PS5 Disk Tray issues.
  • welp
    • Apr 2024
    I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
    Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
    Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
    So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
    With that knowledge I preceded to check all the fuses for the 12v rail on the main board, all fuse's check out.
    Where should I look next?
  • welp
    • Apr 2024
    Fuse was blown on the 12V right before the power connector for the disk tray.
      Surface Mount Fuses Fundamentals Datasheet
      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
      10-07-2024, 06:07 AM
    • Sik_6ty_Sixx
      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
      by Sik_6ty_Sixx
      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
      02-18-2025, 05:06 AM
    • DynaxSC
      ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
      by DynaxSC
      I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
      Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
      Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
      The behaviour is also really very strange, i.e.:
      • The disk shows always up in BIOS - so it is recognized, so far so good
      • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
      02-23-2025, 01:33 PM
      After all of...
      07-13-2024, 08:14 PM
    • madura2010
      DAY11AM6E0 hard disk drive and optical disk drive not detected
      by madura2010
      Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
      i checked the connectivity of ribbon=good communication with hard and motherboard
      changed hard disk and checked=3f0 error persist
      sata power=+5v available
      Then checked data capacitors=all good
      Then checked data lines path connectivity to pch=all good
      reflashed...
      03-12-2023, 09:09 AM
