LG GCC-4521B cannot read any disk
  • chth96
    • Nov 2022
    • 118
    • indonesia
    I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
    But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
    And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
    But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked by Isopropyl Alcohol 99% and I rotated pot to clockwise very slightly.
    But All of my efforts is in vain.It still won't read any disk at all..
    Is there any clue to fix not able to read any disk in LG GCC-4521B drive?
    I created below dropbox link which demonstrate how long GCC-4521B struggle to read disk..
    https://www.dropbox.com/scl/fi/pnst3...bequdizt3&dl=0
  • welp
    PS5 Disk Tray issues.
    by welp
    I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
    Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
    Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
    So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
    With that knowledge I preceded to check all the fuses for the 12v rail on the main...
    12-19-2024, 02:04 PM
  • DynaxSC
    ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
    by DynaxSC
    I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
    Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
    Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
    The behaviour is also really very strange, i.e.:
    • The disk shows always up in BIOS - so it is recognized, so far so good
    • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
    02-23-2025, 01:33 PM
  • Stanley1843
    Windows 11 disk no boot
    by Stanley1843
    I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
    I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
    DISM /Online /Cleanup-image /Restorehealth
    The DISM.... command shows me the error 87.
    sfc /scannow
    chkdsk
    bootrec /FixBoot
    bootrec /ScanOs
    bootrec /RebuildBcd
    For some reason it writes(Total identified installations 0) like there no...
    10-18-2025, 04:41 AM
  • madura2010
    DAY11AM6E0 hard disk drive and optical disk drive not detected
    by madura2010
    Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
    i checked the connectivity of ribbon=good communication with hard and motherboard
    changed hard disk and checked=3f0 error persist
    sata power=+5v available
    Then checked data capacitors=all good
    Then checked data lines path connectivity to pch=all good
    reflashed...
    03-12-2023, 09:09 AM
  • mkdj
    Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
    by mkdj
    Dear all,
    I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
    Here the steps I have taken to fix the laptop:
    - downloaded latest BIOS from Lenovo Website...
    10-18-2025, 03:43 AM
