best cheap/free scores 1.1
This is a sticky topic.
    • 30932
    Re: best cheap/free scores 1.1
    Originally posted by xelectech
    Sometimes craigslist really comes thru for me, I just got a Megatouch Maxx countertop
    video arcade game from a guy who was moving. It's heavy (about 95 lbs.) and it was DOA,
    but I replaced all the caps on the MB (it's a Unicorn!) and it now lives again...yay!
    what software version is that?
    i specialise in those.
      master hoarder
      • May 2008
      • 12164
      • Bulgaria
      #1562
      Haven't gotten anything recently, but I modded those wireless headphones I mentioned in my last post - I put wires on them so they are no longer wireless ... and now they sound great through my headphone amp. Crisp highs and much deeper lows compared to my MDR-023's. However, their drivers are only rated for 30 mW, so they can't handle too much power before starting to distort. But that is okay, since I don't need to turn my volume up that much anymore to get good, loud bass
      Originally posted by Dan81
      PixelView FX5200 128MB - bulged Evercons but OSCON near DVI port OK.
      You gonna fix it? I know it's a worthless card in terms of performance. But now I try to fix mostly older hardware, as that stuff is just loyal and will keep working forever.
      BTW, the Gigabyte mobo is nice.
      • Dan81
        SNES-powered
        • Oct 2013
        • 1865
        • Romania
        #1563
        Thanks. That mobo came from a friend that had 3 PCs. I traded him my old A7N8X-E Deluxe w/ Athlon XP 1900+ (I have my K7N2 and 2500+) for that mobo and same goes for the case. The case isn't as bad as I would expect (other than the inability to remove the right panel as it's used for mounting the mobo) and it looks quite nice on the front. I also installed 2 floppy drives
        Why not? It's not that bad. Also,I need it for another system.
        (K8V-X SE,768MB RAM,Sempron 3000+,FX5200 128MB,40GB HDD and 20GB HDD (both Maxtors), ANS LC-B350ATX (rebuilt) )
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Dan81
          SNES-powered
          • Oct 2013
          • 1865
          • Romania
          #1564
          Fixed the FX5200 and crossflashed it to FX5500.
          I also changed the video mode of the VGA BIOS (color 640x480) and the OEM sign-on message (it has a small piece of text followed by "Geforce FX 5500)
          FYI,I've replaced all the 1500uf 6.3v Evercons with 1000uf 6.3v Rubycon YXGs from a dead FX5200. At least the working card has a active cooler.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
            master hoarder
            • May 2008
            • 12164
            • Bulgaria
            #1565
            Yes, so we are on the same page. Good that you fixed it.
            I didn't know that it can be soft-modded to a FX 5500, though. That's really cool . Just like some of the GeForce 6200 cards can be soft-modded into 6600.
            Funny thing is, the Radeon 9500 Pro/9700 still beats my modded 6600 (6200) in some games - particularly when there is heavy use of shaders.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1865
              • Romania
              #1566
              Just got some moar stuffs:
              Premier LC-C400ATX - replaces my B400ATX because of a dud 80GB SATA (it shorted out of the blue,wires on LC-B400ATX were fine). It has complete input filtering from factory and quality wise its good enough to power a 2.8GHz Northwood Pentium 4,3 DVD-ROMs,2 Floppy drives,a 80GB SATA HDD and a Radeon HD3450 512MB.
              HIS Radeon 9600 Pro 128MB DDR - got this one along with the mentioned PSU,but sadly the screen's garbled. Uses Nichicon HC (anybody heard about those series?) caps and polymers. It has a aftermarket Titan cooler with a 3pin fan plug. Anybody know why the screen's garbled?
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
                master hoarder
                • May 2008
                • 12164
                • Bulgaria
                #1567
                Garbled screen = likely BGA issue with the GPU or RAM (if I am not mistaken, this card has RAM chips that are BGA).
                Just reflow it and it should be good as new. Use a heat gun or something similar. Do NOT bake in the oven - this will kill the caps for sure.
                Speaking of caps, those Nichicon HC caps are quite reliable. IIRC, they are a grade better than Nichicon HD, which is equivalent to Chemicon KZE. So perhaps Panasonic FR/FM? (I going all off top of my head here, as I am too lazy to check). And the polymer caps on those cards are usually Chemicon PSA or Nichicon NA(?) - so again, good stuff.
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  #1568
                  Nichicon HC is a direct cross to Rubycon ZA, also found often on those cards. Just for the sake of it, I attached the HC and HD datasheet here (the datasheets for the laminated case versions) as well as the Nichicon NA polymer datasheets (the three versions I could scrounge from the net at large). Nichicon NA is a direct cross to the first version of Fujitsu RE. I also attached the datasheet for a lesser known series known as Nichicon NX (SMD), which should be a direct cross to NCC PXA (the series interchangeably used with Nichicon NA on those cards).
                  And yes, HC and ZA are lower grade than HW and HV, though not quite as low ESR as MBZ or HM, but HC and ZA are in larger case sizes than even HD.
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1865
                    • Romania
                    #1569
                    Refreshing this thread:
                    Just got some more free stuff:
                    Biostar P4M900-M7 SE w/Pentium E2160
                    Delux ATX-450W P4 (green label) -Sun Pro built,AT-2005B. Has 24 pin cable
                    Gainward GT440 1GB DDR3 128B
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                      • 30932
                      nice nvidia card.
                      wish i could get one for free - all i get is g-force4's
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1865
                        • Romania
                        #1571
                        Originally posted by stj
                        nice nvidia card.
                        Thanks. What's weird with it is that it goes haywire (blank screens) on the Biostar mobo but works fine on my MSI K9N SLi.
                        Anyways,think the Sun Pro is worth modding? Got some parts laying around.
                        What's weird with it though,is that the main transformer (EI-33,at least they don't lie ) doesn't have that grounding wire common for all PSUs.
                        Main rig:
                        Gigabyte B75M-D3H
                        16GB DDR3-1600
                        Delux MG760 case
                          • 30932
                          you mean the thick wire that arches out of the top of the windings?
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1865
                            • Romania
                            #1573
                            Yes,that's the one.
                            Also there's no spot on the board for it.
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                              master hoarder
                              • May 2008
                              • 12164
                              • Bulgaria
                              #1574
                              Hehe.
                              That grounding wire (called center tap) is actually not that common. Only half-bridge topology PSUs have it. However, I suspect you see it a lot since you do tend to use Deer and other cheap PSU brands quite a bit .
                              As for my cheap/free scores: I stopped buying broken stuff from eBay and elsewhere - at least for now. I just moved back at home from college and my room is filled to the brim now. So I need to stop and maybe donate/recycle some of the stuff I have. Just way too much at the moment: 7 CRT monitors (3 waiting in the garage once I free more room in my closet), 10 ATX/mATX PC cases (2 waiting for more free room), 1 small CRT TV, 3 bookshelf -type speakers (4 large floor speakers waiting in garage as well), 2 large stereo/SRS amps, 3 Xbox 360 plastic cases/shells, 3 Xbox 360 metal cases with motherboards, 1 PS3 case with stuff inside, and boxes upon boxes of PC and electronics junk .
                              • goodpsusearch
                                • Oct 2009
                                • 2848
                                • Greece
                                #1575
                                I feel you momaka. I have so many things to repair/test and so little time and space!
                                • SteveNielsen
                                  Retired Tech
                                  • 2327
                                  Same here. I save up too much junk thinking I'll get parts from them. Sometimes I do but mostly they just take up space and collect dust.
                                  • rhomanski
                                    nowhere man
                                    • 5157
                                    • U S of A
                                    #1577
                                    That's how hoarders get started. Soon they have just a path to their bed. Then they're sleeping on the couch. Although with most it truly is garbage they save.
                                    sigpicThe Sky Is Falling
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1865
                                      • Romania
                                      #1578
                                      Hehe.
                                      I've been seeing that center tap wire quite a lot but this Sun Pro was the first PSU I've seen not having one. What are the chances of replacing the transfomer with one from a Delta?
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      16GB DDR3-1600
                                      Delux MG760 case
                                        master hoarder
                                        • May 2008
                                        • 12164
                                        • Bulgaria
                                        #1579
                                        Indeed, and that's what I want to avoid.
                                        I do vacuum my room bi-weekly (and sometimes more often if I make a mess cutting something). And no trash or food inside either. But yeah, now that I moved back, I am definitely overwhelmed with all of the stuff I have collected. I think I definitely need to get rid of some things.
                                        For one, I do have a non-working HP A7217A (Sony GDM-FW900) 24" CRT monitor in the room. I'm thinking of making a how-to dismantling video and then getting rid of it (sans the boards maybe, since they are hard to find now and I have another of these monitors that works). That should free quite a bit of space in the room. Also, the bookshelf speakers I am using right now will likely go to donations. But I don't want to give them out the way they are in their current condition since the tweeter on the left speaker is blown. I want to either replace it or fix it before donating. After all, I don't want to donate junk.
                                        If the PSUs use the same topology and the pins for GND, 5V, and 12V rail match, then it might work.
                                        But I'd say you are better off trying to fix the Delta PSU, even if it rated for 100W. It would still perform better than a "500W" over-rated Sun Pro/Deer/L&C, and all the other low-end junk.
                                        • synaesthesia
                                          • Jul 2015
                                          • 35
                                          • United Kingdom
                                          #1580
                                          Re: Your Best Dumpster Finds
                                          Loving some of these stories!
                                          Used to work for a recycling company and the things some people threw out was hilarious. Core 2 Quad and Core 2 Duos... in 2007. When these companies refresh, so often they just hurl out the "old" in such a way with a dodgy reason like "being more cost effective".
                                          On which note, Dell are hilarious. We used to get palletloads of gear from Dell to recycle.
                                          70/30 brand new gear/faulty gear.
                                          If an engineer goes on site to fix a laptop for instance, they'll take a mainboard just in case. If it's not needed, it'll be sent for recycling. Brand new, in it's box, seals unbroken.
                                          It's more cost effective.
                                          I built a Core 2 Duo Dell Latitude D830 with 1920x1200 screen, and as it was all "scrap" I was allowed to keep it. All parts were brand new; only bits I had to add myself were memory for obvious reasons, and storage. They retailed at the time for £1400.
                                          I had a C2 Quad Q6600 from there along with several 400GB hard drives and a Geforce 8800GT - that was faulty but a spell in the oven soon fixed that!
                                          Needless to say, that's clean dumpster diving but still counts!
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • eccerr0r
                                            Caseless Cheap Chinese electronic tools
                                            by eccerr0r
                                            "Caseless Cheap Chinese electronic tools" I mean things you get from banggood, ali, fleabay, Am-Zon, etc. like AVR-Transistortester, miscellaneous signal generators, frequency counters, (variable) power supplies, oscilloscopes, low resistance meters, etc., etc. that comes optionally with a case, or comes only with a cheap piece of plastic that barely provides protection to the PCB.
                                            Just wondering what of these (generally flimsy) tools you actually find use (almost) everyday and find indispensable for the price, compared to buying a Fluke or whatnot, if there is an expensive...
                                            11-23-2021, 03:44 PM
