0 - 4 GB OCZ Gold DDR2 800 - 2 GB Kingston DDR2 800 Value - ATI Radeon HD4650 512MB - Windows 7 x64 - A bunch of hard drives
                      • AudioCraZ
                        • Sep 2009
                        • 147
                        Normally when I see this, is it usually Ram (or memory controller), CPU, or ROM failing. And, every so often, a beyond dirty disk that the customer couldn't realize was the problem....
                        I never get this on good working systems. If you get a disk read error, there is a problem somewhere.
                        • acstech
                          GrumpyModerator
                          • Jul 2007
                          • 1432
                          Ok, it passes all my tests. Tell me what you use for testing software, as obviously the stuff I use hasn't found the problem.
                          • acstech
                            GrumpyModerator
                            • Jul 2007
                            • 1432
                            Ok I found the problem. It was the memory. Here's the thing though:
                            1. It passes Memtest just fine. It also passes the Intel Burn Test just fine.
                            2. It fails Ultra-X Quick Tech Pro's memory diagnostic (this is a paid-for diagnostic program). Leading me to believe Memtest = junk.
                            3. It only fails when the computer is cold, after having been off and cooled to room temperature. After it's been run for a little while it passes the test.
                            Weird, 'eh?
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              there's memtest and there's memtest.
                              memtest86 and the more up-to-date memtest86+ to be exact
                              • welp
                                PS5 Disk Tray issues.
                                by welp
                                I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
                                Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
                                Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
                                So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
                                With that knowledge I preceded to check all the fuses for the 12v rail on the main...
                                12-19-2024, 02:04 PM
                              • DynaxSC
                                ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                by DynaxSC
                                I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                The behaviour is also really very strange, i.e.:
                                • The disk shows always up in BIOS - so it is recognized, so far so good
                                • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                02-23-2025, 01:33 PM
                              • madura2010
                                DAY11AM6E0 hard disk drive and optical disk drive not detected
                                by madura2010
                                Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                i checked the connectivity of ribbon=good communication with hard and motherboard
                                changed hard disk and checked=3f0 error persist
                                sata power=+5v available
                                Then checked data capacitors=all good
                                Then checked data lines path connectivity to pch=all good
                                reflashed...
                                03-12-2023, 09:09 AM
                              • chth96
                                LG GCC-4521B cannot read any disk
                                by chth96
                                I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
                                But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
                                And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
                                But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
                                02-13-2024, 07:31 AM
                              • mircea_mihai_94
                                MBP 16" A2141 - Cannot install OS
                                by mircea_mihai_94
                                Hi everyone.
                                I received a MBP 16" (board 820-01700) that can't install the OS.
                                The customer says that it started getting slower and received an error in the notification center: Volume Hash Mismatch. He tried to erase the disk and reinstall the OS via internet recovery. Unfortunately he did not disable the startup protection prior to deleting the drive (needs an admin account on the disk to do so) so I cannot boot from external sources. The error occurs when the installation is almost complete and it says: An error occured loading the update. The board is in pristine condition,...
                                07-12-2022, 10:25 AM
